Problem with mesh. non closed cells.
5 Attachment(s)
I have a problem with my mesh. Please help me. What's wrong??
Here i attach some pictures to describe the problem. Domain is a cylinder that consists of 5 hexa-blocks. Non closed cells appears on front and back surfaces of central block. Here is blockMeshDict: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 2.53e-02; vertices ( (0 0.31496063 0) //0 (1.423423083 0.31496063 0) //1 (1.423423083 0.393700787 0) //2 (0 0.393700787 0) //3 (0 0.787401575 -0.472440945) //4 (1.423423083 0.787401575 -0.472440945) //5 (1.423423083 0.787401575 -0.393700787) //6 (0 0.787401575 -0.393700787) //7 (1.423423083 1.25984252 0) //8 (0 1.25984252 0) //9 (0 1.181102362 0) //10 (1.423423083 1.181102362 0) //11 (0 0.787401575 0.3937007) //12 (1.423423083 0.787401575 0.393700787) //13 (0 0.787401575 0.472440945) //14 (1.423423083 0.787401575 0.472440945) //15 ); blocks ( hex (0 1 2 3 4 5 6 7) (25 25 25) simpleGrading (1.0 1.0 1.0) hex (4 5 6 7 9 8 11 10) (25 25 25) simpleGrading (1.0 1.0 1.0) hex (9 8 11 10 14 15 13 12) (25 25 25) simpleGrading (1.0 1.0 1.0) hex (14 15 13 12 0 1 2 3) (25 25 25) simpleGrading (1.0 1.0 1.0) hex (3 2 6 7 12 13 11 10) (25 25 25) simpleGrading (1.0 1.0 1.0) ); edges ( arc 0 4 (0 0.551181102 -0.40914586) arc 1 5 (1.423423083 0.551181102 -0.40914586) arc 4 9 (0 1.023622047 -0.40914586) arc 5 8 (1.423423083 1.023622047 -0.40914586) arc 9 14 (0 1.023622047 0.40914586) arc 8 15 (1.423423083 1.023622047 0.40914586) arc 14 0 (0 0.551181102 0.40914586952) arc 15 1 (1.423423083 0.551181102 0.40914586952) ); boundary ( inlet { type patch; faces ( (0 4 7 3) (4 9 10 7) (9 14 12 10) (14 0 3 12) (3 7 10 12) ); } wall { type wall; faces ( (0 1 5 4) (4 5 8 9 ) (9 8 15 14) (14 15 1 0) ); } outlet { type patch; faces ( (1 5 6 2) (5 8 11 6) (8 15 13 11) (15 1 2 13) (2 6 11 13) ); } ); mergePatchPairs ( ); // ************************************************** *********************** // And checkMesh feedback: /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.0.1-51f1de99a4bc Exec : checkMesh Date : Apr 03 2013 Time : 00:42:07 Host : ************ PID : 3167 Case : ************ nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 82576 faces: 238750 internal faces: 230000 cells: 78125 boundary patches: 3 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 78125 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces ... Patch Faces Points Surface topology inlet 3125 3176 ok (non-closed singly connected) wall 2500 2600 ok (non-closed singly connected) outlet 3125 3176 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (0 0.0079685 -0.0119528) (0.0360126 0.031874 0.0119528) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (1.2176e-08 -6.48171e-16 -1.31418e-16) OK. ***Open cells found, max cell openness: 1, number of open cells 2400 <<Writing 2400 non closed cells to set nonClosedCells <<Writing 62500 cells with high aspect ratio to set highAspectRatioCells Minumum face area = 3.81022e-08. Maximum face area = 1.08166e-06. Face area magnitudes OK. Min volume = 2e-300. Max volume = 4.57339e-10. Total volume = 6.95536e-06. Cell volumes OK. #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib/libc.so.6" #3 in "/lib/libm.so.6" #4 acos in "/lib/libm.so.6" #5 Foam::primitiveMesh::checkFaceOrthogonality(bool, Foam::HashSet<int, Foam::Hash<int> >*) const in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #6 in "/opt/openfoam201/platforms/linux64GccDPOpt/bin/checkMesh" #7 in "/opt/openfoam201/platforms/linux64GccDPOpt/bin/checkMesh" #8 __libc_start_main in "/lib/libc.so.6" #9 in "/opt/openfoam201/platforms/linux64GccDPOpt/bin/checkMesh" Floating point exception Thanks in advance!:) http://www.fotolink.su/v.php?id=5dd0...b42f1685171403http://www.fotolink.su/v.php?id=c21a...fb10a84a657925http://www.fotolink.su/v.php?id=3635...a65b3c42420b46http://www.fotolink.su/v.php?id=918b...8409bbcff4126f |
Already solved this problem.
It turned out that the important role played by the ordering of the vertices of the blocks. The first block is specified coordinate system grid: 0 1 is the X-axis, 1 2 is the Y-axis, and this axis is 0 4 is the Z-axis. All other units must be located in these coordinates as much as possible. Sorry for my bad english :). |
