Home > Forums > OpenFOAM Native Meshers: blockMesh
Can't find my mistake blockMeshDict
Old   February 19, 2013, 07:29
Default Can't find my mistake blockMeshDict
Jos E.
jelzinga is on a distinguished road
I'm trying to get started with OpenFOAM and using BlockMesh as a "first" mesher to get started.
My basic simulation would be 2 squares (cubicles) stacked on top of eachother, with the top face of the small cubicle being an air inlet and the bottom face of the big cubicle being an outlet.
I've defined the 16 vertices and the 2 hex blocks. Furthermore, I've tried to define the patches necessary (including a "mergePatchPairs") but the generated OpenFOAM mesh-files do not contain boundary-zones for the inlet and outlet (the top and bottom faces).
Ive copied/pasted my blockMeshDict to this post in the hopes someone can explain me what I'm doing wrong ...
|  \\    /   O peration     | Version:  1.7.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 0.001;
vertices
    (3 3 -3) //0
    (-3 3 -3) //1
    (-3 -3 -3) //2
    (3 -3 -3) //3
    (3 3 0) //4
    (-3 3 0) //5
    (-3 -3 0) //6
    (3 -3 0) //7
    (1 1 0) //8
    (-1 1 0) //9
    (-1 -1 0) //10
    (1 -1 0) //11
    (1 1 1) //12
    (-1 1 1) //13
    (-1 -1 1) //14
    (1 -1 1) //15
blocks
    hex (0 1 2 3 4 5 6 7) (19 19 19) simpleGrading (1 1 1)
    hex (8 9 10 11 12 13 14 15) (23 23 23) simpleGrading (1 1 1)
edges
patches
 patch vlak1
    ( 4 5 6 7)
 patch vlak2
    (8 9 10 11)
boundary
inlet
   type patch;
   faces
      (12 13 14 15)
 outlet
   type patch;
   faces
      (0 1 2 3)
 defaultFaces
   type patch;
   faces
      (0 4 7 3)
      (3 7 6 2)
      (1 5 6 2)
      (1 0 4 5)
      (8 12 15 11)
      (10 11 15 14)
      (10 9 13 14)
      (9 8 12 13)
      (4 5 6 7)
mergePatchPairs
(vlak2 vlak1) //merge1
thanks in forward
jelzinga is offline   Reply With Quote
Old   February 19, 2013, 08:10
startingWithCFD is on a distinguished road
-You can either have "patches" or "boundary", not both. "boundary" was ignored and therefore no inlet or outlet appeared.
-Be careful that the number of cells must be the same in neighbouring blocks. I corrected that for you.
-There was also an extra ); at the end.
vertices
    (3 3 -3) //0
    (-3 3 -3) //1
    (-3 -3 -3) //2
    (3 -3 -3) //3
    (3 3 0) //4
    (-3 3 0) //5
    (-3 -3 0) //6
    (3 -3 0) //7
    (1 1 0) //8
    (-1 1 0) //9
    (-1 -1 0) //10
    (1 -1 0) //11
    (1 1 1) //12
    (-1 1 1) //13
    (-1 -1 1) //14
    (1 -1 1) //15
blocks
    hex (0 1 2 3 4 5 6 7) (24 24 12) simpleGrading (1 1 1)
    hex (8 9 10 11 12 13 14 15) (8 8 4) simpleGrading (1 1 1)
edges
boundary
    inlet
        type patch;
        faces
            (12 13 14 15)
    vlak1
        type patch;
        faces
            ( 4 5 6 7)
    vlak2
        type patch;
        faces
            (8 9 10 11)
    outlet
        type patch;
        faces
            (0 1 2 3)
mergePatchPairs
startingWithCFD is offline   Reply With Quote
Old   February 19, 2013, 08:30
Jos E.
Thanks for the quick help. I was not aware you could not have both, so learned already something
When I copied your code over my file (after making a backup) I get the following error when I run blockMesh in the case directory:
--> FOAM FATAL IO ERROR:
ill defined primitiveEntry starting at keyword 'boundary' on line 52 and ending at line 101
file: /home/openfoam/Jos2013/GS_proposal/constant/polyMesh/blockMeshDict at line 101.
    From function primitiveEntry::readEntry(const dictionary&, Istream&)
    in file db/dictionary/primitiveEntry/primitiveEntryIO.C at line 214.
FOAM exiting
I must admit I run OpenFOAM 1.7.0 because that was bundled with the OpenCAE Linux version I downloaded, does that matter? Did the syntax change compared to the newer version and perhaps I should consider upgrading ?
Old   February 19, 2013, 10:12
Sorry, I missed a } at the end of outlet during the copy-paste stage.
I wanted to attach the file itself but the forum rules did not allow that.
It must be working like this, right?
Old   February 19, 2013, 10:22
Jos E.
Thanks for the heads-up. In the meantime I took the effort to install OpenFOAM 2.1 to exclude this as a possible problem-point later on.
I've edited the file accordingly and this seems to indeed add the boundaries required, thanks!
I'm pretty sure I run into a new problem later on, but thanks alot for now !
Old   March 18, 2015, 06:48
Default ill defined primitiveEntry starting at keyword 'blocks'
Diana
diananilminikumari is on a distinguished road
I was trying to define cylinder mesh,and When run the blockMesh I have get the error ,
"ill defined primitiveEntry starting at keyword 'blocks' on line 53 and ending at line 149"
file: /home/diana/OpenFOAM/diana-2.3.0/run/tutorials/heatTransfer/buoyantSimpleFoam/hotcylinder/constant/polyMesh/blockMeshDict at line 149.
in file lnInclude/IOerror.C at line 132.
Here is my blockMesh file .Please kind to help me to find the error
| \\ / O peration | Version: 2.3.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
FoamFile
version 2.0;
format ascii;
class dictionary;
convertToMeters 1;
vertices
(0 0 0)//0
(0.02 0 0)//1
(0 0.02 0)//2
(0 0 0.5)//3
(0.02 0 0.5)//4
(0 0.02 0.5)//5
(0 0 1)//6
(0.02 0 1)//7
(0 0.02 1)//8
(-0.02 0 0)
(-0.02 0 0.5)
(-0.02 0 1)
(0 -0.02 0)
(0 -0.02 0.5)
(0 -0.02 1)
(0.05 0 0)
(0 0.05 0)
(0.05 0 0.5)
(0 0.05 0.5)
(0.05 0 1)
(0 0.05 1)
(-0.05 0 0)
(-0.05 0 0.5)
(-0.05 0 1)
(0 -0.05 0)
(0 -0.05 0.5)
(0 -0.05 1)
blocks
hex(0 0 1 2 3 3 4 5) (2 2 10) simpleGrading (1 1 1)
hex(3 3 5 4 6 6 7 8) (2 2 10) simpleGrading (1 1 1)
hex(0 0 2 9 3 3 5 10) (2 2 10) simpleGrading (1 1 1)
hex(3 3 5 10 6 6 8 11) (2 2 10) simpleGrading (1 1 1)
hex(0 0 9 12 3 3 10 13) (2 2 10) simpleGrading (1 1 1)
hex(3 3 10 13 6 6 11 14) (2 2 10) simpleGrading (1 1 1)
hex(0 0 12 1 3 3 13 4) (2 2 10) simpleGrading (1 1 1)
hex(3 3 13 4 6 6 14 7) (2 2 10) simpleGrading (1 1 1)
hex(1 15 16 2 4 17 18 5) (3 3 10) simpleGrading (1 1 1)
hex(4 17 18 5 7 19 20 8) (3 3 10) simpleGrading (1 1 1)
hex(2 16 21 9 5 18 22 10) (3 3 10) simpleGrading (1 1 1)
hex(5 18 22 10 8 20 23 11) (3 3 10) simpleGrading (1 1 1)
hex(9 21 24 12 10 22 25 13) (3 3 10) simpleGrading (1 1 1)
hex(10 22 25 13 11 23 26 14) (3 3 10) simpleGrading (1 1 1)
hex(12 24 15 1 13 25 17 4) (3 3 10) simpleGrading (1 1 1)
hex(13 25 17 4 14 26 19 7) (3 3 10) simpleGrading (1 1 1)
edges
arc 1 2 (0.01 0.0173205080756888 0)
arc 4 5 (0.01 0.0173205080756888 0.5)
arc 7 8 (0.01 0.0173205080756888 1)
arc 2 9 (-0.01 0.0173205080756888 0)
arc 5 10 (-0.01 0.0173205080756888 0.5)
arc 8 11 (-0.01 0.0173205080756888 1)
arc 9 12 (-0.0173205080756888 -0.01 0)
arc 10 13 (-0.0173205080756888 -0.01 0.5)
arc 11 14 (-0.0173205080756888 -0.01 1)
arc 10 1 (0.03 0.04 0)
arc 13 4 (0.03 0.04 0.5)
arc 14 7 (0.03 0.04 1)
boundary
uppipewall
type wall;
faces
(15 16 18 17)
(17 18 20 19)
(16 21 22 18)
(18 22 23 20)
downpipewall
type wall;
faces
(24 15 25 17)
(17 25 26 19)
(24 21 22 25)
(25 22 23 26)
inflow
type patch;
faces
(0 2 1 0)
(1 2 16 15)
(0 9 2 0)
(9 21 16 2)
(0 12 9 0)
(12 24 21 9)
(0 1 12 0)
(1 15 24 12)
outflow
type patch;
faces
(6 8 7 6)
(8 20 19 7)
(6 11 8 6)
(11 23 20 8)
(6 14 11 6)
(14 26 23 11)
(6 7 14 6)
(7 19 26 14)
mergePatchPairs
diananilminikumari is offline   Reply With Quote
Old   March 18, 2015, 07:07
Alexey Matveichev
alexeym will become famous soon enoughalexeym will become famous soon enough
1. There should be space between hex and vertices vector
2. There should be semicolon in the end of faces vector of vector in patch definition
Though after these two minor corrections you will encounter problems with hex vertices numbering:
Creating block mesh topology
--> FOAM Warning :
    From function cellModel::mag(const labelList&, const pointField&)
    in file meshes/meshShapes/cellModel/cellModel.C at line 128
    zero or negative pyramid volume: -1.66667e-05 for face 4
and
--> FOAM FATAL ERROR:
face 0 in patch 1 does not have neighbour cell face: 4(24 15 25 17)
Next time when posting blockMeshDict (or any other dictionary) on the forum, please, use CODE tag or just attach compressed file.
alexeym is offline   Reply With Quote
Old   March 18, 2015, 07:13
Bernhard Linseisen
Linse is on a distinguished road
Just a short note: Try to put a space between the "hex" and the brackets... Should help for part of the problem already...
Linse is offline   Reply With Quote
Old   March 19, 2015, 02:08
Diana
Thank you very much for your information.
I have got the mesh
Thread Tools
Trackbacks are On
Looking for SUBOFF model but i can't find it. Heewon Lee Main CFD Forum 6 September 9, 2014 08:55
OpenFoam171: error /usr/bin/ld: cannot find -llduSolvers Schipper OpenFOAM Programming & Development 5 November 15, 2012 15:13
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 13:38
Problem Building OF on Centos cluster (no admin rights) CKH OpenFOAM Installation 5 November 13, 2011 07:32
YPlus nowhere to be find Daniel CFX 3 May 1, 2006 16:22
