Wedge geometry with two blocks
Hello World.
For my next problem, I need a axisymmetric geometry like this: http://www.cfd-online.com/OpenFOAM_D...ges/1/8074.png I have done some wedge-geometry before but this is special to me. I need two different boundary-conditions at the bottom: Inflow for the red area, wall for the blue area. So, I tried to blockMesh the geometry using two blocks. http://www.cfd-online.com/OpenFOAM_D...hment_icon.gif blockMeshDict But this is not working. How can I manage this problem? Do you have any ideas? |
I think I didn't use the conve
I think I didn't use the convention that the two wedge-patches should straddle the x-y-plane ...
On first impression the mesh looks good. http://www.cfd-online.com/OpenFOAM_D...hment_icon.gif blockMeshDict |
Hi sega (or anyone),
I have a similar Problem. It would be very nice if you could help!!! I modified the blockMesh file above to achieve the following Situation: I have a axisymmetric geometry but with an hole around the center. It is just like your block0 is missing. On the new emerging boundary of the second block1 I have a inflow condition. Do you think this is possible with openfoam without sacrificing the symmetry ??? This question is connected to my general problem posted in this Thread: http://www.cfd-online.com/Forums/ope...tml#post337855 Thank you for helping! Philipp |
solved
1 Attachment(s)
Hi @all,
I think I solved the Problem concerning the mesh. I attached the corresponding file if somebody should have a similar problem. I thought I had already tried a similar solution but it didn't work :confused: p.s.: the other problem (concerning the formulation of the equations in the grid) is still open for discussion. please help.Thx |
