-   OpenFOAM Native Meshers: blockMesh (http://www.cfd-online.com/Forums/openfoam-meshing-blockmesh/)
-   -   Create time fileName::stripInvalid() called for invalid fileName UbuntuOne For d (http://www.cfd-online.com/Forums/openfoam-meshing-blockmesh/123622-create-time-filename-stripinvalid-called-invalid-filename-ubuntuone-d.html)
tobimorak September 17, 2013 09:08
I got this error mesh after typing blockMesh, Can anyone help on how to solve this? I am a new user ..please help . here is d error message
| \\ / O peration | Version: 2.2.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.2.1-57f3c3617a2d
Exec : blockMesh
Date : Sep 17 2013
Time : 21:00:42
Host : "tobie-Vostro-2521"
PID : 2402
Case : /home/tobie
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
For debug level (= 2) > 1 this is considered fatal
Aborted (core dumped)
wouter September 26, 2013 17:45
helo tobimorak,
You probably figured it out already. Openfoam does not like certain filenames in the case directory. In this case probably 'Ubuntu One' with a space.
Hope this helps
Wouter
tobimorak September 26, 2013 19:36
Thank You...I will try again
