[snappyHexMesh] troubles with sHM and parallel |
August 30, 2012, 18:00 |
Tobias Holzmann
Rep Power: 51 |
Hey guys,
I am using sHM since 1 year and since last week I get the following error by executing sHM parallel: Code:
Create mesh for time = 1 [1] [1] [1] --> FOAM FATAL ERROR: [1] read failed [1] [1] From function UIPstream::UIPstream(const commsTypes, const int, DynamicList<char>&, streamFormat, versionNumber) [1] in file UIPread.C at line 114. [1] FOAM parallel run aborting [1] [2] [2] [2] --> FOAM FATAL ERROR: [2] read failed [2] [2] From function UIPstream::UIPstream(const commsTypes, const int, DynamicList<char>&, streamFormat, versionNumber) [2] in file UIPread.C at line 114. [2] FOAM parallel run aborting [2] Read mesh in = 0.12 s [2] #0 [1] #0 Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&) in "/home/shorty/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [1] #1 Foam::error::abort() in "/home/shorty/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [2] #1 Foam::error::abort() in "/home/shorty/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [1] #2 Foam::UIPstream::UIPstream(Foam::UPstream::commsTypes, int, Foam::DynamicList<char, 0u, 2u, 1u>&, int&, int, bool, Foam::IOstream::streamFormat, Foam::IOstream::versionNumber) in "/home/shorty/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [2] #2 Foam::UIPstream::UIPstream(Foam::UPstream::commsTypes, int, Foam::DynamicList<char, 0u, 2u, 1u>&, int&, int, bool, Foam::IOstream::streamFormat, Foam::IOstream::versionNumber) in "/home/shorty/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/openmpi-1.5.3/libPstream.so" [1] #3 Foam::IPstream::IPstream(Foam::UPstream::commsTypes, int, int, int, Foam::IOstream::streamFormat, Foam::IOstream::versionNumber) in "/home/shorty/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/openmpi-1.5.3/libPstream.so" [2] #3 Foam::IPstream::IPstream(Foam::UPstream::commsTypes, int, int, int, Foam::IOstream::streamFormat, Foam::IOstream::versionNumber) in "/home/shorty/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [1] #4 Foam::IOdictionary::readFile(bool) in "/home/shorty/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [2] #4 Foam::IOdictionary::readFile(bool) in "/home/shorty/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [1] #5 Foam::IOdictionary::IOdictionary(Foam::IOobject const&) in "/home/shorty/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [2] #5 Foam::IOdictionary::IOdictionary(Foam::IOobject const&) in "/home/shorty/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [1] #6 Foam::solution::solution(Foam::objectRegistry const&, Foam::fileName const&) in "/home/shorty/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [2] #6 Foam::solution::solution(Foam::objectRegistry const&, Foam::fileName const&) in "/home/shorty/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [2] #7 Foam::fvMesh::fvMesh(Foam::IOobject const&) in "/home/shorty/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [1] #7 Foam::fvMesh::fvMesh(Foam::IOobject const&) in "/home/shorty/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" [1] #8 in "/home/shorty/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" [2] #8 [1] in "/home/shorty/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/bin/snappyHexMesh" [1] #9 __libc_start_main[2] in "/home/shorty/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/bin/snappyHexMesh" [2] #9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [1] #10 in "/lib/x86_64-linux-gnu/libc.so.6" [2] #10 [1] in "/home/shorty/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/bin/snappyHexMesh" -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 1 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- [2] in "/home/shorty/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/bin/snappyHexMesh" -------------------------------------------------------------------------- mpirun has exited due to process rank 1 with PID 13823 on node cfd exiting improperly. There are two reasons this could occur: 1. this process did not call "init" before exiting, but others in the job did. This can cause a job to hang indefinitely while it waits for all processes to call "init". By rule, if one process calls "init", then ALL processes must call "init" prior to termination. 2. this process called "init", but exited without calling "finalize". By rule, all processes that call "init" MUST call "finalize" prior to exiting or it will be considered an "abnormal termination" This may have caused other processes in the application to be terminated by signals sent by mpirun (as reported here). -------------------------------------------------------------------------- [cfd:13821] 1 more process has sent help message help-mpi-api.txt / mpi-abort [cfd:13821] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages Or whats the error? Thanks for reading and helping PS: Running solvers in parallel mode is working fine as well Tobi |
Display Modes | |
[snappyHexMesh] Parallel sHM error | vigges | OpenFOAM Meshing & Mesh Conversion | 12 | September 23, 2022 02:23 |
[snappyHexMesh] Problem with boundaries with sHM in parallel running | Loekatoni | OpenFOAM Meshing & Mesh Conversion | 0 | January 24, 2019 08:56 |
[snappyHexMesh] OpenFoam in parallel with sHM and sFE | pradyumnsingh | OpenFOAM Meshing & Mesh Conversion | 4 | October 26, 2018 17:25 |
[snappyHexMesh] SHM parallel error. I honestly have no idea | stark22 | OpenFOAM Meshing & Mesh Conversion | 4 | December 13, 2017 01:42 |
[snappyHexMesh] shm in parallel with simple decomposition | mihaipruna | OpenFOAM Meshing & Mesh Conversion | 6 | July 16, 2015 05:55 |
