-   OpenFOAM Installation (http://www.cfd-online.com/Forums/openfoam-installation/)
-   -   openFOAM installation in ubuntu 11.10 (http://www.cfd-online.com/Forums/openfoam-installation/97006-openfoam-installation-ubuntu-11-10-a.html)
kirubhakaran February 7, 2012 06:08
hi in previous version of ubuntu i had i.e 10.04 i could able to install openfoam easily
but in ubuntu 11.10 i first tried to install thro ubuntu deb pack installation wen i put wget like to fetch the software i fails it show like the link doesnt exist. so i again tried with source pack installation.
1. i have use ubuntu 11.10 64 bit platform
2. i install all the prerequestive files
3. i download the source pack file given in that website
4. i extracted tar file into my root directory /opt/OpenFOAM
5. then in home directory i /.bashrc file i pasted the following line at last
# source /opt/OpenFOAM/OpenFOAM-2.1.0/etc/bashrc
6. i save the file and close it
7. when i type foamSystemCheck i get as "command not found"
can u help me to sought out this problem .
wyldckat February 7, 2012 16:01
Greetings kirubhakaran,
For the deb package for Ubuntu, start reading here: http://www.openfoam.com/mantisbt/view.php?id=410#c1013
As for the source package, do not install OpenFOAM directly on "/opt" until you have enough experience. Simply follow the instructions provided in the page for the source package and install OpenFOAM on your user area at "$HOME/OpenFOAM".
Best regards,
Bruno
kirubhakaran February 8, 2012 05:03
installation
dear wyldckat
i tried your steps you given but i again fail
i sent the terminal box message initially i got.
kirubha@kirubha-AcerPower-Series:~$ sudo apt-get install openfoam210 --fix-missing
Reading package lists... Done
Building dependency tree
Reading state information... Done
openfoam210 is already the newest version.
The following package was automatically installed and is no longer required:
libjpeg62-dev
Use 'apt-get autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
with regards
kirubhakaran
wyldckat February 8, 2012 06:59
Hi Kirubhakaran,
It's already installed! See the line in bold:
libjpeg62-dev
Best regards,
Bruno
WaterDynamics February 9, 2012 03:41
OpenFOAM have updated the link now for Deb pack Ubuntu, now you can try :)
elvis February 17, 2012 03:16
can you post your ~.bashrc (only the lines that are responsible for OpenFoam)
do the OpenFoam shortcuts work properly? Try
foam
tut
sol
I guess that you did not configure your .bashrc.
