May 29, 2016, 10:03 |
emove a cylinder from a cube
A. Min
Rep Power: 12 |
Hi
I want to simulate Free Convection flow of water over a circular cylinder as a practice. How can I remove a cylinder from a cube? Thanks friends |
May 29, 2016, 16:57 |
Marco Atzori
Rep Power: 10 |
Hi!
I'm not sure it is what you are looking for: try to use blockMesh with the attachment (I changed a little bit what I found in this post: http://www.cfd-online.com/Forums/ope...-cylinder.html) Anyway, if I had to started from scratch, I would use Salome to obtain an .stl and Snappy or cfMesh for the mesh. Cheers! |
May 30, 2016, 02:36 |
#3 | |
A. Min
Rep Power: 12 |
Thanks a lot for your cooperation! It works well and I can see the Mesh. I'm a beginner in openFoam. I know about Verticies, blocks, edges but not about patches! What are patches? in fact why do we use patch command in blockMeshDict? In addition, could you please explain how to create this mesh by that code? Thanks a lot |
May 30, 2016, 03:04 |
Rep Power: 15 |
Patches are basically faces on which usually boundary conditions are applied for the problem that you are solving. It is the generic term for faces on which BCs will be applied. While patch is the generic term, there are instance when you might want to be more specific about the type of patch the face is, e.g. wall, symmetry etc. You can read more about it here (under the section on boundary): http://cfd.direct/openfoam/user-guide/blockMesh/ Hope this helps. Cheers, Antimony |
May 30, 2016, 03:19 |
A. Min
Rep Power: 12 |
Hi Antimony!!
of course it was helpful. but in the page you introduce me, there is a code that has boundary, not patches: boundary // keyword ( inlet // patch name { type patch; // patch type for patch 0 faces ( (0 4 7 3) // block face in this patch ); } // end of 0th patch definition outlet // patch name { type patch; // patch type for patch 1 faces ( (1 2 6 5) ); } walls { type wall; faces ( (0 1 5 4) (0 3 2 1) (3 7 6 2) (4 5 6 7) ); } ); while, in the code that is sent to me by my friend Marco Atzori (top of this page) we have patches instead of boundaries! patches ( symmetryPlane down ( (42 43 56 55) (41 42 55 54) (43 50 63 56) (50 49 62 63) ) patch right ( (2 3 22 21) (3 6 25 22) (2 38 51 21) (38 41 54 51) ) symmetryPlane up ( (7 8 27 26) (6 7 26 25) (8 18 37 27) (18 17 36 37) ) patch left ( (14 13 32 33) (17 14 33 36) (46 13 32 59) (49 46 59 62) ) symmetryPlane cylinder ( (10 5 24 29) (5 0 19 24) (16 10 29 35) (11 16 35 30) (45 40 53 58) (40 0 19 53) (48 45 58 61) (11 48 61 30) ) ); why? whats difference? Thanks my dear friend |
May 30, 2016, 04:49 |
Rep Power: 15 |
I don't think there is a difference. I think "patches" at that location is from an older version of OF, while "boundary" is the one that has been around from OF 2.1.x (at least that is how long I can remember it being there). The one sent by Atzori seems to be from OF 1.5, though I could be wrong about that. Cheers, Antimony |
May 30, 2016, 04:55 |
Marco Atzori
Rep Power: 10 |
Hi!
Antimony's perfectly right: I took the example directly from the previous post and it is an old version: I suppose that a sort of partial redundancy is adopted because I managed to compile the attachment in OF 2.2 (the attachment, what you have post later differs from the presence of the “symmetryPlane”), but I recognise now the difference with the current standard: I’m writing a new dict, just one sec: I notice that “front” and “back” are not included in the boundary and it takes some min to add them |
May 30, 2016, 05:14 |
Marco Atzori
Rep Power: 10 |
Hi!
It is better now Notice that the "empty type" is mandatory in that case for frontAndBack since it is a 2D case. Cheers! |
May 30, 2016, 09:27 |
#9 |
A. Min
Rep Power: 12 |
Thanks dear friends. You helped me a lot!
Best Regards... |
free convection, openfoam |
Flow past a 2D cylinder - High Re (1E+05) - Cd too high | Pervispasco | OpenFOAM Running, Solving & CFD | 4 | March 14, 2022 02:19 |
Drag force coefficient too high for a flow past a cylinder using komega sst | Scabbard | OpenFOAM Running, Solving & CFD | 37 | March 21, 2016 16:16 |
Forces Acting on a Rotating Cylinder (Moving Mesh) | dreamchaser | CFX | 5 | April 25, 2015 06:01 |
Gambit help: Cube inside cube | Jack Martinez | FLUENT | 13 | August 11, 2010 06:29 |
[blockMesh] Specifying boundary faces failes in blockMesh | blaise | OpenFOAM Meshing & Mesh Conversion | 0 | May 10, 2010 03:56 |
