[blockMesh] How to mesh this?
Old   November 17, 2014, 20:19
Default How to mesh this?
Tony Ladd
tladd is on a distinguished road
I have been running some simulations of a Stefan problem. Basically two domains with a Laplace equation in each domain and a jump condition at the interface to include the (step) change in permeability. We solve a convection diffusion equation for concentration (C) in the inner region and advect the interface according to snGrad(C). The steady-state (more or less) finger shape at Pe = 50 (with the jump in perm = 10) is shown in C.jpg. There are 256^2 zones in this region - too many to show; coarser meshes develop artefacts before the steady state is reached.
Problem is the mesh is not very good; there are many non-orthogonal faces - see corner.jpg and tip.jpg. However, the max angle is still less than 80 deg. I make the mesh using blockMesh with a single block and the boundary defined with polyLine (OF2.3.0). I can see I might do better with foamyQuadMesh but before that I was wondering if anyone could suggest a better strategy for blockMesh.
Thanks
Tony
tladd is offline   Reply With Quote
Old   November 18, 2014, 05:50
Paulo Vatavuk
vatavuk is on a distinguished road
Hi Tony,
If have time (and patience) you could try this topology with 10 blocks.
Best Regards,
Paulo
vatavuk is offline   Reply With Quote
Old   November 18, 2014, 07:15
Tony Ladd
Paulo
Thanks for the suggestion. It is a bit or work and I think I will have to remesh as I go. I will let you you know if I have any success. But its clever how you keep the hex blocks - I did not see that.
Tony
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 11:14
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 08:52
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
