Home > Forums > OpenFOAM Native Meshers: blockMesh
PolySpline question
Old   October 1, 2008, 07:37
Default Hello! I have a problem usi
Steinar Aasebų
saasebo is on a distinguished road
Hello!
I have a problem using the polySpline in blockMesh, does anyone know the syntax that must be used? It have not found it anywhere!
Thanks,
Steinar
saasebo is offline   Reply With Quote
Old   October 2, 2008, 06:39
Default If I remember correctly the sy
Martin Aunskjaer
aunola is on a distinguished road
If I remember correctly the syntax is
polySpline pntA pntB ( (ctrl1) (ctrl2) ... (ctrlN) ) grad_pntA grad_pntB;
where (pntA,grad_pntA) and (pntB,grad_pntB) are the coordinates and the gradients at the end points of the curve, and the (ctrl) are controlpoints.
Use the search facility to search for polySpline. I recall reading about it in the forum.
aunola is offline   Reply With Quote
Old   October 2, 2008, 07:15
Default Yes, this syntax is accepted b
Steinar Aasebų
Yes, this syntax is accepted by blockMesh, but the gradients are giving me unexpected results.
I really think I need some kind of B-splines to avoid the disturbances near the end points, and they are not implemented in OF?
Old   October 2, 2008, 09:52
Default go to the bugs list there is t
Franz
ffbof is on a distinguished road
go to the bugs list there is the solution or
search for "Bugs in polySplineEdge.C"
ffbof is offline   Reply With Quote
Old   October 2, 2008, 11:08
Default What kind of unexpected result
Martin Aunskjaer
What kind of unexpected results? If you mean erratic shapes, like loops, this may happen for unevenly spaced data points if the algorithm that calculates the control points assigns uniformly spaced parameter values to the data points.
Looking at the implementation in
applications/utilities/mesh/generation/blockMesh/curvedEdges
this does indeed appear to be the case. You could try to specify the gradients to zero in which case polySpline calculates them as a finite-difference (Catmull-Rom).
polySpline in OpenFOAM is a clamped cubic B-Spline.
Old   December 4, 2008, 09:10
Default Dear Martin, I got trouble
Wolfgang Heydlauff
wolle1982 is on a distinguished road
Dear Martin,
I got trouble with the polySpline as well. Poorly I did not understand any word of what you said.
HOW can I get the polySpline work?
The polySpline works fine at the beginning. but towards the end point it starts to become a straight line. the given gradient is ignored as well.
Thanks
wolle1982 is offline   Reply With Quote
Thread Tools
Trackbacks are On
Help polySpline ivan_cozza OpenFOAM Native Meshers: blockMesh 1 July 17, 2008 01:08
CFX 10 question DAK565656 CFX 0 August 6, 2007 00:06
About a question Flora FLUENT 0 December 4, 2006 09:07
C question shuo OpenFOAM Running, Solving & CFD 0 September 30, 2006 18:56
UDF question Ryan FLUENT 2 July 5, 2006 14:54
