[Gmsh] Creating 2 baffles in geometry
Old   October 6, 2018, 04:37
Default Creating 2 baffles in geometry
Petar Cajic
caja94 is on a distinguished road
Send a message via Skype™ to caja94
Hello guys, I am a beginner at using OpenFoam and Gmsh, and I have one problem.
For my master thesis, I wanted to create an air duct with heat source, and 2 plates that partially close air duct's cross-section. I used Gmsh for creating geometry, and everything works fine, except baffles. Here's what I want to get:
Plate1 is there, but it's invisible from this point of view. This is done in PHOENICS.
Now, I created geometry in Gmsh, and then I created a mesh. After that, I imported that mesh file in OpenFoam, and I tried to create 2 baffles that I need. For that I followed this youtube tutorial:
https://www.youtube.com/watch?v=7Ex1RHDQqIc
I have 2 plates, named Plate1 and Plate2. Here is my baffleDict file:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      createBafflesDict;
internalFacesOnly true;
baffles
    baffleFaces
        type        faceZone;
        zoneName    Plate1;
        flip        false;
        patches
            master
                name            Plate1;
                type            wall;
            slave { ${..master} }
baffles
    baffleFaces
        type        faceZone;
        zoneName    Plate2;
        flip        false;
        patches
            master
                name            Plate2;
                type            wall;
Also, here's my boundary file:
FoamFile
    version     2.0;
    format      ascii;
    class       polyBoundaryMesh;
    location    "constant/polyMesh";
    object      boundary;
9
    Front
        type            empty;
        physicalType    empty;
        nFaces          1380;
        startFace       2662;
    Bottom
        type            patch;
        physicalType    patch;
        nFaces          50;
        startFace       4042;
    Plate1
        type            wall;
        physicalType    wall;
        nFaces          0;
        startFace       4092;
    HeatSource
        type            patch;
        physicalType    patch;
        nFaces          32;
        startFace       4092;
    Back
        type            empty;
        physicalType    empty;
        nFaces          1380;
        startFace       4124;
    Outlet
        type            patch;
        physicalType    patch;
        nFaces          18;
        startFace       5504;
    Inlet
        type            patch;
        physicalType    patch;
        nFaces          16;
        startFace       5522;
    Plate2
        type            wall;
        physicalType    wall;
        nFaces          0;
        startFace       5538;
    Top
        type            patch;
        physicalType    patch;
        nFaces          80;
        startFace       5538;
After I run createBaffles command, I get this:
createBaffles -case proba1 -dict system/baffleDict -overwrite
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  6
     \\/     M anipulation  |
Build  : 6-e05f780ebc87
Exec   : createBaffles -case proba1 -dict system/baffleDict -overwrite
Date   : Oct 06 2018
Time   : 10:21:12
Host   : "Petar"
PID    : 14881
I/O    : uncollated
Case   : ./proba1
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading baffle criteria from createBafflesDict
Not converting faces on non-coupled patches.
Created zone baffleFaces at index 2 with 12 faces
Patch 'Plate2' already exists.  Only moving patch faces - type will remain the same
Converted 12 faces into boundary faces in patches 1(Plate2)
--> FOAM Warning :
    From function int main(int, char**)
    in file createBaffles.C at line 854
    Setting field on boundary faces to zero.
You might have to edit these fields.
Removing zero-sized patches:
    Plate1 type wall at position 2
Writing mesh to 0
End
Now, when I run paraFoam, I see the problem that shows at the line "Removing zero-sized patches: Plate1 type wall at position 2"
Then, I tried changing startFace for Plate1 to the last face, as said in tutorial, but I get this error:
Create time
--> FOAM FATAL ERROR:
Problem : Patch Plate1 starts at 5618
Current face counter at 4092
Are patches in incremental order?
    From function void Foam::polyTopoChange::addMesh(const Foam::polyMesh&, const labelList&, const labelList&, const labelList&, const labelList&)
    in file polyTopoChange/polyTopoChange/polyTopoChange.C at line 2451.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::error::abort() at ??:?
#2  Foam::polyTopoChange::addMesh(Foam::polyMesh const&, Foam::List<int> const&, Foam::List<int> const&, Foam::List<int> const&, Foam::List<int> const&) at ??:?
#3  Foam::polyTopoChange::polyTopoChange(Foam::polyMesh const&, bool) at ??:?
#4  ? in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/createBaffles"
#5  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#6  ? in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/createBaffles"
Aborted (core dumped)
I also tried matching startFaces for Plate1 and Plate2, but the only time i can actually run createBaffles command successfully is when Plate1 startFace matches that from the first file.
I also uploaded entire case file here: https://ufile.io/8qi1z
fvSchemes, fvSolutions etc. are there just because I couldn't export from Gmsh to OF without them, I didn't work on them yet.
I hope you guys can help me, it would be much appreciated. Thank you in advance.
caja94 is offline   Reply With Quote
Old   October 7, 2018, 04:05
Default Update
Petar Cajic
Hi guys, I managed to resolve this problem by going back to gmsh and putting both plates in 1 physical group, thus making my problem a lot easier. Before this thread is closed, can anyone tell me if solving this problem the way I did will have any effect when I try to get my case to work?
Thanks a lot.
[ICEM] Creating mesh for fluid - solid geometry tmu ANSYS Meshing & Geometry 1 March 5, 2016 06:14
[ICEM] Question about creating lateral surface for a specific geometry lnk ANSYS Meshing & Geometry 2 July 12, 2012 06:14
Creating geometry from .def file az_f ANSYS Meshing & Geometry 1 June 29, 2011 07:27
Loosing baffles while creating a volume mesh Susanne Siemens 0 May 9, 2006 02:52
Creating 2D geometry with ICEM TobiasZ CFX 4 April 13, 2006 04:32
