-   OpenFOAM Installation (http://www.cfd-online.com/Forums/openfoam-installation/)
-   -   Metis for OpenFOAM 2.1.0 (http://www.cfd-online.com/Forums/openfoam-installation/97289-metis-openfoam-2-1-0-a.html)
Kaskade February 14, 2012 04:16
the official support for metis has been dropped for license issues. Has someone been able to install and use metis on their own? My attempts so far have been fruitless.
Greetings
Kaskade
AlmostSurelyRob June 5, 2012 17:17
Yes, you need to download metis from this site
http://people.sc.fsu.edu/~jburkardt/c_src/metis/metis.html
and GKLib. GKLib was a bit more tricky to find but I have found it for example here:
http://code.google.com/p/graphlabapi...0a9d384317c3bf
You can checkout the whole repository if you have mercurial installed.
Now it's the question of compiling these things. Set up your include paths correctly. For GKLib I had to add
DMALLOCINC = -I../libmetis/
in the supplied Makefile. libmetis was the position of libmetis.
Metis compiled seamlessly in my case using script although you must add -fPIC to the gcc command.
Finally go to
$FOAM_SRC/parallel/decompose/metisDecomp
change Make/option file to point to your metis library location and run
wmake libso
Let me know if you have any problems with that. I can send you the necessary files.
EDIT: ALSO! I removed the -I pointing to the dummy library. I guess that might be important. :-)
Kaskade June 23, 2012 05:31
Thanks, I'll try it some time. My current case is pretty symmetric, so simple does the trick.
pere April 9, 2013 06:39
Hi everybody,
I'm trying to compile metisDecomp, I'm getting this error while I'm doing wmake libso:
metisDecomp.C: In member function ‘Foam::label Foam::metisDecomp::decompose(const Foam::List<int>&, const Foam::List<int>&, const Foam::scalarField&, Foam::List<int>&)’:
metisDecomp.C:237: error: ‘METIS_WPartGraphRecursive’ was not declared in this scope
metisDecomp.C:254: error: cannot convert ‘int*’ to ‘real_t*’ for argument ‘9’ to ‘int METIS_PartGraphRecursive(idx_t*, idx_t*, idx_t*, idx_t*, idx_t*, idx_t*, idx_t*, idx_t*, real_t*, real_t*, idx_t*, idx_t*, idx_t*)’
metisDecomp.C:275: error: ‘METIS_WPartGraphKway’ was not declared in this scope
metisDecomp.C:292: error: cannot convert ‘int*’ to ‘real_t*’ for argument ‘9’ to ‘int METIS_PartGraphKway(idx_t*, idx_t*, idx_t*, idx_t*, idx_t*, idx_t*, idx_t*, idx_t*, real_t*, real_t*, idx_t*, idx_t*, idx_t*)’
make: *** [Make/linux64GccDPOpt/metisDecomp.o] Error 1
I've linked to libmetis.so.... perhaps any include that is not found?
Kaskade April 9, 2013 11:20
I've compared scotch and metis for some of my old meshes. For some metis was a little faster (decomposing and/or simulation), for some scotch. You are probably wasting more time getting metis to run, than you would ever save by using it.
pere April 9, 2013 11:40
Hi Kaskade,
I'm compiling OpenFoam from the source code so I need the same time to compile it with scotch or metis. Thanks for your reply.
dkokron April 9, 2013 16:30
Mods to get 2.2.x to compile with METIS from parmetis-4.0.2.
Make sure you test the results!!
git diff src/parallel/decompose/Allwmake
diff --git a/src/parallel/decompose/Allwmake b/src/parallel/decompose/Allwmake
index 5cea1fb..581b877 100755
--- a/src/parallel/decompose/Allwmake
+++ b/src/parallel/decompose/Allwmake
@@ -62,6 +62,7 @@ else
    echo
 fi
+wmake $makeType metisDecomp
 wmake $makeType decompositionMethods
 wmake $makeType decompose
git diff src/parallel/decompose/metisDecomp/Make/options
diff --git a/src/parallel/decompose/metisDecomp/Make/options b/src/parallel/decompose/metisDecomp/Make/options
index a6a0f14..b046053 100644
--- a/src/parallel/decompose/metisDecomp/Make/options
+++ b/src/parallel/decompose/metisDecomp/Make/options
@@ -1,7 +1,6 @@
 EXE_INC = \
-    -I$(WM_THIRD_PARTY_DIR)/metis-5.0pre2/include \
-    -I../../dummyThirdParty/metisDecomp  /* location of dummy metis.h */ \
+    -I/home/dkokron/play/ParMETIS/parmetis-4.0.2/install/include \
    -I../decompositionMethods/lnInclude
 LIB_LIBS = \
-    -L$(FOAM_EXT_LIBBIN) -lmetis -lGKlib
+    -L$(FOAM_EXT_LIBBIN) -lmetis
git diff src/parallel/decompose/metisDecomp/metisDecomp.C
diff --git a/src/parallel/decompose/metisDecomp/metisDecomp.C b/src/parallel/decompose/metisDecomp/metisDecomp.C
index e1614a8..2530e61 100644
--- a/src/parallel/decompose/metisDecomp/metisDecomp.C
+++ b/src/parallel/decompose/metisDecomp/metisDecomp.C
@@ -202,6 +202,7 @@ Foam::label Foam::metisDecomp::decompose
    // Vertex weight info
    int wgtFlag = 0;
+    int ncon = 1;
    int* vwgtPtr = NULL;
    int* adjwgtPtr = NULL;
@@ -220,18 +221,19 @@ Foam::label Foam::metisDecomp::decompose
        if (processorWeights.size())
-            METIS_WPartGraphRecursive
+            METIS_PartGraphRecursive
                &numCells,        // num vertices in graph
+                &ncon,            // number of balancing constraints. It should be at least 1.
                const_cast<List<int>&>(xadj).begin(),  // indexing into adjncy
                const_cast<List<int>&>(adjncy).begin(), // neighbour info
                vwgtPtr,          // vertexweights
+                NULL,
                adjwgtPtr,        // no edgeweights
-                &wgtFlag,
-                &numFlag,
                &nProcs,
-                processorWeights.begin(),
-                options.begin(),
+                NULL,              // NULL indicates graph should be equally divided among the partitions
+                NULL,              // load imbalance tolerance for each constraint; NULL -> 1.001
+                NULL,              // options array
                &edgeCut,
                finalDecomp.begin()
@@ -241,14 +243,16 @@ Foam::label Foam::metisDecomp::decompose
+                NULL,
-                &wgtFlag,
-                &numFlag,
                &nProcs,
-                options.begin(),
                &edgeCut,
                finalDecomp.begin()
@@ -258,18 +262,19 @@ Foam::label Foam::metisDecomp::decompose
-            METIS_WPartGraphKway
+            METIS_PartGraphKway
+                NULL,
-                &wgtFlag,
-                &numFlag,
                &nProcs,
-                options.begin(),
                &edgeCut,
                finalDecomp.begin()
@@ -279,14 +284,16 @@ Foam::label Foam::metisDecomp::decompose
            METIS_PartGraphKway
+                NULL,
-                &wgtFlag,
-                &numFlag,
                &nProcs,
-                options.begin(),
                &edgeCut,
                finalDecomp.begin()
@@ -328,7 +335,16 @@ Foam::labelList Foam::metisDecomp::decompose
    CompactListList<label> cellCells;
-    calcCellCells(mesh, identity(mesh.nCells()), mesh.nCells(), cellCells);
+    calcCellCells
+        mesh,
+        identity(mesh.nCells()),
+        mesh.nCells(),
+        true,
+        cellCells
+    // DSK replace after switching to 2.2.x calcCellCells(mesh, identity(mesh.nCells()), mesh.nCells(), cellCells);
    // Decompose using default weights
    labelList decomp;
@@ -362,7 +378,15 @@ Foam::labelList Foam::metisDecomp::decompose
    //  xadj(celli) : start of information in adjncy for celli
-    calcCellCells(mesh, agglom, agglomPoints.size(), cellCells);
+    calcCellCells
+        mesh,
+        agglom,
+        agglomPoints.size(),
+        true,
+        cellCells
+    // DSK replace after switching to 2.2.x calcCellCells(mesh, agglom, agglomPoints.size(), cellCells);
    labelList finalDecomp;
pere April 10, 2013 05:09
Thanks I will try it!
ruby_nuaa May 31, 2014 01:20
Hi pere ,did you solve this problem?
Originally Posted by pere (Post 419375)
Hi everybody,
Hi Pere, I have the same issue here. did you solve this?
