Axi-symmetric blockmesh
I am trying to create an axisymmetric mesh with blockMesh. The mesher is giving me a warning about the non-panarity of faces ("The local face at ... the normal ... differs from the average normal ... by 5.18e-15"). The mesh appears to have generated, but the case will not run. Any help would be greatly appreciated. Here is my input file: Code:
/*--------------------------------*- C++ -*----------------------------------*\ |
Hello JFluid,
I have very little experience with blockMesh but I had a simular problem and it was solved by increasing writePrecision in controlDict, so maybe it helps you as well Best Wouter |
Wouter, thank you very much for the reply. I already had the writePrecision set to 12. But your post gave me an idea. I solved the problem by increasing the number of digits of precision in the spreadsheet that I used to generate the mesh. 8 digits after the decimal point worked.
