[blockMesh] Multiple Regions not Connected by Any Face
Like Tree1Likes
  • 1 Post By lcj66
Old   July 6, 2015, 21:53
Default Multiple Regions not Connected by Any Face
Lori
lcj66 is on a distinguished road
Hi!
So I am attempting to make a mesh that is basically two rectangles, one on top of the other, with a membrane interface between. I have made the following blockMeshDict file:
|  \\    /   O peration     | Version:  2.3.1                                |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 0.01;
vertices
    ( 0      0      0   ) // Number 0
    ( 14     0      0   ) // Number 1
    ( 14     0.3    0   ) // Number 2
    ( 0      0.3    0   ) // Number 3
    ( 0      0      0.1 ) // Number 4
    ( 14     0      0.1 ) // Number 5
    ( 14     0.3    0.1 ) // Number 6
    ( 0      0.3    0.1 ) // Number 7
    ( 0     -0.3    0   ) // Number 8
    ( 14    -0.3    0   ) // Number 9
    ( 14     0      0   ) // Number 10
    ( 0      0      0   ) // Number 11
    ( 0    -0.3    0.1  ) // Number 12
    ( 14   -0.3    0.1  ) // Number 13
    ( 14     0    0.1   ) // Number 14
    ( 0      0    0.1   ) // Number 15
blocks
   hex ( 0 1 2 3 4 5 6 7 ) (140 150 1) simpleGrading (1 10 1)
   hex ( 8   9   10 11 12 13 14 15 ) (140 150 1) simpleGrading (1 10 1)
edges
boundary
    inlet1
         type patch;
         faces
             (0 4 7 3)
     inlet2
          type patch;
          faces
              (9 10 14 13)
      outlet1
           type patch;
           faces
               (6 5 1 2)
       outlet2
           type patch;
           faces
               (11 8 12 15)
       fixedWalls
            type wall;
            faces
                (3 7 6 2)
                (8 9 13 12)
mergePatchPairs
and then I used the toposet utility and createbaffles utility to make a facezone out of the membrane and to make it into an internal boundary. Below are the toposetdict and createbafflesdict files:
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      topoSetDict;
actions
    name            f0;
    type            faceSet;
    action          new;
    source          boxToFace;
    sourceInfo
        box         (0 0 0) (0.14 0 0.01);
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      createBafflesDict;
internalFacesOnly false;
noFields          true;
baffles
    Membrane
        type         faceZone;
        zoneName     f0;
        patchPairs
           type      patch;
When this happens, the checkMesh says the mesh is ok, but it still has the message that:
" *Number of regions: 2
The mesh has multiple regions which are not connected by any face."
And I am almost certain this is why I am getting issues while attempting to use a custom built solver.
So, any ideas on how to connect the two regions? Im still new to openfoam so my knowledge about utilities is sparse and would like to get suggestions on where I should go.
Thanks!
Lori
niumeng likes this.
lcj66 is offline   Reply With Quote
Old   July 9, 2015, 05:21
Alexander Bartel
alexB is on a distinguished road
Hi Lori,
it's an frequently made beginners error.
http://www.cfd-online.com/Forums/ope...ordinates.html
regards
Alex
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
alexB is offline   Reply With Quote
Old   September 29, 2017, 14:30
HJM
Jue
HJM is on a distinguished road
Hi Lori,
Did you figure it out? Would you like to share your solution to this problem?
What I want to do is to make the top membrane surface as a patch. I use faceZoneSet in topoSet and createBaffles. But when I do checkMesh, I have the exact same problem about two regions. It seems cellzone is separated to two regions. I searched ton of threads for several days but didn't find a solution.
Would you please help me with that?
Thank you very much!
HJM is offline   Reply With Quote
blockmesh, createbaffles, openfoam, regions, toposet
Run parallel but low calculating speed HuJG OpenFOAM Running, Solving & CFD 1 April 22, 2019 22:15
Simulating fire in a tunnel luca1992 OpenFOAM 14 August 16, 2017 13:50
[snappyHexMesh] How to define to right point for locationInMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 7 March 13, 2016 14:07
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
