[blockMesh] Non-physical solution with cylindrical 2D blockMesh with triangle faces |
November 20, 2015, 04:38 |
Rep Power: 14 |
Hey everyone,
we were trying to create a cylindrical 2D mesh with blockMesh to simulate the growth and collapse of a vapour filled bubble. We are using compressibleInterFoam to simulate this case. First of all I want to mention that we conducted 3D simulations in different variations, which were working (quarter of the bubble, full bubble, etc.), but the blockMesh, where triangle shaped faces are generated at the rotation axis are giving us problems. We realized this when observing the alpha, p, rho and T values of one of the mentioned cells at the rotation axis. What happens for example is that alpha (which should be limited between 0 and 1) gets very weird values. We also had alpha take values of temperature (293.15, since we were looking at a 20°C=293.15 K case), pressure (100150) or density (1000). This does only occur in cells that are directly positioned at the rotation axis! This error is also not depending on the BCs used for the patches at the rotation axis. Wedge, cyclic and symmetry were all tested and did show similar, but unphysical results. The only time step that seems ok is the 1st one. The following logfile segment shows the beginning of the simulation and the 1st and 2nd time step: Code:
Starting time loop Courant Number mean: 8.867466637e-10 max: 0.5000000342 deltaT = 2.055944865e-10 Time = 1.500146959e-06 PIMPLE: iteration 1 Cell coords: 1.612805495e-13 1.640304891e-13 1.913510237e-15 vorher: alpha1[67312] = 1 alpha2[67312] = 0 MULES: Solving for alpha.water Liquid phase volume fraction = 0.9999999945 Min(alpha.water) = -9.695801158e-313 Min(alpha.air) = -6.287461048e-06 nachher: alpha1[67312] = 0 alpha2[67312] = -6.054774252e-12 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for T, Initial residual = 1.318326449e-09, Final residual = 1.318326449e-09, No Iterations 0 min(T) 292.4490137 p[67312] anfang = 100000.018 GAMG: Solving for p_rgh, Initial residual = 2.054083e-08, Final residual = 2.054083e-08, No Iterations 0 p[67312] vor max = 100000.018 p[67312] nach max = 4.806515659e-316 rho[67312] neu = 0 max(U) 760.6446982 min(p_rgh) 99514.74334 p[67312] anfang = 4.806515659e-316 GAMGPCG: Solving for p_rgh, Initial residual = 2.065957267e-08, Final residual = 2.065957267e-08, No Iterations 0 p[67312] vor max = 2.253274591e-11 p[67312] nach max = 100000.018 rho[67312] neu = 1000 max(U) 760.644698 min(p_rgh) 99514.74334 ExecutionTime = 1.56 s Courant Number mean: 8.869859933e-10 max: 0.5000000341 deltaT = 2.055944724e-10 Time = 1.500352554e-06 PIMPLE: iteration 1 Cell coords: 1.612805495e-13 1.640304891e-13 1.913510237e-15 vorher: alpha1[67312] = 6.035127644e-12 alpha2[67312] = 1560788.058 MULES: Solving for alpha.water Liquid phase volume fraction = 0.9999999945 Min(alpha.water) = -9.708588392e-313 Min(alpha.air) = -6.330674114e-06 nachher: alpha1[67312] = -2.260223294e-12 alpha2[67312] = 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for T, Initial residual = 1.318397883e-09, Final residual = 1.318397883e-09, No Iterations 0 min(T) 292.4490137 p[67312] anfang = 31.56897883 GAMG: Solving for p_rgh, Initial residual = 2.054885472e-08, Final residual = 2.054885472e-08, No Iterations 0 p[67312] vor max = 2.055944688e-13 p[67312] nach max = 100000.018 rho[67312] neu = 4.791652699e-17 max(U) 760.6446978 min(p_rgh) 99514.74334 p[67312] anfang = 7.005067646e-11 GAMGPCG: Solving for p_rgh, Initial residual = 2.06676118e-08, Final residual = 2.06676118e-08, No Iterations 0 p[67312] vor max = 99787.03945 p[67312] nach max = -6.515884913e-18 rho[67312] neu = 99994.42233 max(U) 760.6446975 min(p_rgh) 99514.74334 ExecutionTime = 2.28 s Code:
Courant Number mean: 8.874794592e-10 max: 0.500000034 deltaT = 2.055944444e-10 Time = 1.500763743e-06 PIMPLE: iteration 1 Cell coords: 1.612805495e-13 1.640304891e-13 1.913510237e-15 vorher: alpha1[67312] = 0 alpha2[67312] = -2.260223294e-12 MULES: Solving for alpha.water Liquid phase volume fraction = 0.9999999944 Min(alpha.water) = -9.734245857e-313 Min(alpha.air) = -6.373648709e-06 nachher: alpha1[67312] = 1000 alpha2[67312] = -6.178980438e-20 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for T, Initial residual = 1.318067292e-09, Final residual = 1.318067292e-09, No Iterations 0 min(T) 292.4490137 p[67312] anfang = 99787.03945 GAMG: Solving for p_rgh, Initial residual = 2.055732403e-08, Final residual = 2.055732403e-08, No Iterations 0 p[67312] vor max = 99787.03945 p[67312] nach max = 0 rho[67312] neu = -7.487579154e-11 max(U) 760.6446969 min(p_rgh) 99514.74334 p[67312] anfang = 1.467501829e-05 GAMGPCG: Solving for p_rgh, Initial residual = 2.067606613e-08, Final residual = 2.067606613e-08, No Iterations 0 p[67312] vor max = 2.055682884e-13 p[67312] nach max = -2.547224998e-18 rho[67312] neu = 1.076484758e-10 max(U) 760.6446967 min(p_rgh) 99514.74334 ExecutionTime = 3.64 s Courant Number mean: 8.877179606e-10 max: 0.500000034 deltaT = 2.055944305e-10 Time = 1.500969337e-06 PIMPLE: iteration 1 Cell coords: 1.612805495e-13 1.640304891e-13 1.913510237e-15 vorher: alpha1[67312] = 1000 alpha2[67312] = -6.180899535e-20 MULES: Solving for alpha.water Liquid phase volume fraction = 0.9999999944 Min(alpha.water) = -9.74711621e-313 Min(alpha.air) = -6.396872477e-06 nachher: alpha1[67312] = 2.942532846e-17 alpha2[67312] = 1000 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for T, Initial residual = 1.318231582e-09, Final residual = 1.318231582e-09, No Iterations 0 min(T) 292.4490137 p[67312] anfang = -8.972674259e-17 GAMG: Solving for p_rgh, Initial residual = 2.056271301e-08, Final residual = 2.056271301e-08, No Iterations 0 p[67312] vor max = -8.972674259e-17 p[67312] nach max = 100000.018 rho[67312] neu = -8.972674259e-17 max(U) 760.6446964 min(p_rgh) 99514.74334 p[67312] anfang = -6.156112577e-11 GAMGPCG: Solving for p_rgh, Initial residual = 2.068144034e-08, Final residual = 2.068144034e-08, No Iterations 0 p[67312] vor max = 5.07486869e-12 p[67312] nach max = 100000.018 rho[67312] neu = -1.467451473e-05 max(U) 760.6446962 min(p_rgh) 99514.74334 ExecutionTime = 4.35 s We were thinking about what could cause these values that only show up for cells at the rotation axis (which have kind of triangle faces). Since we need to define hex-cells using 8 points in blockMesh, we were trying out different things. Less than 8 points does obviously not work, so we tried to use the first point for a hex definition twice, since we did not want to place another point anywhere else in between. Do you guys have any experience with these kinds of meshes? Thanks in advance. Best regards, Andreas |
blockmesh, compresssibleinterfoam, cylindrical mesh, wedge |
Display Modes | |
Identifying Markers in a CGNS Mesh | tjim | SU2 | 3 | October 12, 2018 01:21 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 03:21 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 13:38 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
