June 9, 2014, 12:35 |
snappyHexMesh running
Rep Power: 11 |
I'm trying to solve cfd problem using snappyHexMesh. The program works quite well but only for the mesh and it stops then. I don't find any internet help to find out what is the problem. The problem seems to come from the running file. What is the best runApplication to make it works. I've tried some like : runApplication snappyHexMesh runApplication snappyHexMesh -overwrite runApplication decomposePar runApplication foamJob -parallel -screen snappyHexMesh runApplication reconstructParMesh -latestTime Has any body have ever had such a problem? Could you help me for it? Cheers |
June 9, 2014, 14:29 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings lguillem and welcome to the forum!
There is a very simple reason why snappyHexMesh doesn't work as a solver: it's only a mesher!! For more information about snappyHexMesh, have a look here: http://openfoamwiki.net/index.php/SnappyHexMesh Best regards, Bruno
June 10, 2014, 05:47 |
Rep Power: 11 |
Hi Bruno,
Thank you for your answer, but there is something I don't understand. When I don't put the snapptHexMeshDict in the system file and when I run the code, calculations are made. I mean I have folders which are created (0, 0.1, 0.2...). And when I put the snappyHexMeshDict in the system file and when I put "runApplication snappyHexMesh" in the "Allrun", those folders doesn't appear. Would you know why ? Thanks again for your answer. Cheers, Louise. |
June 10, 2014, 10:54 |
Rep Power: 11 |
In fact snappyHexMesh create the folder 0.01 0.02 and 0.03.
And then, interDymFoam is not able to calculate because it doesn't find the 0 folder. How can I resolve this problem ? Cheers, Louise. |
June 10, 2014, 10:59 |
Bruno Santos
Rep Power: 128 |
Hi Louise,
You're not looking at the bigger picture. From your description, my guess is that when you don't use snappyHexMesh, you still have the base mesh that was created with blockMesh. Therefore, there is a mesh available and the solver might be able to run with it. But when you run snappyHexMesh, the resulting mesh is of very poor quality and the solver crashes soon enough. Whenever you use the function "runApplication" in the Allrun scripts, it will create a log file with the log.name file, with the name of the application that is executed. For example, you will get "log.blockMesh" and "log.snappyHexMesh" files, when the respective applications are used. Open those log files with a text editor and you will then be able to see if things went well or not. Furthermore, if feels like you're not familiar/comfortable with the shell/command line. Therefore, I suggest that you look for tutorials on this topic. For example: http://linuxcommand.org/learning_the_shell.php edit: If you don't give more information about which tutorial case you're trying to run, then it gets rather complicated to help you . Best regards, Bruno
June 10, 2014, 12:14 |
Rep Power: 11 |
Thank again for your answer.
I will try to explain more my problem. Sorry for my english, I am french. I want to use the tutorial floatingObject (using interdymfoam). I want to create a snappyHexMeshDict to create a sphere inside a tank. The snappyHexMesh seems to be working, because there is no fatal error in log.snappyhexmesh and folders 0.01, 0.02, 0.03 are created. On the contrary, there are fatal errors in the log.interdymfoam. It is written ; Create time Create mesh for time = 0.03 Selecting dynamicFvMesh dynamicMotionSolverFvMesh Selecting motion solver: displacementLaplacian --> FOAM FATAL IO ERROR: cannot find file file: /home/RN2/LouiseCode/floatingObject/0.03/pointDisplacement at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 73. FOAM exiting Am I clear ? Best, Louise. |
June 11, 2014, 16:11 |
Bruno Santos
Rep Power: 128 |
Hi Louise,
OK, that makes it a lot easier to understand what is happening in your case! The problem is that since you did not use the option "-overwrite" with snappyHexMesh, it created those additional time folders, one per mesh stage (castellated, snapped, with layers). For example: Code:
snappyHexMesh -overwrite Best regards, Bruno |
June 13, 2014, 12:28 |
Rep Power: 11 |
Hi Bruno,
Thank you very much for your answer and for the time you've put into it ! Best regards, Louise. |
Display Modes | |
[snappyHexMesh] Parallelize snappyHexMesh optimally? | Antimony | OpenFOAM Meshing & Mesh Conversion | 1 | May 25, 2016 01:01 |
Running parallel case after parallel meshing with snappyHexMesh? | Adam Persson | OpenFOAM Running, Solving & CFD | 0 | August 31, 2015 23:04 |
Something weird encountered when running OpenFOAM in parallel on multiple nodes | xpqiu | OpenFOAM Running, Solving & CFD | 2 | May 2, 2013 05:59 |
Strange Results With snappyHexMesh | calebamiles | OpenFOAM Running, Solving & CFD | 0 | August 14, 2011 17:02 |
[snappyHexMesh] stitchMesh and snappyHexMesh | gdbaldw | OpenFOAM Meshing & Mesh Conversion | 0 | December 23, 2009 03:09 |
