[blockMesh] checkMesh Floating point exception error
Old   July 31, 2015, 14:26
Default checkMesh Floating point exception error
Daniel Madeira de Almeida
daniel.almeida is on a distinguished road
I am trying to create a mesh of a wedge with a small void part representing a nozzle. I have the blockMeshDict, and p and U at 0. I created the mesh, but when I try to run checkMesh I get the following message:
| \\ / O peration | Version: 2.2.2 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.2.2-9240f8b967db
Exec : checkMesh
Date : Jul 31 2015
Time : 14:16:43
Host : "daniel-N450-P-BE55P1"
PID : 6298
Case : /home/daniel/OpenFOAM/daniel-2.2.2/mit/nozzle2D
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create polyMesh for time = 0
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam:olyMesh::calcDirections() const at ??:?
#4 Foam:olyMesh:olyMesh(Foam::IOobject const&) at ??:?
at ??:?
#6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
at ??:?
I could open the mesh on paraview without loading the pressure and velocity fields, as it occurred in other error:
--> FOAM FATAL IO ERROR:
patch type 'patch' not constraint type 'wedge'
for patch front of field U in file "/home/daniel/OpenFOAM/daniel-2.2.2/mit/nozzle2D/0/U"
Here is the blockMeshDict:
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 0.001;
vertices
(0 0 0) //vertex number 0
(19.3937 0 0) //vertex number 1
(300 0 0) //vertex number 2
(0 -0.138496 3.1720) //vertex number 3
(0 0.138496 3.1720) //vertex number 4
(19.3937 -0.138496 3.1720) //vertex number 5
(19.3937 0.138496 3.1720) //vertex number 6
(300 -0.138496 3.1720) //vertex number 7
(300 0.138496 3.1720) //vertex number 8
(0 -0.207748 4.7581) //vertex number 9
(0 0.207748 4.7581) //vertex number 10
(6.4646 -0.207748 4.7581) //vertex number 11
(6.4646 0.207748 4.7581) //vertex number 12
(19.3937 -0.207748 4.7581) //vertex number 13
(19.3937 0.207748 4.7581) //vertex number 14
(300 -0.207748 4.7581) //vertex number 15
(300 0.207748 4.7581) //vertex number 16
(0 -2.1810 49.952) //vertex number 17
(0 2.1810 49.952) //vertex number 18
(6.4646 -2.1810 49.952) //vertex number 19
(6.4646 2.1810 49.952) //vertex number 20
(19.3937 -2.1810 49.952) //vertex number 21
(19.3937 2.1810 49.952) //vertex number 22
(300 -2.1810 49.952) //vertex number 23
(300 2.1810 49.952) //vertex number 24
blocks
hex (0 1 1 0 3 5 6 4) (20 1 6) simpleGrading (1 1 1) //0
hex (1 2 2 1 5 7 8 6) (280 1 6) simpleGrading (1 1 1) //1
hex (5 7 8 6 13 15 16 14) (280 1 3) simpleGrading (1 1 1) //2
hex (9 11 12 10 17 19 20 18) (6 1 100) simpleGrading (1 1 1) //3
hex (11 13 14 12 19 21 22 20) (14 1 100) simpleGrading (1 1 1) //4
hex (13 15 16 14 21 23 24 22) (280 1 100) simpleGrading (1 1 1) //5
hex (11 5 6 12 11 13 14 12) (14 1 3) simpleGrading (1 1 1) //6
edges
arc 3 4 (0 0 3.17502)
arc 5 6 (19.3937 0 3.17502)
arc 9 10 (0 0 4.76263)
arc 11 12 (6.4646 0 4.76263)
arc 17 18 (0 0 49.9996)
arc 23 24 (300 0 49.9996)
patches
patch
inlet
(0 3 4 0)
patch
outlet
(2 7 8 2)
(7 15 16 8)
(15 23 24 16)
wall
wall
(3 5 6 4)
(17 19 20 18)
(19 21 22 20)
(21 23 24 22)
(10 9 17 18)
(10 12 11 9)
(12 6 5 11)
wedge
front
(0 1 5 3)
(1 2 7 5)
(5 7 15 13)
(9 11 19 17)
(11 13 21 19)
(13 15 23 21)
(11 5 13 11)
wedge
back
(0 1 6 4)
(1 2 8 6)
(6 8 16 14)
(10 12 20 18)
(12 14 22 20)
(14 16 24 22)
(12 6 14 12)
mergePatchPairs //merge faces for patches created
p:
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0]; //dimension [Mass Length Time Temperature Quantity Current Luminous intensity] IMPORTANT: OpenFOAM use rho normalized pressure, divide pressure by density!!
internalField uniform 0;
boundaryField
inlet
type uniformFixedValue;
uniformValue tableFile;
tableFileCoeffs
fileName "$FOAM_CASE/inletpressure"
outOfBounds clamp;
outlet
type fixedValue;
value uniform 0;
wall
type zeroGradient;
front
type wedge;
back
type wedge;
U:
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0]; //dimension of the variable [Mass Length Time Temperature Quantity Current Luminous intensity]
internalField uniform (0 0 0);
boundaryField
inlet
type zeroGradient;
outlet
type zeroGradient;
wall
type fixedValue;
value uniform (0 0 0); //no slip condition, 0m/s velocity
front
type wedge;
back
type wedge;
I also uploaded a picture of the detail of the wedge. The nozzle part.
Has anyone seen something similar before?
Thanks in advance,
Daniel
daniel.almeida is offline   Reply With Quote
long error when using make-install SU2_AD. tomp1993 SU2 Installation 3 March 17, 2018 06:25
Undeclared Identifier Errof UDF SteveGoat Fluent UDF and Scheme Programming 7 October 15, 2014 07:11
[General] 2 datas on one plot Akuji ParaView 46 December 1, 2013 14:06
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 09:30
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 02:27
