[blockMesh] Tool Block generation with blender
Old   December 19, 2008, 09:19
Default Tool Block generation with blender
Niklas Wikstrom
wikstrom is on a distinguished road
since snappy came to life, blockMesh has become a more interesting tool. Therefore I have written a small blender plugin to help in the tedious generation of the blockMeshDict block structure.
The plugin is in an early stage, and lacks exception handling and gui, but it can be used as follows (blender should be launched from terminal so messages from the plugin can be seen):
1) Create the block topology in blender (Must be orhtogonal blocks) All blocks must reside in the same blender object.
2) Assert there are no duplicate vertices (remove doubles in edit mode).
3) In edit mode, select 8 vertices forming your first block.
4) Export to a file using the attached plugin.
5) Select 8 vertices forming your second block.
6) Export to the same file using the attached plugin (it will be appended to).
7) Repeat for all blocks.
8) OPTIONAL: To produce a skewed block structure, move the nodes in blender and export to a new file. Then replace the vertices in the first file with the vertices in this new file.
9) Hand edit the blockMesh file.
NOTE: Since I haven't grasped how to handle tolerances in blender yet, the exported vertices only include 3 decimal digits!
I know this is not very userfriendly, but hand editing blockMeshDict is worse by far, imho.
To install a blender plugin, simply put it in $HOME/.blender/scripts/
exportBlockMeshVertices.py
Please feel free to enhance this embryo of a tool.
cheers
Niklas
wikstrom is offline   Reply With Quote
Old   December 19, 2008, 09:22
Default And a new version: http://
Niklas Wikstrom
And a new version:
blockMeshExporter.py
N.
Old   December 22, 2008, 09:09
Default And a GUI version: 1) Creat
Niklas Wikstrom
And a GUI version:
1) Create block topology (orthogonal blocks!)
2) Remove duplicate vertices
3) Open a "Scripts Window" in blender
3) Select from Scripts->Export menu "BlockMesh Export GUI" (Some buttons should appear)
4) Select output file, or accept default
5) In edit mode select 8 vertices forming a block
6) Press "Register block"
7) Repeat 5) and 6) until all blocks are registred
8) Optional: Now, you can move the vertices around, to create a "skewed" block structure.
8) Press "Write and quit"
blockMeshExporterGUI.py
/N
It takes about 1 minute to create
Old   December 29, 2008, 08:05
Default Some enhancements and changes.
Niklas Wikstrom
/N
Old   December 29, 2008, 10:50
Default Later updates can be fetched a
Niklas Wikstrom
Later updates can be fetched at
http://nikwik.webfactional.com/public.html
/n
Old   July 27, 2009, 15:25
Fabian Braennstroem
braennstroem is on a distinguished road
Hi Niklas,
nice approach. Could you suggest some tutorials for hex mesh creation in blender in combination with your scripts?
Thanks!
Fabian
braennstroem is offline   Reply With Quote
Old   July 28, 2009, 07:10
Henrik Rusche
henrik is on a distinguished road
Dear All,
I had a go with blender, but I haven't tried creating blockMesh files with it. It's all very interesting and I just want to make sure that you are aware of this presentation:
http://www.imac.unavarra.es/Cursos/A...FOAMCharts.pdf
Douglas released the code. Maybe somebody can post up-to-date pointers.
Henrik
henrik is offline   Reply With Quote
Old   August 12, 2009, 17:03
Ahmed
Ahmed is on a distinguished road
Originally Posted by henrik View Post
Dear All,
Henrik
Could you please check/update the link
Thanks and good luck
Ahmed is offline   Reply With Quote
Old   August 12, 2009, 17:09
Henrik Rusche
Just did. Works for me. Henrik
[swiftBlock/swiftSnap] SwiftSnap and SwiftBlock, GUIs for OpenFOAM's meshers kalle OpenFOAM Community Contributions 292 May 20, 2023 09:50
[ICEM] Replay not working properly - Creating the mesh for Free Block. Wingman ANSYS Meshing & Geometry 4 January 17, 2017 03:57
[blockMesh] blockMesh error - Negative Volume Block adoledin OpenFOAM Meshing & Mesh Conversion 2 June 22, 2016 10:44
[ICEM] Quest for seemingly simple Blocking (degenerate block) la7low ANSYS Meshing & Geometry 0 July 12, 2011 19:48
Latest news in mesh generation Robert Schneiders Main CFD Forum 0 March 2, 1999 04:07
