[Salome] ideasUnvToFoam error
Like Tree1Likes
  • 1 Post By Luchini
Old   September 4, 2012, 08:58
Default ideasUnvToFoam error
Luca Franceschini
Luchini is on a distinguished road
I am trying to convert a .unv mesh with groups.
Does anyone knows wha are these errors?
a)
For group 2 named outflow trying to read 1669 patch face indices.
--> FOAM Warning :
From function readSets(..)
in file ideasUnvToFoam.C at line 552
Reading "/XXX/YYY/CCC/Mesh_1.unv" at line 496102
When reading patches expect entity type code 8
Skipping group code 7
b)
Constructing mesh with non-default patches of size:
--> FOAM Warning :
From function polyMesh:olyMesh(... construct from shapes...)
in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 619
Found 13406 undefined faces in mesh; adding to default patch.
End
Thank you for your help
Luchini is offline   Reply With Quote
Old   September 4, 2012, 10:11
Luca Franceschini
problem solved.
In Salome for a 3D case, i was creating the mesh group of points (the default option) instead of faces.
kiski likes this.
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
