-   OpenFOAM Meshing & Mesh Conversion (https://www.cfd-online.com/Forums/openfoam-meshing/)
-   -   [blockMesh] Inconsistent number of faces (https://www.cfd-online.com/Forums/openfoam-meshing/109787-inconsistent-number-faces.html)
hiasl November 26, 2012 19:25
I want to create a axisymmetric mesh consisting of a wedge-part with a block added on the outer side. I need this to get two different patches on one side, to be able to realize two velocityfields and two boundaryconditions there.
Can anyone give me advice? Thank you!
Create time
Creating block mesh from
    "/tmp/OpenFOAM/matthias-2.1.1/tutorials/incompressible/icoFoam/cavity/consta        nt/polyMesh/blockMeshDict"
Creating curved edges
Creating topology blocks
Creating topology patches
Creating block mesh topology
--> FOAM Warning :
    From function polyMesh::polyMesh(... construct from shapes...)
    in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 888
    Found 2 undefined faces in mesh; adding to default patch.
Check topology
        Basic statistics
                Number of internal faces : 2
                Number of boundary faces : 14
                Number of defined boundary faces : 14
                Number of undefined boundary faces : 0
        Checking patch -> block consistency
Creating block offsets
Creating merge list
--> FOAM FATAL ERROR:
Inconsistent number of faces between block pair 0 and 2
    From function blockMesh::calcMergeInfo()
    in file blockMesh/blockMeshMerge.C at line 221.
FOAM exiting
aljazari November 28, 2012 14:11
Create time
--> FOAM Warning :
Check topology
        Basic statistics
Creating merge list
FOAM exiting
Attach your blockMeshDict as well.
hiasl November 28, 2012 18:47
Thanks you for the answer!
In the meanwhile I solved the problem - it's all about the order of the vertices in the hex-blockdefinitions. Also you have to keep the same kind of order for every block, even the starting point of each patch (in the hex-def.) is important.
