Upper Boundary condition for a mesh split at half channel height |
December 2, 2016, 03:23 |
Robert
Rep Power: 11 |
Hello everyone,
i'm modelling a flow between two plates which are defined as wall-BC's. To save comp. resources i want to split my model at half channel height (red line), and only model the lower half. The lower boundary remains to be a wall-BC. I don't want any influence on the flow at the upper boundary. Untill now i use a slip-BC for my upper boundary which now lies at 1 µm. That works fine, i'd say. Q1: Would it be a better solution to use the symmetryPlane BC here as i would expect the, now missing, upper half of the flow being a mirror image of the lower part? Same basic case (2 µm height): I lower my upper boundary (red line) to ~ 0.2 µm to only model the part of the flow close to the wall. Q2: Do i use the slip-BC or the symmetry-BC (the missing part of the model would now be more than 50%). Thanks for your answers, Robert |
blockmesh, boundary conditon, crack flow, half channel height |
3D Windturbine simulation in SU2 | k.vimalakanthan | SU2 | 15 | October 12, 2023 05:53 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
