-   OpenFOAM Installation (http://www.cfd-online.com/Forums/openfoam-installation/)
-   -   Paraview Installion Problem on ubuntu (http://www.cfd-online.com/Forums/openfoam-installation/99716-paraview-installion-problem-ubuntu.html)
Indrajit April 10, 2012 07:08
Dear All,
Greetings !
I have installed OpenFoam210 and Paraview3120
While launching Paraview i got the following error message.
Can you guys please suggest.
test@ubuntu:~$ paraFoam
WARN file does not exist:
./system/controlDict
./system/fvSchemes
./system/fvSolution
created temporary 'test.OpenFOAM'
fileName::stripInvalid() called for invalid fileName UbuntuOne
For debug level (= 2) > 1 this is considered fatal
Aborted
test@ubuntu:~$
Thank you in Advance ,
Indrajit
wyldckat April 10, 2012 16:27
Hi Indrajit,
It's simple: you should run paraFoam only from within a case folder. At the end of the installation instructions, did you notice the following commands?
Originally Posted by http://www.openfoam.org/download/ubuntu.php
cd $FOAM_RUN/tutorials/incompressible/icoFoam/cavity
blockMesh
icoFoam
paraFoam
In case you didn't read the beginning of that section, start reading from the section titled "Getting Started".
Best regards,
Bruno
Indrajit April 11, 2012 00:15
Thank you
Hey Bruno :)
Thanks it worked :)
