November 16, 2012, 10:57 |
decomposePar corrupting mesh
AS
Rep Power: 16 |
Hi all,
I have a mesh which passes checkMesh serial no problems. However if I use decomposePar, and run checkMesh in parallel, it fails for the same mesh as follows: ==================== Face pyramids OK. ***Max skewness = 4.28888, 475 highly skew faces detected which may impair the quality of the results <<Writing 475 skew faces to set skewFaces Coupled point location match (average 2.60702e-16) OK. Failed 1 mesh checks. ==================== The number of skewed faces depends on the number of processors I use (with greater #processors seemingly corrupting the mesh more) My decomposeParDict: ==================== numberOfSubdomains $NSLOTS ; method scotch; preservePatches ( cyc_half0 cyc_half1 ); ==================== I have cyclic boundaries in spanwise direction (which are exactly the same on patch cyc_half0 and cyc_half1). Not sure if this could have an effect? Any suggestions? Thanks |
November 19, 2012, 08:25 |
#2 | |
AS
Rep Power: 16 |
Does anyone else see this happen at all? The mesh does seem to work OK, but it strikes me as odd that the cell quality should deteriorate by domain decomposition. decomposePar should not be affecting the coordinates of the mesh vertices, so this shouldn't happen...
Is this a bug? Quote:
November 19, 2012, 14:46 |
Chris L
Rep Power: 13 |
Try
preservePatches (cyc_half0); preservePatches (cyc_half1); preservePatches may only take 1 augment. I detailed my cyclic BC issues in the following thread: http://www.cfd-online.com/Forums/ope...esh-error.html |
November 20, 2012, 07:51 |
#4 | |
AS
Rep Power: 16 |
decomposepar checkmesh |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 17:16 |
[snappyHexMesh] SHM problem : KVLCC2 with appendage mesh | sc.park | OpenFOAM Meshing & Mesh Conversion | 1 | March 13, 2016 13:28 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 07:05 |
decomposePar: can use this decomposition method only for the whole mesh | aloeven | OpenFOAM Bugs | 0 | March 16, 2011 10:15 |
