[snappyHexMesh] Layers in SHM and refineWallLayer
Old   April 25, 2012, 05:21
Default Layers in SHM and refineWallLayer
Daniele Vicario
danvica is on a distinguished road
This argument has been discussed several times but I haven't got a clear idea so far.
What is the difference between the addlayer step in SHM and the refineWallLayer utility ?
I've never been able to add layers in complex geometries with SHM but with rWL is simple. Unluckily the meshes obtained with the utility have usually severe non-orto and skewness problems.
I already tried following the advices in this threads:
http://www.cfd-online.com/Forums/ope...bent-tube.html
http://www.cfd-online.com/Forums/ope...al-layers.html
http://www.cfd-online.com/Forums/ope...tlet-pipe.html
But I couldn't get a clear general procedure... I don't think it's a problem related to my geometries, more probably to my brain
Has someone some hint ? Thanks.
Daniele Vicario
blueCFD2.1 - Windows 7
danvica is offline   Reply With Quote
Old   April 30, 2012, 04:02
Daniele Vicario
I haven't completely solved my problem yet, but I found that is more simple, with SHM, to add one layer at time.
In the enclosed picture you can see 7 layers added to a simple pipe running SHM (guess...) 7 times.
finalLayerThickness is 0.9 in this case.
I don't know why but setting nSurfaceLayers=7 results in no layer added.
I still have to try on complex geometries.
Daniele Vicario
Old   April 30, 2012, 04:52
lore
lovecraft22 is on a distinguished road
Send a message via Skype™ to lovecraft22
If you post your snappyHexMesh dict I could have a look and see if I can find a reason why you don't get layers at once…
lovecraft22 is offline   Reply With Quote
Old   April 30, 2012, 05:32
Daniele Vicario
The reason is because I played too much with parameters... actually I can have 7 layers in one step if I choose the right values.
Here is my SHMDict for addlayer:
addLayersControls
    relativeSizes true;
    layers
        walls
            nSurfaceLayers 7;
    expansionRatio 1.1;
    finalLayerThickness 0.9;
    minThickness 0.000001;
    nGrow 0;
    featureAngle 30;
    nRelaxIter 5;
    nSmoothSurfaceNormals 1;
    nSmoothNormals 3;
    nSmoothThickness 10;
    maxFaceThicknessRatio 0.5;
    maxThicknessToMedialRatio 0.3;
    minMedianAxisAngle 90;
    nBufferCellsNoExtrude 0;
    nLayerIter 100;
With this expansionRatio and finalLayerThickness I am able to get the correct result.
Using my older values, expansionRatio=1.8 and finalLayerThickness=1, SHM is getting more than 100000 faces with zero volume and the results is no layer added.
I'll make some more tests.
Daniele Vicario
[snappyHexMesh] Controlling y+ values with snappyHexMesh? cjm OpenFOAM Meshing & Mesh Conversion 67 July 10, 2019 18:56
[snappyHexMesh] snappyHexMesh and refineWallLayer Claudio OpenFOAM Meshing & Mesh Conversion 0 June 20, 2013 13:36
