[blockMesh] mesh of tube
Old   October 6, 2013, 12:59
Default mesh of tube
Ahmed Khattab's Avatar
ahmed
Ahmed Khattab is on a distinguished road
Dear Foamers,
I'd like to make mesh of tube with length 1 m and diameter 20 cm and thickness of 1 cm. anyone have an idea how blockMeshDict would like??
thanks in advance.
Ahmed Khattab is offline   Reply With Quote
Old   October 6, 2013, 13:58
Retired Super Moderator
Bruno Santos
Quick question: Have you already searched here on the forum, namely in the sub-forum "blockMesh"? OpenFOAM Native Meshers: blockMesh
Old   October 7, 2013, 06:56
ahmed
Dear wyldckat,
yes i searches a lot for it. i found my way to do it. but I'm searching now for better or easier ideas. I'll share my mesh in another post or may be in a blog. because a tube must be done from cylinder then split it to solid part and flow part as my way.
thanks for your reply
Old   November 13, 2013, 03:05
skyinventorbt's Avatar
Dr. B T KANNAN
skyinventorbt is on a distinguished road
Originally Posted by Ahmed Khattab View Post
Dear wyldckat,
Four quarter domains with thickened arcs above that will work.
Quarter domains for pipe and arcs for pipe thickness.
KANNAN
Dr. B T KANNAN, PhD, M.I.E,
PhD in Aerodynamics (CFD|Turbulence|Experiments)
Alumnus of Indian Institute of Technology - Madras.
skyinventorbt is offline   Reply With Quote
Old   January 6, 2014, 12:44
ahmed
KANNAN
Dear Kannan,
i think i didn't catch your idea, could you please send me example for this mesh.
BR,
Ahmed
Old   January 7, 2014, 00:17
Default blockMesh example
Dr. B T KANNAN
Dear Kannan,
BR,
Ahmed
Dear Ahmed,
You refer to User guide for making wedge type mesh and your domain in to two blocks as shown in the attachment.
Also refer this code for axisymmetric pipe (Just for example) using single cell thickness. For multi cell, use curved surfaces defined by arc.
Note: Create your own vertices(Use paraFoam block to understand the positioning)
vertices
    (0 0 0)                          //0
    (0 0.6 0.020943951)              //1
    (0 0.6 -0.020943951)             //2
    (30 0 0)                        //3
    (30 0.6 0.020943951)            //4
    (30 0.6 -0.020943951)           //5
    (0 180 6.283185307)             //6
    (30 180 6.283185307)           //7
    (30 180 -6.283185307)          //8
    (0 180 -6.283185307)          //9
blocks
    hex (0 3 3 0 1 4 5 2) (15 1 5) simpleGrading (4 1 1)
    hex (1 4 5 2 6 7 8 9) (15 1 9) simpleGrading (4 1 5)
KANNAN B T
[snappyHexMesh] Snappyhex mesh: poor inlet mesh Swagga5aur OpenFOAM Meshing & Mesh Conversion 1 December 3, 2016 16:59
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 07:05
[ANSYS Meshing] Meshing Strategy for inside geometry powpow ANSYS Meshing & Geometry 6 January 16, 2013 04:32
