[blockMesh] what commands should I use to start creating a blockMeshdict file?
Old   October 20, 2014, 20:39
Default what commands should I use to start creating a blockMeshdict file?
Hojae Chung
Hojae is on a distinguished road
I just started using Linux/UX system and OpenFoam, so I have many questions for fairly easy ones.
I studied 'how to write a blockMeshdict' file on OpenFoam.org, but I can't figure out what commands to input to start creating a blockMeshdict file.
FYI, I'm trying to build meshes for an airfoil in a wind tunnel.
Thanks,
Hojae
Hojae is offline   Reply With Quote
Old   November 12, 2014, 16:58
cutter is on a distinguished road
Hi and welcome to the forums!
The input files for blockMesh are simple text files. They can be created and edited with any text editor. Usually the creation is done by copying an existing blockMeshDict file. The available text editors highly depend on your Linux distribution and the software packages that are installed on your machine. Please ask other students or colleagues to give you a short introduction to Linux and the most important commands! There are probably introductory courses at an university nearby!
The question is too generic to be answered more precisely.
Regarding the meshing of airfoils, please have a look at http://www.cfd-online.com/Forums/ope...odynamics.html.
Good luck!
Cutter
cutter is offline   Reply With Quote
airfoil, block mesh, blockmeshdict, wind tunnel
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 21:53
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 13:59
[swak4Foam] funkySetFields compilation error tayo OpenFOAM Community Contributions 39 December 3, 2012 05:18
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 10:57
