[mesh manipulation] how can remove bad cells with assistance of cellSet,setSet,subsetMesh utilities?
Like Tree1Likes
  • 1 Post By dener
Old   August 8, 2013, 11:42
Default how can remove bad cells with assistance of cellSet,setSet,subsetMesh utilities?
s.m
saeideh mohamadi
s.m is on a distinguished road
Hi
I use the checkMesh utility:
Exec : checkMesh
Date : Mar 28 2011
Time : 16:17:31
Host : simon-VPCEB1J1E
PID : 3410
Case : /home/simon/Escritorio/mis_test/TEST-MALLA/testsnapEdge/BULB/V70_1
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
faces: 5925560
internal faces: 5561625
cells: 1838209
boundary patches: 7
point zones: 0
face zones: 0
cell zones: 0
Overall number of cells of each type:
hexahedra: 1691494
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 0
polyhedra: 146715
Checking topology...
Boundary definition OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
Patch Faces Points Surface topology
zmin 8111 9075 ok (non-closed singly connected)
zmax 4489 4898 ok (non-closed singly connected)
xmin 1335 1447 ok (non-closed singly connected)
ymax 7596 7860 ok (non-closed singly connected)
ymin 900 961 ok (non-closed singly connected)
xmax 1143 1234 ok (non-closed singly connected)
bulb_GID 340361 344468 ok (non-closed singly connected)
Checking geometry...
Overall domain bounding box (-12.1 -1 -2.1) (-8.4 4 0)
Mesh (non-empty, non-wedge) directions (1 1 1)
Mesh (non-empty) directions (1 1 1)
Boundary openness (-2.6271e-16 -1.12183e-15 1.70118e-14) OK.
Max cell openness = 2.8861e-16 OK.
Max aspect ratio = 7.84759 OK.
Minumum face area = 5.67861e-07. Maximum face area = 0.0205671. Face area magnitudes OK.
Min volume = 6.11961e-09. Max volume = 0.0014397. Total volume = 38.1685. Cell volumes OK.
Mesh non-orthogonality Max: 62.5983 average: 10.3867
Non-orthogonality check OK.
Face pyramids OK.
***Max skewness = 6.2148, 36 highly skew faces detected which may impair the quality of the results
<<Writing 36 skew faces to set skewFaces
Failed 1 mesh checks.
End
I would like delete or fix this mesh errors, i have studied in the forum about that "cellSet,setSet,subsetMesh" but i dont understand how should we use these utility yet,
can you help me ?
Thank you very much.
s.m is offline   Reply With Quote
Old   August 22, 2013, 08:20
Default usage of setSet, subsetMesh
Denis GILBERT
dener is on a distinguished road
searching for some technics to find bad cells I found this link, I hope it helps you.
http://www.diva-portal.org/smash/get...FULLTEXT01.pdf
Regards
s.m likes this.
dener is offline   Reply With Quote
Old   September 22, 2013, 13:48
s.m
saeideh mohamadi
Anyone can't help me?
Old   September 23, 2015, 12:04
Johan
JohanAdam is on a distinguished road
Please see http://openfoamwiki.net/index.php/SetSet
JohanAdam is offline   Reply With Quote
[ICEM] Error in mesh writing helios ANSYS Meshing & Geometry 21 August 19, 2021 14:18
Problem with divergence TDK FLUENT 13 December 14, 2018 06:00
killed "snappyHexMesh" parkh32 OpenFOAM Pre-Processing 2 April 8, 2012 17:12
how to deal with bad quality cells? phsieh2005 OpenFOAM 3 July 20, 2011 09:35
Problems of Duns Codes! Martin J Main CFD Forum 8 August 14, 2003 23:19
