[blockMesh] blockMesh "Number of edges not aligned with or perpendicular to non-empty direction"
Like Tree4Likes
  • 1 Post By DuarteMagalhaes
  • 3 Post By alexeym
Old   April 24, 2014, 10:56
Default blockMesh "Number of edges not aligned with or perpendicular to non-empty direction"
Duarte Magalhães
DuarteMagalhaes is on a distinguished road
Hi, can anyone help me on this?
When i run checkMesh i get the following error message:
Wedge axi_symm-r with angle 2.5 degrees
***Number of edges not aligned with or perpendicular to non-empty directions: 9360
<<Writing 5746 points on non-aligned edges to set nonAlignedEdges
Failed 1 mesh checks.
My blockMeshDict file is:
convertToMeters 1;
vertices
(0 0 0) //0
(0.0000436193873653360 0.000999048221581858 0) //1
(-0.0000436193873653360 0.000999048221581858 0) //2
(0.00218096936826680 0.0499524110790929 0) //3
(-0.00218096936826680 0.0499524110790929 0) //4
(0 0 0.2) //5
(0.0000436193873653360 0.000999048221581858 0.2) //6
(-0.0000436193873653360 0.000999048221581858 0.2) //7
(0.00218096936826680 0.0499524110790929 0.2) //8
(-0.00218096936826680 0.0499524110790929 0.2) //9
blocks
hex (0 5 5 0 2 7 6 1) (25 10 5) simpleGrading (1 1 1)
hex (1 3 4 2 6 8 9 7) (15 10 25) simpleGrading (1 1 1)
edges
arc 2 1 (0 0.001 0)
arc 7 6 (0 0.001 0.2)
arc 4 3 (0 0.05 0)
arc 9 8 (0 0.05 0.2)
patches
patch
inlet_center_tube
(0 2 1 0)
patch
outlet
(5 7 6 5)
(7 6 8 9)
patch
inlet_co_flow
(1 2 4 3)
wedge
axi_symm-f
(0 5 7 2)
(2 7 9 4)
wedge
axi_symm-r
(0 5 6 1)
(1 6 8 3)
wall
wall
(4 9 8 3)
mergePatchPairs
I have checked and the numbering of my patches seems to be correct. I'm doing a one layer thick wedge mesh.
If anyone has any clue or hint, please let me know!
Thanks in advance!
djdudns likes this.
DuarteMagalhaes is offline   Reply With Quote
Old   April 24, 2014, 11:33
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
in general this message means you forgot to describe certain patches in blockMeshDict (so face of these patches went to empty patch with the name defaultFaces and checkMesh is not happy about it).
Tobi, Marpole and Chaoran like this.
alexeym is offline   Reply With Quote
Old   April 28, 2014, 06:09
Duarte Magalhães
Originally Posted by alexeym View Post
Hi Alexey,
Indeed, when i run blockMesh, it creates a patch named defaultFaces:
"patch 6 (start: 15700 size: 0) name: defaultFaces". However, this happens because it creates the interface between my two blocks (central tube and annular region), and since it is not a boundary of the main domain, I cannot set this interface as a patch. Do you know how can i define it in blockMeshDict, so that blockMesh knows that it is a simple interface between two blocks?
Thanks for your help!
Old   April 28, 2014, 09:00
Alexey Matveichev
you should define two patches in these two blocks, and then use mergePatchPairs in blockMeshDict to merger patches. Otherwise you'll have defaultFaces empty type patch between blocks and result won't be as you expect.
Though it's just a guess from what you've written in the previous message. Maybe if you describe the problem in more details someone will be able to propose more convenient way to create a mesh for you case.
Old   April 28, 2014, 12:48
Default checkMesh error, centre flow + annular flow
Duarte Magalhães
Thank you for your reply!
I have been reading about face matching and face merging, and apparently OpenFoam says that "To connect two blocks with face matching, the two patches that form the connection should simply be ignored from the patches list. blockMesh then identifies that the faces do not form an external boundary and combines each collocated pair into a single internal faces that connects cells from the two blocks."
This is what i am doing and for this reason he is creating the defaultFaces patch (empty patch).
To describe my problem more thoroughly, I have followed this tutorial: http://www.somogyibence.hu/documents.../Cornell1.html , and afterwards, changed the geometry to insert a central tube, transforming the remaining flow in an annular co-flow.
I do believe the problem is in the interface of these two blocks, centre tube and annular region, however, I am not being able to fix the error that checkMesh reports, which is the following:
Checking geometry...
Overall domain bounding box (-0.00218097 0 0) (0.00218097 0.0499524 0.2)
Mesh (non-empty, non-wedge) directions (0 1 1)
Wedge axi_symm-f with angle 2.5 degrees
***Number of edges not aligned with or perpendicular to non-empty directions: 4160
<<Writing 4186 points on non-aligned edges to set nonAlignedEdges
Boundary openness (-5.30238e-15 -1.60247e-16 6.32555e-19) OK.
Max cell openness = 3.67795e-16 OK.
Max aspect ratio = 400.381 OK.
Minimum face area = 1.74311e-10. Maximum face area = 2.61333e-05. Face area magnitudes OK.
Min volume = 1.39449e-12. Max volume = 1.10163e-08. Total volume = 2.17889e-05. Cell volumes OK.
Mesh non-orthogonality Max: 2.25027 average: 1.10984
Non-orthogonality check OK.
Face pyramids OK.
Max skewness = 0.333333 OK.
Coupled point location match (average 0) OK.
End
Can anyone help me on this?
Thanks in advance!
Old   April 28, 2014, 13:06
Alexey Matveichev
checked the tutorial, still can't get what changes did you do to the tutorial mesh. Post your case files, this way it'll be simpler.
Yes, there is face matching algorithm which can merge faces automatically but there are also certain conditions for this algorithm to work.
Old   April 28, 2014, 14:27
Duarte Magalhães
I am trying to create a domain with inlet: central tube with annular co-flow. In the rest of the domain, this central tube no longer exists, only exists the wall that now contains both the flow entering from the central tube, and the annular co flow.
My blockMeshDict file:
convertToMeters 1;
vertices
(0 0 0) //0
(0 0 0.2) //5
blocks
edges
arc 2 1 (0 0.001 0)
arc 4 3 (0 0.05 0)
patches
patch
inlet_center_tube
(0 2 1 0)
patch
outlet
(5 7 6 5)
(7 6 8 9)
patch
inlet_co_flow
(1 2 4 3)
wedge
axi_symm-f
(0 5 7 2)
(2 7 9 4)
wedge
axi_symm-r
(0 5 6 1)
(1 6 8 3)
wall
wall
(4 9 8 3)
mergePatchPairs
My velocity BC's are:
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet_center_tube
type fixedValue;
value uniform (0 0 0.7);
outlet
type zeroGradient;
inlet_co_flow
type fixedValue;
value uniform (0 0 0.2);
wall
type fixedValue;
value uniform (0 0 0);
axi_symm-f
type wedge;
axi_symm-r
type wedge;
Thank you so much for your help!
Old   May 5, 2014, 11:04
Duarte Magalhães
I was able to fix the problem by changing my mesh and also by using mergePatchPairs.
Thanks for your help Alexey!
Old   April 6, 2018, 07:21
Luís Tiago Ferreira Fernandes
ltiago94 is on a distinguished road
Hello ,
I'm also having this problem, what did you exactly do to solve this error?
Thanks
Luís
ltiago94 is offline   Reply With Quote
Old   July 2, 2018, 01:04
Default edges not aligned with or perpendicular to non-empty directions
Ainal Hoque Gazi
A H Gazi is on a distinguished road
Hello
I have made a mesh in blockMeshDict which is working good.but when i changed the Z co ordinate to increase the height of the geometry it is showing the following error in checkMesh.....for example i have changed (0.5 0 -.5) ; (0.5 0 .5) to (0.5 0 -4) ; (0.5 0 4).....please can you help me, i don't get a solution, i cant find the error .
Overall domain bounding box (-0.05 -0.05 0) (0.05 0.05 1)
Mesh (non-empty, non-wedge) directions (0 0 0)
Mesh (non-empty) directions (0 0 0)
***Number of edges not aligned with or perpendicular to non-empty directions: 2700
<<Writing 1652 points on non-aligned edges to set nonAlignedEdges
Boundary openness (1.8035e-16 4.9005e-17 5.2265e-18) OK.
***Open cells found, max cell openness: 1, number of open cells 40
<<Writing 40 non closed cells to set nonClosedCells
***Zero or negative face area detected. Minimum area: 0
<<Writing 2 zero area faces to set zeroAreaFaces
***Zero or negative cell volume detected. Minimum negative volume: -4.8531e-06, Number of negative volume cells: 161
<<Writing 161 zero volume cells to set zeroVolumeCells
Mesh non-orthogonality Max: 180 average: 43.969
*Number of severely non-orthogonal (> 70 degrees) faces: 26.
***Number of non-orthogonality errors: 324.
<<Writing 350 non-orthogonal faces to set nonOrthoFaces
***Error in face pyramids: 950 faces are incorrectly oriented.
<<Writing 653 faces with incorrect orientation to set wrongOrientedFaces
***Max skewness = 23.18, 2 highly skew faces detected which may impair the quality of the results
<<Writing 2 skew faces to set skewFaces
Failed 7 mesh checks.
Thanks in advance.
A H Gazi is offline   Reply With Quote
[mesh manipulation] Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Meshing & Mesh Conversion 42 January 8, 2017 12:55
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 15:03
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 10:37
