-   OpenFOAM Installation (https://www.cfd-online.com/Forums/openfoam-installation/)
-   -   Problems with MPI implementation (https://www.cfd-online.com/Forums/openfoam-installation/96373-problems-mpi-implementation.html)
francesco_capuano January 20, 2012 10:49
Hi everybody,
I'm having some problems running OpenFOAM v 2.1.0 in parallel mode. In particular, I need to update the PStream library to switch from OpenMPI to Intel MPI, which is actually installed on the cluster I'm using.
I have followed the instructions in
http://openfoamwiki.net/index.php/HowTo_Pstream
but they refer to old versions of OpenFOAM (v. 1.XXX) and I cannot figure out what's the problem.
Is there anyone who has successfully switched from OpenMPI to other MPI implementations?
wyldckat January 21, 2012 13:57
Greetings Francesco,
The wiki page isn't very out of date, the instructions there still apply to the latest versions of OpenFOAM... with a few minor adjustments...
Basically, there are 3 places that need attention (OpenFOAM version number is just a reference):
  1. "OpenFOAM-2.1.0/etc/bashrc" - check where it says:
    #- MPI implementation:
    #    WM_MPLIB = SYSTEMOPENMPI | OPENMPI | MPICH | MPICH-GM | HPMPI
    #              | GAMMA | MPI | QSMPI
    export WM_MPLIB=OPENMPI
    Change "WM_MPLIB=OPENMPI" to "WM_MPLIB=INTELMPI"
  2. "OpenFOAM-2.1.0/etc/config/settings.sh" - search for the code that starts with:
    # Communications library
    unset MPI_ARCH_PATH MPI_HOME FOAM_MPI_LIBBIN
    case "$WM_MPLIB" in
    OPENMPI)
    Wait... you will find in 2.1.0 on this file, near the end, the entry for "INTELMPI)". It assumes that "MPI_ROOT" is properly defined before you source "OpenFOAM-2.1.0/etc/bashrc".
  3. "OpenFOAM-2.1.0/wmake/rules/linux64Gcc/mplibINTELMPI" - this is the rules file for the "INTELMPI" option.
And that's pretty much it!
Best regards,
Bruno
francesco_capuano January 21, 2012 15:57
Thanks Bruno for your quick and clear reply!
As soon as I get back to work I will try and let you know!
Regards,
Francesco
francesco_capuano January 24, 2012 04:06
Dear Bruno,
I get the following message:
Warning in /u2/capuanf/OpenFOAM/OpenFOAM-2.0.1/etc/config/settings.csh:
MPI_ROOT not a valid mpt installation directory.
Please set MPI_ROOT to the mpt installation directory.
(usually done by loading the mpt module)
MPI_ROOT currently set to '/dummy'
MPI_ROOT is not properly set! How can I fix this?
Problem solved! I just defined the MPI_ROOT variable properly in my .bashrc file and it worked!
Thanks in advance!
sandy September 19, 2012 05:21
Hi Francesco,
I met the same problem. Could you give a detailed list how to set the MPI_ROOT variable in .bashrc ?? Thanks
francesco_capuano September 19, 2012 11:09
Originally Posted by sandy (Post 382505)
Hi Francesco,
Hi Sandy,
you can define the MPI_ROOT variable by adding the line
export MPI_ROOT=mpipath
at the end of the your .bashrc file. mpipath is the mpi installation path of your computer/cluster. You can either try to find it yourself or ask it to your cluster technician. Just to give you a clue, in my case the installation path is
/cm/shared/apps/intel/ics/impi/4.0.3.008/
In case you have further questions, please don't hesitate to ask.
Regards,
Francesco
hawkeye321 January 15, 2013 20:46
MPI version and OpenFOAM 2.1
Hi FOAMERS
I am using OpenFOAM 2.1,and have LAM/MPI already installed (LAM 7.1.4/MPI 2 C++/ROMIO - Indiana University). When I am trying to rum icofoam on 3 processors I get this error
It seems that [at least] one of the processes that was started with
mpirun did not invoke MPI_INIT before quitting (it is possible that
more than one process did not invoke MPI_INIT -- mpirun was only
notified of the first one, which was on node n0).
mpirun can *only* be used with MPI programs (i.e., programs that
invoke MPI_INIT and MPI_FINALIZE). You can use the "lamexec" program
to run non-MPI programs over the lambooted nodes.
Any idea why i get this error?
I have already run some cases on parallel with OpenFOAM 1.7 and mpirun (Open MPI) 1.3.2. Can I used LAM/MPI instead of OpenMPI? If yes, is there a certain version of LAM/MPI which is compatible with OpenFOAM 2.1?
nimasam January 16, 2013 01:53
i dont know what the error is, but there is a suggestion in error line
did you try this program?
