[blockMesh] Problem with mesh. non closed cells.
Old   April 2, 2013, 14:06
Smile Problem with mesh. non closed cells.
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
I have a problem with my mesh. Please help me. What's wrong??
Here i attach some pictures to describe the problem.
Domain is a cylinder that consists of 5 hexa-blocks. Non closed cells appears on front and back surfaces of central block.
Here is blockMeshDict:
| \\ / O peration | Version: 2.0.1 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 2.53e-02;
vertices
(0 0.31496063 0) //0
(1.423423083 0.31496063 0) //1
(1.423423083 0.393700787 0) //2
(0 0.393700787 0) //3
(0 0.787401575 -0.472440945) //4
(1.423423083 0.787401575 -0.472440945) //5
(1.423423083 0.787401575 -0.393700787) //6
(0 0.787401575 -0.393700787) //7
(1.423423083 1.25984252 0) //8
(0 1.25984252 0) //9
(0 1.181102362 0) //10
(1.423423083 1.181102362 0) //11
(0 0.787401575 0.3937007) //12
(1.423423083 0.787401575 0.393700787) //13
(0 0.787401575 0.472440945) //14
(1.423423083 0.787401575 0.472440945) //15
blocks
hex (0 1 2 3 4 5 6 7)
(25 25 25)
simpleGrading (1.0 1.0 1.0)
hex (4 5 6 7 9 8 11 10)
(25 25 25)
hex (9 8 11 10 14 15 13 12)
(25 25 25)
hex (14 15 13 12 0 1 2 3)
(25 25 25)
hex (3 2 6 7 12 13 11 10)
(25 25 25)
edges
arc 0 4 (0 0.551181102 -0.40914586)
arc 1 5 (1.423423083 0.551181102 -0.40914586)
arc 4 9 (0 1.023622047 -0.40914586)
arc 5 8 (1.423423083 1.023622047 -0.40914586)
arc 9 14 (0 1.023622047 0.40914586)
arc 8 15 (1.423423083 1.023622047 0.40914586)
arc 14 0 (0 0.551181102 0.40914586952)
arc 15 1 (1.423423083 0.551181102 0.40914586952)
boundary
inlet
type patch;
faces
(0 4 7 3)
(4 9 10 7)
(9 14 12 10)
(14 0 3 12)
(3 7 10 12)
wall
type wall;
faces
(0 1 5 4)
(4 5 8 9 )
(9 8 15 14)
(14 15 1 0)
outlet
type patch;
faces
(1 5 6 2)
(5 8 11 6)
(8 15 13 11)
(15 1 2 13)
(2 6 11 13)
mergePatchPairs
And checkMesh feedback:
Build : 2.0.1-51f1de99a4bc
Exec : checkMesh
Date : Apr 03 2013
Time : 00:42:07
Host : ************
PID : 3167
Case : ************
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
faces: 238750
internal faces: 230000
cells: 78125
boundary patches: 3
point zones: 0
face zones: 0
cell zones: 0
Overall number of cells of each type:
hexahedra: 78125
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 0
polyhedra: 0
Checking topology...
Boundary definition OK.
Cell to face addressing OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
Patch Faces Points Surface topology
inlet 3125 3176 ok (non-closed singly connected)
wall 2500 2600 ok (non-closed singly connected)
outlet 3125 3176 ok (non-closed singly connected)
Checking geometry...
Overall domain bounding box (0 0.0079685 -0.0119528) (0.0360126 0.031874 0.0119528)
Mesh (non-empty, non-wedge) directions (1 1 1)
Mesh (non-empty) directions (1 1 1)
Boundary openness (1.2176e-08 -6.48171e-16 -1.31418e-16) OK.
***Open cells found, max cell openness: 1, number of open cells 2400
<<Writing 2400 non closed cells to set nonClosedCells
<<Writing 62500 cells with high aspect ratio to set highAspectRatioCells
Minumum face area = 3.81022e-08. Maximum face area = 1.08166e-06. Face area magnitudes OK.
Min volume = 2e-300. Max volume = 4.57339e-10. Total volume = 6.95536e-06. Cell volumes OK.
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib/libc.so.6"
#3 in "/lib/libm.so.6"
#4 acos in "/lib/libm.so.6"
#5 Foam:rimitiveMesh::checkFaceOrthogonality(bool, Foam::HashSet<int, Foam::Hash<int> >*) const in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
in "/opt/openfoam201/platforms/linux64GccDPOpt/bin/checkMesh"
#8 __libc_start_main in "/lib/libc.so.6"
Floating point exception
Thanks in advance!
AlexanderZ is offline   Reply With Quote
Old   April 3, 2013, 09:44
Alexander
Already solved this problem.
It turned out that the important role played by the ordering of the vertices of the blocks.
The first block is specified coordinate system grid: 0 1 is the X-axis, 1 2 is the Y-axis, and this axis is 0 4 is the Z-axis. All other units must be located in these coordinates as much as possible.
Sorry for my bad english .
non closed cells
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 07:34
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
[ICEM] Problem making structured mesh on a surface froztbear ANSYS Meshing & Geometry 4 November 10, 2011 08:52
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
