July 8, 2016, 10:01 |
checkMesh/blockMesh errors
Marco Bernardes
Rep Power: 16 |
I have created a cylinder using blockMesh and arcs. The mesh looks great (see figure) but I get too many errors. I would appreciate any help. Best, Marco. /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.3.1-262087cdf8db Exec : checkMesh Date : Jul 08 2016 Time : 15:58:19 Host : "ubuntu" PID : 12626 Case : /home/marco/SUPP_blockMesh nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 169781 faces: 489600 internal faces: 470400 cells: 160000 faces per cell: 6 boundary patches: 2 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 160000 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. ***Total number of faces on empty patches is not divisible by the number of cells in the mesh. Hence this mesh is not 1D or 2D. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology outlet 1600 1681 ok (non-closed singly connected) defaultFaces 17600 17681 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-50 270 -50) (50 1000 50) Mesh (non-empty, non-wedge) directions (0 0 0) Mesh (non-empty) directions (0 0 0) ***Number of edges not aligned with or perpendicular to non-empty directions: 323200 <<Writing 169680 points on non-aligned edges to set nonAlignedEdges Boundary openness (8.36976e-17 1.65837e-18 -8.32554e-17) OK. Max cell openness = 4.07927e-16 OK. Max aspect ratio = -1 OK. Minimum face area = 0.340203. Maximum face area = 19.6751. Face area magnitudes OK. ***Zero or negative cell volume detected. Minimum negative volume: -52.991, Number of negative volume cells: 160000 <<Writing 160000 zero volume cells to set zeroVolumeCells Mesh non-orthogonality Max: 180 average: 158.904 ***Number of non-orthogonality errors: 470400. <<Writing 470400 non-orthogonal faces to set nonOrthoFaces ***Error in face pyramids: 960000 faces are incorrectly oriented. <<Writing 489600 faces with incorrect orientation to set wrongOrientedFaces Max skewness = 0.998588 OK. Coupled point location match (average 0) OK. Failed 4 mesh checks. End |
July 11, 2016, 05:41 |
Solved.
Marco Bernardes
Rep Power: 16 |
Solved! The sequence was wrong.
November 28, 2016, 07:11 |
Ramin
Rep Power: 10 |
hi
this error is because of false hex assigning focus on choosing points in hex selection for example : hex ( 0 1 2 3 4 5 6 7) direction between 0 to 1 in all of hexes should be the same( e.g x axis) direction between 1 to 2 in all of hexes should be the same (e.g y axis) or we can say that you should use "right hand low" in assigning your hexes. Best wishes Ramin |
blockmeshdict, checkmesh error |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 13:21 |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 05:28 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
