[blockMesh] blockMesh for 20M grids, stuck forever?
Like Tree3Likes
  • 3 Post By nimasam
Old   August 13, 2013, 16:41
Post blockMesh for 20M grids, stuck forever?
Jack
ripperjack is on a distinguished road
Hi guys,
I want to generate mesh with 20 million grid points using blockMesh. However, I tried for many times and I failed. I uses blockMesh and now it has taken for more than 5 hours, and the mesh is not successfully generated, I am still waiting..... Could you guys tell me is there a better way to generate big mesh using blockMesh? Thanks!
ripperjack is offline   Reply With Quote
Old   August 14, 2013, 01:14
Nima Samkhaniani
nimasam is on a distinguished road
well you may want to generate your mesh with coarser mesh, then using refineHexMesh or refineMesh, to make it refine to the level you want
fabian_roesler, ripperjack and mgg like this.
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   August 21, 2013, 10:58
Kent Wardle
kwardle is on a distinguished road
refineHexMesh can also be run in parallel, so you could make a mesh with blockMesh, decomposePar, and then refine in parallel to your desired level.
kwardle is offline   Reply With Quote
Old   August 21, 2013, 11:36
Bernhard
Bernhard is on a distinguished road
How much RAM memory do you got on your machine? Probably blockMesh is eating everything, and evading to some swap-memory, which makes it terribly slow. If this is the case, try running on a machine with more RAM.
Bernhard is offline   Reply With Quote
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
Does the grids topology matters? Anna Tian Main CFD Forum 11 August 19, 2014 02:20
[blockMesh] tutorial 2.2 Stress(...) trouble with blockMesh colinB OpenFOAM Meshing & Mesh Conversion 8 January 22, 2012 10:32
How to generate tetrahedral/hybrid grids by blockmesh Tarak OpenFOAM 1 November 5, 2010 03:25
How to generate tetrahedral/hybrid grids by blockmesh Tarak OpenFOAM 0 October 4, 2010 15:00
