[Commercial meshers] VTK to Fluent mesh conversion
Old   November 10, 2012, 08:29
Question VTK to Fluent mesh conversion
Giles Richardson
ufocfd is on a distinguished road
Are there any OpenFOAM utilities for converting VTK file to Fluent (mesh) format ?
ufocfd is offline   Reply With Quote
Old   November 12, 2012, 17:02
Retired Super Moderator
Bruno Santos
Greetings ufocfd,
If your mesh is in OpenFOAM format, then you can convert it to either VTK or Fluent. But there is no utility in OpenFOAM (that I know of) that can import VTK to foam mesh format.
Best regards,
Bruno
conversion, fluent mesh, openfoam, vtk
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
Mesh Changing When Importing from Fluent russel60 OpenFOAM Running, Solving & CFD 0 February 15, 2019 16:43
Transfer of mesh from Meshing to Fluent destroys the mesh balrog_f FLUENT 9 July 28, 2018 10:02
[Commercial meshers] fluent mesh conversion to foam sangram OpenFOAM Meshing & Mesh Conversion 1 November 14, 2016 07:14
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 22:56
