-   OpenFOAM Native Meshers: blockMesh (http://www.cfd-online.com/Forums/openfoam-meshing-blockmesh/)
-   -   3D blockMesh for multiple material rectangular blocks one above another (http://www.cfd-online.com/Forums/openfoam-meshing-blockmesh/107284-3d-blockmesh-multiple-material-rectangular-blocks-one-above-another.html)
Sargam05 September 22, 2012 21:46
Hello everybody,
I am trying to make mesh for three multiple material rectangular blocks. In may case there are three solid blocks one above another. constant/polyMesh/blockMesh is:
convertToMeters 1;
vertices
(0.00025 0 0)
(0.0005 0 0)
(0.0005 0.000027 0)
(0.00025 0.000027 0)
(0.00025 0 0.0005)
(0.0005 0 0.0005)
(0.0005 0.000027 0.0005)
(0.00025 0.000027 0.0005)
(0.00025 0.000025 0)
(0.0005 0.000025 0)
(0.0005 0.000026 0)
(0.00025 0.000026 0)
(0.00025 0.000025 0.0005)
(0.0005 0.000025 0.0005)
(0.0005 0.000026 0.0005)
(0.00025 0.000026 0.0005)
blocks
hex (0 1 9 8 4 5 13 12) solid1 (100 80 50) simpleGrading (1.0 1.0 1.0)
hex (8 9 10 11 12 13 14 15) solid2 (100 50 50) simpleGrading (1.0 1.0 1.0)
hex (11 10 2 3 15 14 6 7) solid3 (100 50 50) simpleGrading (1.0 1.0 1.0)
edges
patches
// From Bottom to Top
patch
solid1_Bottom
(0 4 5 1)
patch
solid3_TOP
(3 7 6 2)
symmetryPlane left
(0 4 12 8)
(7 15 11 3)
(8 12 15 11)
patch solid1_right
(1 5 13 9)
patch solid3_right
(6 14 10 2)
patch solid2_right
(9 13 14 10)
patch frontAndBack
(4 5 13 12)
(13 14 15 12)
(15 14 6 7)
(0 1 9 8)
(9 10 11 8)
(11 10 2 3)
mergePatchPairs
I have also made three different folders of solid 1, 2, and 3 in constant directory (for defining physical properties) and system directories (for defining fvScheme and fvSolution).
blockMesh run successfully. Then I run
splitMeshRegions -cellZones -overwrite
It is showing following error after running above command:
Create time
Create mesh for time = 0
Trying to match regions to existing cell zones.
Number of regions:3
Writing region per cell file (for manual decomposition) to "/home/sangeeta/elasticThermalSolidFoam/constant/cellToRegion"
Writing region per cell as volScalarField to "/home/sangeeta/elasticThermalSolidFoam/0/cellToRegion"
Region Cells
0 400000
1 250000
2 250000
Region Zone Name
0 0 solid1
1 1 solid2
2 2 solid3
Sizes inbetween regions:
Region Region Faces
0 1 5000
1 2 5000
Reading volScalarField cellToRegion
Adding patches
Adding patches
Inserting patch solid1_to_solid2 to slot 7 out of 7
--> FOAM Warning :
From function gAverage(const UList<Type>&)
in file /home/sangeeta/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude/FieldFunctions.C at line 524
empty field, returning zero.
--> FOAM FATAL ERROR:
request for polyMesh solid2 from objectRegistry elasticThermalSolidFoam failed
available objects of type polyMesh are
1
region0
From function objectRegistry::lookupObject<Type>(const word&) const
in file /home/sangeeta/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 140.
FOAM aborting
Aborted
Does any one have any idea why this error is coming. How can I fix this problem?
Thanks in advance.
Best regards,
Sangeeta
