Home > Forums > OpenFOAM Native Meshers: blockMesh
face normal direction of a wedge
Old   July 15, 2015, 19:51
Default face normal direction of a wedge
popokaka is on a distinguished road
I tried to create a wedge for a axial symmetrical problem. This figure is the geometry. Following is my
blockMeshDict file.
According to the user guide, the normal direction of any boundary face should point to outside of the computational zone. So I defined all the faces in this way. Error messages popped out when I run blockMesh, saying outlet and axi_symm-r don't have neighbor cell faces.
I found that if I change the vertices in the reversed order (the quoted lines) I can generate the mesh successfully. But in this case, the normal directions of these two faces are actually pointing into the computational zone. I wonder what is wrong. Thanks
convertToMeters 1;
vertices
(0 0 0) //0
(8 0 0) //1
(0 -0.0034905 0.099985) //2
(8 -0.0034905 0.099985) //3
(8 0.0034905 0.099985) //4
(0 0.0034905 0.099985) //5
blocks
hex (0 1 1 0 2 3 4 5) (100 1 20)
simpleGrading
1
1
(0.5 0.5 4)
(0.5 0.5 0.25)
edges
arc 2 5 (0 0 0.1)
arc 3 4 (8 0 0.1)
patches
patch
inlet
(0 2 5 0)
patch
outlet
// (1 3 4 1)
(1 4 3 1)
wedge
axi_symm-f
(0 1 3 2)
wedge
axi_symm-r
// (0 1 4 5)
(0 5 4 1)
wall
wall
(2 3 4 5)
mergePatchPairs
popokaka is offline   Reply With Quote
Old   July 16, 2015, 04:48
Alexander Bartel
alexB is on a distinguished road
Hi popo, or kaka or whatever (I hope you aren't german )
You made an fault by defining your block.
If you want to let collapse some points to create a prism... don't let the first 4 collapse, as they are used to define your local coordinate system of the block.
I hope it helps
regards
Alex
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
alexB is offline   Reply With Quote
Old   July 16, 2015, 13:39
Thanks for the response.
I changed the geometry. So now it is like:
|  \\    /   O peration     | Version:  2.4.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
 FoamFile
     version     2.0;
     format      ascii;
     class       dictionary;
     object      blockMeshDict;
 convertToMeters 0.01;
 vertices
     (-0.008026884 0 -1)             //0
     (0.008026884 0 -1)           //1
     (0.008026884 8.8 -1)             //2
     (-0.008026884 8.8 -1)               //3
     (0 0 0)              //4
     (0 8.8 0)            //5
 blocks
         hex (0 1 2 3 4 5 5 4) (1 100 20)
         simpleGrading
             1
             1
                (0.5 0.5 4)
                (0.5 0.5 0.25)
 edges
 patches
         patch
         inlet
                 (4 0 1 4)
         patch
         outlet
                 (2 3 5 5)
         wedge
         axi_symm-f
                 (1 2 5 4)
         wedge
         axi_symm-r
                 (0 4 5 3)
         wall
         wall
                 (0 3 2 1)
 mergePatchPairs
However, I still had the same error message:
--> FOAM FATAL ERROR:
face 0 in patch 0 does not have neighbour cell face: 4(4 0 1 4)
I hope it helps
regards
Alex
Old   July 16, 2015, 14:39
I didn't find it in the user guide. But does the symmetrical axis need to be one of the coordinate axis?
thanks
I hope it helps
regards
Alex
Old   July 16, 2015, 17:23
Alexander Bartel
hmmm, looks good so far...
but I am not sure about your multi-grading-thing... never done that... I hope you are sure that there is no error.
Furthermore I always rather describe the boundary than the patches.
like here http://cfd.direct/openfoam/user-guide/blockmesh/ see under 5.3.1.5 The boundary
I hope it helps
Edit:
Another possible error could be that you haven't defined the empty patch (4 5 5 4) . But I don't know it refers to the error message.
Old   July 17, 2015, 10:45
I found this example:
https://openfoamwiki.net/index.php/M...s/AxiSymmetric
But even in this case, the normal direction of the outlet is pointing to the computational domain. I am really confused...
I hope it helps
Edit:
Old   July 17, 2015, 15:47
Alexander Bartel
the rule to set the boundary is defined in the users guide as
The order in which the vertices are given must be such that, looking from inside the block and starting with any vertex, the face must be traversed in a clockwise direction to define the other vertices
but I thought it fits to your dict
Old   July 17, 2015, 16:30
yeah, in my case, it fits. But the case doesn't work.
All the working cases I saw so far have one or two faces violating this rule. I am really confused...
Old   July 19, 2015, 13:13
Alexander Bartel
sorry, but I am at my wits end.
Have you defined the empty face?
Old   July 20, 2015, 11:29
I tried that as well.
Thanks for your help anyway
Old   July 20, 2015, 15:44
Alexander Bartel
there is no try... do it
I wanted to say that it's necessary to define the collapsed face explicitly. (as I read it in the guide)
And one thing I wanted to say at first when I saw your dict (but I forgot it) :
I think you have to write:
        inlet
            type patch;
            faces
                (4 0 1 4)
Instead of:
patch
inlet
 (4 0 1 4)
Old   Yesterday, 17:36
I did.
Take a look at this example:
The normal direction of the outlet is in the "wrong direction". If you change that, the case won't work. Everything else you mentioned was in this case. The empty face. The way of defining faces for the new version of openFOAM
        inlet
            type patch;
            faces
                (4 0 1 4)
Instead of:
patch
inlet
 (4 0 1 4)
Thread Tools
Trackbacks are On
How to get area, face normal vector of a patch GCMS_A OpenFOAM Running, Solving & CFD 1 May 28, 2015 03:52
Exporting Face Normal of a patch and some other values fredo490 OpenFOAM Post-Processing 6 March 14, 2014 08:44
how to set periodic boundary conditions Ganesh FLUENT 13 January 22, 2014 05:11
Error message: 8 face(s) not in face lists of adjacent cells jyoung79 FLUENT 0 November 10, 2012 17:09
