[mesh manipulation] Best way to merge this two mesh
Old   October 25, 2015, 22:54
Default Best way to merge this two mesh
Eduardo Firvida
efirvida is on a distinguished road
Hi I'm trying to create a 3D wind tunnel for wind generator, in openfoam for this I have this to separated meshes files. its possible to do that?? Or in the case that the best way is to all blocks in the same blockMeshDic file, how can I create the blocks between the curvatures.
blockMeshDict1 -> is the mesh definition for blade, to use it first is needed a translation like
transformPoints -rotate '( (0 1 0) (0 0 1) )'
blockMeshDict2 -> is the tunnel mesh
efirvida is offline   Reply With Quote
[Commercial meshers] MRF: imported mesh from ICEM not shown in ParaView and trying to merge with other n0ukh3z007 OpenFOAM Meshing & Mesh Conversion 0 September 20, 2015 15:04
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
[Technical] How to crop a mesh or merge layers Opxah OpenFOAM Meshing & Mesh Conversion 1 May 31, 2011 07:32
[ICEM] Merge mesh - non manifold vertices BrolY ANSYS Meshing & Geometry 4 October 30, 2010 22:07
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
