[OpenFOAM.org] paraView reader module build problem |
March 5, 2014, 00:15 |
#41 |
Rep Power: 12 |
I am using UBUNTU 12.04 .
Yesterday I proceeded with re-installation neglecting the previous problem and got some errors which have reflected in make.log . Here is the snapshot after executing sudo nano /etc/apt/sources.list |
March 5, 2014, 16:27 |
#42 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Looking at the image you've shown, the problem is that you only have the "universe" repository turned on. You also need the "main" repository. Create a backup of that file and then use the following lines: Code:
deb http://archive.ubuntu.com/ubuntu/ precise main universe deb-src http://archive.ubuntu.com/ubuntu/ precise main universe Code:
apt-get update
March 6, 2014, 01:40 |
#43 |
Rep Power: 12 |
Thanks a lot
I managed to install it properly |
May 19, 2014, 05:08 |
Problem after the first line
#44 |
Nour Tamer
Just want to know what should I do if after the first : Code:
]echo $PV_PLUGIN_PATH Best Regards Nour |
May 19, 2014, 05:20 |
#45 |
Rep Power: 12 |
Hi Nour Tamer,
Can you explain your problem in detail ? |
May 19, 2014, 06:12 |
#46 |
Nour Tamer
Hi, Sam
In fact I had some problems with Paraview library, when I try to see a result or any mesh i had : nour@cmefe-p:~/Desktop/exof/plateHole> paraFoam FATAL ERROR: ParaView reader module libraries do not exist Please build the reader module before continuing: cd $FOAM_UTILITIES/postProcessing/graphics/PV3Readers ./Allwclean ./Allwmake But finally I got a solution, first I must do a: [CODE] touch filename.foam then executing PVIew314 and open filename.foam and finally it works. Thank you very much for your help |
June 1, 2016, 12:56 |
#47 | |||
Pavel
Rep Power: 11 |
Hello Bruno & others,
Could you give some advice here, please? Running Code:
echo $PV_PLUGIN_PATH Running Code:
ls -l /opt/openfoam210/platforms/linux64GccDPOpt/lib/paraview-3.12 Code:
ERROR: ParaView not found in /home/pavel/OpenFOAM/ThirdParty-v3.0+/platforms/linux64Gcc/ParaView-4.4.0 Quote:
This solved some issues, but not cannot find a file: Quote:
P.S. first installation. Fresh one (well, I deleted another attempt and started from fresh) Cheers, Pavel Quote:
June 8, 2016, 02:20 |
#48 |
Pavel
Rep Power: 11 |
Hi again,
I managed to sort this out. I forgot tot check all the system requirements as presented on the openfoam website. Cannot remember which one sort this issue out. After I checked this, I installed the third party source code and it did compile well. ParaFoam is working now. |
July 1, 2017, 13:51 |
Possible solution...
#49 |
Riccardo
Rep Power: 10 |
I had the same problem when I tried to run paraFoam for postprocessing. I found useful some of the previous suggestions which made paraview actually working (i.e. "touch filename.foam then executing PVIew314"). But most of all, I definitely recommend to Switch to root mode (administrator) with "sudo -s" and then run paraFoam. Through this operation paraview worked perfectly.
July 2, 2017, 15:10 |
#50 | |
Bruno Santos
Rep Power: 128 |
Whenever possible, it's preferable to rely on aliases to activate the OpenFOAM/foam-extend environment on each terminal, so that whenever a new terminal is started, the OpenFOAM environment is not loaded automatically. This is detailed here: https://openfoamwiki.net/index.php/I...nFOAM_versions @powpawell: My apologies, but I ended up not having time to get back to you on this last year |
March 7, 2018, 02:42 |
#51 | |
Elham
Rep Power: 16 |
I stuck during installation of paraView4 from https://openfoam.org/download/2-3-1-source. When I execute sudo nano /etc/apt/sources.list I got Screenshot from 2018-03-07 15-39-51.png I will appreciate to help me find a solution. Regards, Elham |
March 7, 2018, 15:22 |
#52 | |
Bruno Santos
Rep Power: 128 |
Quick answer:
It's not clear what is the exact problem you are having.
March 7, 2018, 23:40 |
#53 | |
Elham
Rep Power: 16 |
paraFoam -builtin Anyway, it seems that it is working. Regards, Elham |
[OpenFOAM.org] paraView running Problem [not found] | X.Thomas | OpenFOAM Installation | 6 | January 14, 2018 12:15 |
Parafoam - FATAL ERROR: ParaView reader module libraries do not exist | Amit_Pawarpawar | OpenFOAM Installation | 1 | August 25, 2014 10:31 |
FATAL ERROR: ParaView reader module libraries do not exist | adarsh tiwari | OpenFOAM Installation | 6 | April 5, 2014 11:47 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
paraFoam reader for OpenFOAM 1.6 | smart | OpenFOAM Installation | 13 | November 16, 2009 21:41 |
