Home > Forums > OpenFOAM Native Meshers: blockMesh
OpenFoam blockMesh: reference internal block interface
Like Tree2Likes
  • 2 Post By panpanzhong
Old   July 8, 2013, 13:12
Default OpenFoam blockMesh: reference internal block interface
Peng Zhong
panpanzhong is on a distinguished road
Dear OpenFoam users,
I am interested in naming an internal interface so I can reference it by that name in a source code. The problem is that internal interface is not a boundary face and it is a face formed by touching interface of 2 blocks created in blockMesh. So my question is, while we can name a normal boundary face, is there a way we can name internal block interface? Thanks.
Peng,
panpanzhong is offline   Reply With Quote
Old   July 10, 2013, 05:13
Artur's Avatar
Artur
Artur is on a distinguished road
Depending on what you need it for, you could use faceZones or faceSets. Have a look at the propeller tutorial in pimpleDyMFoam folder where this approach is used for setting up an arbitrary mesh interface (AMI) for a rotating geometry.
More precisely, you should look at the topoSet dictionaries and createPatchDict.
Artur is offline   Reply With Quote
Old   July 10, 2013, 22:20
Peng Zhong
Thanks.
I figured it out. The patch type is cyclicAMI which can be defined in blockMesh as follows
side1
type cyclicAMI;
neighborPatch side2;
faces
(1 2 3 4)
side2
type cyclicAMI;
neighborPatch side1;
faces
(8 7 6 5)
where side1 and side2 are faces formed by the 2 mesh regions' interface. There orientation is opposite from each other. Vertex 1 has exact same coordinate as vertex 5, Vertex 2 has exact same coordinate as Vertex 6 ...
The initial boundary condition for side1 and side2 is:
boundaryFields
side1
type cyclicAMI;
side2
type cyclicAMI;
These boundary condition being "type cyclicAMI" will tell the solver that fielsd from side1 should progagate across side2.
Artur and crixman like this.
Thread Tools
Trackbacks are On
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 06:55
Compiling new Solver with wmake lin123 OpenFOAM 3 April 13, 2010 14:18
Icem Mesh to Foam jphandrigan OpenFOAM Mesh Utilities 4 March 9, 2010 03:58
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 10:38
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
