April 14, 2005, 16:30 |
Trouble with blockMesh
Marco Kupiainen
Rep Power: 17 |
I have a good and kosher blockMeshDict, which describes my mesh. I have doubled the number of grid points in all directions, and blockMesh works fine. Now I wanted to make another doubling of grid points, and tried to run blockMesh, but got the following cryptic message and the program died:
/*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.0.2 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : /afs/nada.kth.se/home/nada/marcok/OpenFOAM/OpenFOAM-1.0.2/applications/ bin/linuxIA64I64Opt/blockMesh . base3 Date : Apr 14 2005 Time : 16:35:47 Host : h05n23.pdc.kth.se PID : 869 Root : /afs/nada.kth.se/home/nada/marcok/prj00 Case : base3 Nprocs : 1 Create database Reading block mesh description dictionary Creating block mesh Creating blockCorners Creating curved edges Creating blocks Creating patches Creating block mesh topology Default patch type set to empty Check block mesh topology Basic statistics Number of internal faces : 101 Number of boundary faces : 50 Number of defined boundary faces : 50 Number of undefined boundary faces : 0 Checking patch -> block consistency Creating block offsets Creating merge list . Creating points Creating cells Creating patches Creating mesh from block mesh Default patch type set to empty What can be the problem? Is there some limitation? best regards |
April 15, 2005, 06:22 |
What is your cryptic message?
Mattijs Janssens
Rep Power: 26 |
What is your cryptic message? All seems ok. Does it core dump and if so what if you compile blockMesh with debugging and traceback in a debugger?
April 15, 2005, 07:40 |
It does not core dump. In fact
Marco Kupiainen
Rep Power: 17 |
It does not core dump. In fact the trouble is that there is no output i.e. no grid. It seems that everything is fine, but still no grid. By the way the gridsize will be something around 8 million cells, can this cause problems?
April 15, 2005, 07:42 |
Are you running 32bit or 64bit
Rep Power: 22 |
Are you running 32bit or 64bit? You can't generate 8e6 cells with only 32bit addressing, the maximum is about 2e6 but you can with 64bit.
April 15, 2005, 07:56 |
How do I check if I'm running
Marco Kupiainen
Rep Power: 17 |
How do I check if I'm running 32bit or 64bit? The machine sure supports 64bit, but I'm not sure if I compiled the code with the right flags.
April 15, 2005, 08:06 |
There is an optional environme
Rep Power: 22 |
There is an optional environment variable to switch between 32bit and 64bit on machines that support both, $WM_64, which is documented in the README file. What do you have it set to? If you have it set and you are on an AMD64 machine $WM_OPTIONS will be linuxAMD64Opt otherwise it will be linuxOpt and you are running 32bit.
April 15, 2005, 09:51 |
I'm running 64bit, since
sete
Marco Kupiainen
Rep Power: 17 |
setenv WM_64 yes and echo $WM_OPTIONS linuxIA64I64Opt. I have only one time directory 0.075 present, does this have to be named 0? |
April 15, 2005, 11:13 |
No there is nothing fundamenta
Rep Power: 22 |
No there is nothing fundamental about the 0 directory unless you have specified in the controlDict that the code will start from time 0.
April 18, 2005, 05:40 |
Now I understand, why the prog
#9 |
Marco Kupiainen
Rep Power: 17 |
Now I understand, why the program crashes...
I have 8GB of memory available, and blockMesh requires more for 8million cells. Is there a parallell blockMesh? This would mean that 1cell = 1000B, is this really reasonable? |
April 18, 2005, 06:26 |
Does this include swap space?
#10 |
Eugene de Villiers
Rep Power: 21 |
Does this include swap space? If you have a 64-bit machine, simply increase your swap. Running blockMesh might take a bit longer, but you shouldn't have memory problems.
In any case, blockMesh uses less than 1kB per cell (~750 bytes when I last checked), so your problem might be elsewhere. Even if it was a memory issue, you would get an error message stating this. The fact that the code exits without any warnings or errors messages is HIGHLY unusual. Make sure you execute "ulimit -c unlimited" in your login shell, run the code again and check whether it has generated a core dump. I dont even want to begin to speculate what could cause a crash with no error message or core dump. For the record, I have generated 32 million cell blockMeshes without any problems. There is no parallel blockMesh. As to why it uses so much memory, the source code is in OpenFOAM-1.1/applications/utilities/mesh/generation/blockMesh/ I'm sure you could significantly reduce the memory overhead if you were prepared to live without some of the built in checks. |
September 1, 2005, 13:53 |
I've seen and fixed thi
#11 |
Hrvoje Jasak
Rep Power: 33 |
I've seen and fixed this before - it is a silly error in mesh reference setup on creation of mesh modifiers. Not sure why it didn't make it into the release... However, the fix (compared to the 1.2 release) is a bit spread out so I've no idea how to pass it over short of packing up several libraries that you would have to compile locally (I suspect this will turn up more often with multiple mesh modifiers). By the way, is the mesh itself any use to you (that's easy to E-mail across) or were you after something more complex? Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
September 1, 2005, 14:01 |
Forgot to say:
- Rolando, y
#12 |
Hrvoje Jasak
Rep Power: 33 |
Forgot to say:
- Rolando, you should really define the outside patches, otherwise the complete outside surface endds up in a patch of type empty by default, which is no too healthy. - for all those out there looking at the mesh using paraFoam, the wiggly lines at the block boundaries are not real. The cells are actually rpoper polyhedral but paraview cannot deal with them so they need to be decomposed into "allowed" shapes on the fly - dxFoam does not have this problem = you only get the real mesh lines. Also, if I remember correctly, the version of dxFoam I've sent out for foam-1.1 works OK with the new version as well. Enjoy, Hrv
September 1, 2005, 14:14 |
Hi Hrvoje,
I tried to create
#13 |
Rolando Maier
Rep Power: 17 |
Hi Hrvoje,
I tried to create a mesh, thatīs a little bit more complex and there I encountered the problem. The case above is just a simplification, that Iīve chosen to shortly place the problem in the discussion group. Would it be possible to get the fix? And would it be possible for me to handle it? Do you have any other ideas, how I can overcome that problem? I tried several things, as creating each mesh block separately and merging them by "mergeMeshes". But I didnīt meet with success. Regards Rolando |
September 1, 2005, 14:19 |
I was to slow for your second
#14 |
Rolando Maier
Rep Power: 17 |
I was to slow for your second message.
Thanks for the hint. I left the outside patches in the above example to keep it short. In my real (complexer) mesh I use them. |
September 1, 2005, 17:30 |
All I can offer is access to m
#15 |
Hrvoje Jasak
Rep Power: 33 |
All I can offer is access to my development version, pending the inclusion of bug fixes into the release.
Apologies, Hrv
September 1, 2005, 19:11 |
I have made a variable mesh, t
#16 |
Ali Heidari
Rep Power: 17 |
I have made a variable mesh, two-patch cavity case, the left and right patches have different number of grids. It doesn't give acceptable results, even if I set the left and right grids the same resolution.
What I have done wrong? I appreciate any help. cavityVarMesh.tar.gz |
September 1, 2005, 23:29 |
Hi Rolando,
I tried your bl
#17 |
Mattijs Janssens
Rep Power: 26 |
Hi Rolando,
I tried your blockMeshDict and it works fine in 1.2, also under valgrind. Are you running 1.2? |
September 2, 2005, 02:56 |
Thanks Hrvoje,
Iīd be gratefu
#18 |
Rolando Maier
Rep Power: 17 |
Thanks Hrvoje,
Iīd be grateful, if you can make me accessible your version. Hi Mattijs, Iīm still running 1.1, because I donīt get the 1.2 version running on my machine. My linux version doesnīt provide the proper glibc. I tried to compile OpenFOAM yesterday, but I didnīt succeed so far. Rolando |
September 2, 2005, 08:50 |
Dear Ali,
Ias I have suspec
#19 |
Hrvoje Jasak
Rep Power: 33 |
Dear Ali,
Ias I have suspected, there is absolutely nothing wrong with the code (again!). Attached is the image of the solution from your case Could you please have a careful look at it and tell me precisely why you think there is something strange about it. Also, please note that the case runs out of box exactly as you have provided it; the only difference is that it converges in about 10 s simulation time rather than the 0.5 s in the tutorial. May I also suggest much more care if in the future you decide to report problems with the code - reporting issues that are not there or are a result of poor setup or understanding leaves a bad image of the code which it does not deserve (wastes my time as well!) Regards, Hrv
September 2, 2005, 13:00 |
Dear Hrvoje, dear Mattijs,
th
#20 |
Rolando Maier
Rep Power: 17 |
thanks for your help. I got version 1.2 running on my machine. Now the mesh generation seems to work fine. Rolando |
[blockMesh] trouble shooting for 3d complex geometry using blockMesh | kush verma | OpenFOAM Meshing & Mesh Conversion | 1 | July 4, 2016 12:29 |
[blockMesh] Trouble using blockMesh for axisymmetric geometry | twinturbotom | OpenFOAM Meshing & Mesh Conversion | 1 | February 8, 2016 20:59 |
[blockMesh] tutorial 2.2 Stress(...) trouble with blockMesh | colinB | OpenFOAM Meshing & Mesh Conversion | 8 | January 22, 2012 10:32 |
Blockmesh cavity error message | tonitoney | OpenFOAM Installation | 2 | March 17, 2008 11:59 |
BlockMesh trouble | r2d2 | OpenFOAM Pre-Processing | 2 | January 16, 2006 09:51 |
