[blockMesh] Cylindrical BlockMesh
Old   September 12, 2014, 08:04
Default Cylindrical BlockMesh
Pratik Nanavati
nanavati is on a distinguished road
Hello All,
Can anyone please throw some light on how to generate Cylindrical blockMesh.
Actually I need this kind of cylnidrical shape mesh for SnappyHexMesh.
I am snapping Mixing chamber and for that if the Back Ground mesh is cylindrical then it can give much better results compared to Block shape BlockMesh.
Thanks
nanavati is offline   Reply With Quote
Old   September 13, 2014, 15:46
jokerito is on a distinguished road
have you seen this thread?
[#1]
jokerito is offline   Reply With Quote
Old   September 15, 2014, 10:03
Pratik Nanavati
[#1]
Yes I have already gone through it.. but I have one more problem.
I am not able to run this cylinderMesh.m4 file even after following the procedures written there.
this is very complicated one.
can i have it as a simple blockmeshDict file ?
Old   September 16, 2014, 13:12
I don't know why, but there is something missing after the m4 to blockMesh conversion. The syntax FoamFile is missing in the BlockMeshDict. If you add it at the beginning, it should work.
At first, you run the
 m4 cylinderMesh.m4 > blockMeshDict
from the folder where your cylinderMesh file is. Then you open the created blockMesh File and add before the header "version..." at the beginning
 FoamFile
{ version ...
  .... MeshDict;
and copy the file in your constant/polyMesh folder and then it should work.
Hope this helps,
Mike
blockmesh, cylinder mesh
[snappyHexMesh] Cylindrical blockmesh to Improve snappyHexMesh Results nicholas.jones OpenFOAM Meshing & Mesh Conversion 3 May 16, 2019 09:52
[blockMesh] Simple cylindrical geometry: example using blockMesh guin OpenFOAM Meshing & Mesh Conversion 0 June 19, 2017 05:59
[blockMesh] Non-physical solution with cylindrical 2D blockMesh with triangle faces A_Pete OpenFOAM Meshing & Mesh Conversion 0 November 20, 2015 04:38
[blockMesh] Cylindrical Duct with blockMesh StefanoP OpenFOAM Meshing & Mesh Conversion 0 December 7, 2013 06:36
[blockMesh] How to use blockMesh to generate cylindrical T-junction norkistar OpenFOAM Meshing & Mesh Conversion 2 January 28, 2013 20:53
