[blockMesh] could anyone post a simple cylinder mesh |
February 16, 2012, 19:00 |
#21 |
mo houssami
Rep Power: 14 |
hi all,
I took your examples and try to adapt it to my case, where i only have to make a simple cylinder that i need to mesh inside as regularly as possible. the first solution proposed doesn't work on my version of openFOAM, but the others do but its a bit tricky, since i'm still learning. If someone has an example of what i need, please post it. Anyway thank you very much, i learned a lot from this discussion. |
February 20, 2012, 16:34 |
#22 |
mo houssami
Rep Power: 14 |
it's ok, i did it !
April 23, 2012, 03:21 |
#23 | |
anonymous
Rep Power: 14 |
I have the same problem! Did you earned the mesh?? I'm new with the OPenFOAM and for me it's difficult to understand how it works the mesh generation. Thanks! |
April 23, 2012, 06:43 |
#24 |
cfdkid
Rep Power: 17 |
@libia87
OpenFOAM mesh how does it work? This is a broad question, and really depends on the problem you are solving. So, Plz discribe your problem. Note: OpenFOAM mesh making module has two major blocks. 1. blockMesh // this generate basic structured mesh for domain to be considered. 2. snappyHexMesh // This generates fine mesh for boundary ex a CAR or Cylinder. Also consider a cylinder placed in regular domain. If you want to mesh inside the cylnder domain Use following Patch in snappyHexMeshDict::castellatedMeshControls refinementSurfaces { myCylinder // user defined cylinder { level (2 2); faceZone cylinder; cellZone cylinder; zoneInside true; // inside or ZoneOutside for outer mesh } } . Also it is best you state your model. It will be much easier for us. regards CFDkid |
April 24, 2012, 09:05 |
#25 |
blockmesh and snappyhexmesh are the two meshing programs that are included into OpemFoam. If you install Engrid you have another opensource mesher. With pyFoamDisplayBlockMesh.py an external program (you could visualize your blockmesh) => http://openfoamwiki.net/index.php/Co...m#Installation There are commercial mesher that can export directly as OF (ANSA, Hypermesh, Pointwise, CastNet) |
July 24, 2012, 09:55 |
#26 |
P.M.Bronow
Rep Power: 16 |
has anyone tried to run script provided by Rasmus with the OF 2.0.1? I get an error when I try to run the blockMesh on blockMeshDict created after execution of the m4 script. blockMeshDict can be seen below. This is what I get after executing Rasmus's script: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.1 | | \\ / A nd | Web: http://www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.001; //5 mm column diameter //10 cm length //Width of middle square section //how many cells in the square section //how many cells from square section to perimeter // how many cells from top to bottom vertices ( ( 1.25 0.0 1.25) // Vertex fiveoclocksqb = 0 (-1.25 0.0 1.25) // Vertex sevenoclocksqb = 1 (-1.25 0.0 -1.25) // Vertex elevenoclocksqb = 2 ( 1.25 0.0 -1.25) // Vertex oneoclocksqb = 3 ( 1.76776695455285 0.0 1.76776695137989) // Vertex fiveoclockcb = 4 (-1.76776695455285 0.0 1.76776695137989) // Vertex sevenoclockcb = 5 (-1.76776695455285 0.0 -1.76776695137989) // Vertex elevenoclockcb = 6 ( 1.76776695455285 0.0 -1.76776695137989) // Vertex oneoclockcb = 7 ( 1.25 100 1.25) // Vertex fiveoclocksqt = 8 (-1.25 100 1.25) // Vertex sevenoclocksqt = 9 (-1.25 100 -1.25) // Vertex elevenoclocksqt = 10 ( 1.25 100 -1.25) // Vertex oneoclocksqt = 11 ( 1.76776695455285 100 1.76776695137989) // Vertex fiveoclockct = 12 (-1.76776695455285 100 1.76776695137989) // Vertex sevenoclockct = 13 (-1.76776695455285 100 -1.76776695137989) // Vertex elevenoclockct = 14 ( 1.76776695455285 100 -1.76776695137989) // Vertex oneoclockct = 15 ); blocks ( //square block hex ( 1 0 3 2 9 8 11 10 ) (3 3 10) simpleGrading (1 1 1) //slice1 hex ( 5 4 0 1 13 12 8 9 ) (3 3 10) simpleGrading (1 1 1) //slice2 hex ( 1 2 6 5 9 10 14 13 ) (3 3 10) simpleGrading (1 1 1) //slice3 hex ( 2 3 7 6 10 11 15 14 ) (3 3 10) simpleGrading (1 1 1) //slice4 hex ( 3 0 4 7 11 8 12 15 ) (3 3 10) simpleGrading (1 1 1) ); //create the quarter circles edges ( arc 4 5 (0.0 0.0 2.5) arc 5 6 (-2.5 0.0 0.0) arc 6 7 (0.0 0.0 -2.5) arc 7 4 (2.5 0.0 0.0) arc 12 13 (0.0 100 2.5) arc 13 14 (-2.5 100 0.0) arc 14 15 (0.0 100 -2.5) arc 15 12 (2.5 100 0.0) ); patches ( patch outlet ( (2 4(0 3 2 1)) (2 4(0 4 7 3)) (2 4(4 0 1 5)) (2 4(1 2 6 5)) (2 4(3 7 6 2)) ) patch inlet ( (2 4(8 11 10 9)) (2 4(8 12 15 11)) (2 4(12 8 9 13)) (2 4(9 10 14 13)) (2 4(11 15 14 10)) ) wall walls ( (2 4(5 4 12 13)) (2 4(5 13 14 6)) (2 4(6 14 15 7)) (2 4(7 15 12 4)) ) ); mergePatchPairs ( ); |
July 28, 2012, 09:55 |
#27 | |
Adam
Rep Power: 14 |
PrzemekPL,
I believe it has to do with a change in the way that patches are now defined. Rename the attached version to .m4 and use the same method that hemph described: Quote:
-Smed |
July 30, 2012, 03:36 |
#28 |
P.M.Bronow
Rep Power: 16 |
Smed,
you were right. There was an issue with the patches definition, i.e. : (2 4(fiveoclocksqb oneoclocksqb elevenoclocksqb sevenoclocksqb)) Now, everything works, thanks! |
December 12, 2012, 10:59 |
#29 |
Burak
Rep Power: 13 |
Hello
Here is my small contrubution to the forum.I modified the cylindermesher.m4 file to have the Z direction passing through the middle. I wanted to have arced inlet conditions for the turbinsiting tutorial so I modified the skript somebodyposted in this thread(Thanks!). So maybe somebody needs this version also.Just rename the file to cylindermesher.m4 and use it(You have to have the m4 preprocessor installed).I hope this helps. My Regards Burak |
May 7, 2013, 11:17 |
#30 | |
Álex de Sousa Vieira
I'm trying to do basically the same mesh from this problem but using openfoam 2.1.1 and all the examples posted aren't working. Using the mesh generated from the file posted from Burak_1984 i get the blockMesh but when i try to see it on paraFoam the following error appears: --> FOAM FATAL IO ERROR: keyword outlet is undefined in dictionary "/home/lest/Downloads/C1/0/p::boundaryField" file: /home/lest/Downloads/C1/0/p::boundaryField from line 25 to line 35. From function dictionary::subDict(const word& keyword) const in file db/dictionary/dictionary.C at line 461. FOAM exiting Can anyone help me? Last edited by ÁlexVieira; May 7, 2013 at 12:02. |
September 13, 2013, 04:34 |
#31 | ||
Benjamin van den Akker
Rep Power: 12 |
February 26, 2016, 04:20 |
create cylineder mesh by collapsing one edge
#32 |
Dr Sachin Borse
Rep Power: 14 |
Dear all,
First make block. Collapse one side. Use arc for one side in block. Preapre mesh for half cylivder. see fig halfcyl. create blockmesh. use feature mirrorMesh by keeping and editing file mirrorMeshDict in system. See cylinder made in fig. fullcyl. Regards Dr Sachin Borse |
March 25, 2016, 07:45 |
#33 | |
Steve
Rep Power: 13 |
Seems that some syntax has changed... Thanks |
October 10, 2016, 22:24 |
Error in blockMeshDict
#34 | |
UHGAR
Rep Power: 9 |
Hi Foamers,
I am very new to OpenFoam and I have modified the codes posted by the members in this thread as follows. Code:
/*-----------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.3 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*-----------------------------------------------------*/ FoamFile { version 2.0; format ascii; root ""; case ""; instance ""; local ""; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * *// //meshGenApp blockMesh; convertToMeters 0.001; r 2.2; // Radius of Inlet R #calc "20*$r"; // Domain radius Inlet_z 11; // Inlet from origin (-ve) Outlet_z 110; // Outlet distance from origin halfAngle 45.0; // Fixed angle for mid-point radHalfAngle #calc "degToRad($halfAngle)"; mid_c1 #calc "$r*sin($radHalfAngle)"; // Mid-point for Inner cylinder arc mid_c2 #calc "$R*sin($radHalfAngle)"; // Mid-point for Outer cylinder arc vertices ( ( $r #calc"-1*$r" #calc "-1*$Inlet_z") //0 ( $r $r #calc "-1*$Inlet_z") (#calc"-1*$r" $r #calc "-1*$Inlet_z") (#calc"-1*$r" #calc"-1*$r" #calc "-1*$Inlet_z") ( $r #calc"-1*$r" 0) //4 ( $r $r 0) (#calc"-1*$r" $r 0) (#calc"-1*$r" #calc"-1*$r" 0) ( $R #calc"-1*$R" 0) //8 ( $R $R 0) (#calc"-1*$R" $R 0) (#calc"-1*$R" #calc"-1*$R" 0) ( $R #calc"-1*$R" $Outlet_z) //12 ( $R $R $Outlet_z) (#calc"-1*$R" $R $Outlet_z) (#calc"-1*$R" #calc"-1*$R" $Outlet_z) ( $r #calc"-1*$r" $Outlet_z) //16 ( $r $r $Outlet_z) (#calc"-1*$r" $r $Outlet_z) (#calc"-1*$r" #calc"-1*$r" $Outlet_z) ); blocks ( hex (0 1 2 3 4 5 6 7) (10 10 10) simpleGrading (1 1 1) hex (4 5 6 7 16 17 18 19) (10 10 10) simpleGrading (1 1 1) hex (10 6 5 9 14 18 17 13) (10 10 10) simpleGrading (1 1 1) hex (11 7 6 10 15 19 18 14) (10 10 10) simpleGrading (1 1 1) hex (8 4 7 11 12 16 19 15) (10 10 10) simpleGrading (1 1 1) hex (9 5 4 8 13 17 16 12) (10 10 10) simpleGrading (1 1 1) ); edges ( arc 2 1 (0.0 $mid_c1 #calc "-1*$Inlet_z") arc 1 0 ($mid_c1 0.0 #calc "-1*$Inlet_z") arc 0 3 (0.0 #calc"-1*$mid_c1" #calc "-1*$Inlet_z") arc 3 2 (#calc"-1*$mid_c1" 0.0 #calc "-1*$Inlet_z") arc 6 5 (0.0 $mid_c1 0) arc 5 4 ($mid_c1 0.0 0) arc 4 7 (0.0 #calc"-1*$mid_c1" 0) arc 7 6 (#calc"-1*$mid_c1" 0.0 0) arc 10 9 (0.0 $mid_c2 0.0) arc 9 8 ($mid_c2 0.0 0.0) arc 8 11 (0.0 #calc"-1*$mid_c2" 0.0) arc 11 10 (#calc"-1*$mid_c2" 0.0 0.0) arc 18 17 (0.0 $mid_c2 $Outlet_z) arc 17 16 ($mid_c2 0.0 $Outlet_z) arc 16 19 (0.0 #calc"-1*$mid_c2" $Outlet_z) arc 19 18 (#calc"-1*$mid_c2" 0.0 $Outlet_z) arc 14 13 (0.0 $mid_c2 $Outlet_z) arc 13 12 ($mid_c2 0.0 $Outlet_z) arc 12 15 (0.0 #calc"-1*$mid_c2" $Outlet_z) arc 15 14 (#calc"-1*$mid_c2" 0.0 $Outlet_z) ); boundary ( Inlet { type patch; faces ( (0 3 2 1) ); } Outlet { type patch; faces ( (16 17 18 19) (17 13 14 18) (18 14 15 19) (12 16 19 15) (12 13 17 16) ); } Wall { type patch; faces ( (0 1 5 4) (5 1 2 6) (3 7 6 2) (7 11 10 6) (10 9 5 6) (9 8 4 5) (9 13 12 8) (12 15 11 8) (15 14 10 11) (14 13 9 10) ); } ); Quote:
October 11, 2016, 02:57 |
#35 |
Rep Power: 15 |
Have you visualized your mesh? There seems to be something wrong with your mesh if your maximum aspect ratio is 0. Check that the mesh is the type you want before proceeding further. Cheers, Antimony |
October 11, 2016, 22:41 |
#36 |
UHGAR
Rep Power: 9 |
Hi Antimony,
Thanks for your reply, I got it. I have corrected the script as follows. Code:
/*-----------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.3 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*-----------------------------------------------------*/ FoamFile { version 2.0; format ascii; root ""; case ""; instance ""; local ""; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * *// //meshGenApp blockMesh; convertToMeters 0.001; r 1.1; // Radius of Inlet (mm) R #calc "20*$r"; // Domain radius (mm) Inlet_z_1 80; // Inlet-1 from origin (-ve) (mm) Inlet_z_2 10; // Inlet-2 (exit of inlet-1) from origin (-ve) (mm) Outlet_z 110; // Outlet distance from origin (mm) halfAngle 45.0; // Fixed angle for mid-point radHalfAngle #calc "degToRad($halfAngle)"; mid_c1 #calc "$r/sin($radHalfAngle)"; // Mid-point for Inner cylinder arc mid_c2 #calc "$R/sin($radHalfAngle)"; // Mid-point for Outer cylinder arc vertices ( ( $r #calc"-1*$r" #calc "-1*$Inlet_z_1") //0 ( $r $r #calc "-1*$Inlet_z_1") (#calc"-1*$r" $r #calc "-1*$Inlet_z_1") (#calc"-1*$r" #calc"-1*$r" #calc "-1*$Inlet_z_1") ( $r #calc"-1*$r" #calc "-1*$Inlet_z_2") //4 ( $r $r #calc "-1*$Inlet_z_2") (#calc"-1*$r" $r #calc "-1*$Inlet_z_2") (#calc"-1*$r" #calc"-1*$r" #calc "-1*$Inlet_z_2") ( $r #calc"-1*$r" 0) //8 ( $r $r 0) (#calc"-1*$r" $r 0) (#calc"-1*$r" #calc"-1*$r" 0) ( $R #calc"-1*$R" 0) //12 ( $R $R 0) (#calc"-1*$R" $R 0) (#calc"-1*$R" #calc"-1*$R" 0) ( $r #calc"-1*$r" $Outlet_z) //16 ( $r $r $Outlet_z) (#calc"-1*$r" $r $Outlet_z) (#calc"-1*$r" #calc"-1*$r" $Outlet_z) ( $R #calc"-1*$R" $Outlet_z) //20 ( $R $R $Outlet_z) (#calc"-1*$R" $R $Outlet_z) (#calc"-1*$R" #calc"-1*$R" $Outlet_z) ); blocks ( hex (0 1 2 3 4 5 6 7) (20 20 80) simpleGrading (1 1 1) hex (4 5 6 7 8 9 10 11) (20 20 10) simpleGrading (1 1 1) hex (8 9 10 11 16 17 18 19) (20 20 80) simpleGrading (1 1 1) hex (14 10 9 13 22 18 17 21) (40 20 80) simpleGrading (0.5 1 1) hex (15 11 10 14 23 19 18 22) (40 20 80) simpleGrading (0.5 1 1) hex (12 8 11 15 20 16 19 23) (40 20 80) simpleGrading (0.5 1 1) hex (13 9 8 12 21 17 16 20) (40 20 80) simpleGrading (0.5 1 1) ); edges ( arc 2 1 (0.0 $mid_c1 #calc "-1*$Inlet_z_1") arc 1 0 ($mid_c1 0.0 #calc "-1*$Inlet_z_1") arc 0 3 (0.0 #calc"-1*$mid_c1" #calc "-1*$Inlet_z_1") arc 3 2 (#calc"-1*$mid_c1" 0.0 #calc "-1*$Inlet_z_1") arc 6 5 (0.0 $mid_c1 #calc "-1*$Inlet_z_2") arc 5 4 ($mid_c1 0.0 #calc "-1*$Inlet_z_2") arc 4 7 (0.0 #calc"-1*$mid_c1" #calc "-1*$Inlet_z_2") arc 7 6 (#calc"-1*$mid_c1" 0.0 #calc "-1*$Inlet_z_2") arc 10 9 (0.0 $mid_c1 0.0 ) arc 9 8 ($mid_c1 0.0 0.0 ) arc 8 11 (0.0 #calc"-1*$mid_c1" 0.0 ) arc 11 10(#calc"-1*$mid_c1" 0.0 0.0 ) arc 14 13(0.0 $mid_c2 0.0 ) arc 13 12($mid_c2 0.0 0.0 ) arc 12 15(0.0 #calc"-1*$mid_c2" 0.0 ) arc 15 14(#calc"-1*$mid_c2" 0.0 0.0 ) arc 18 17(0.0 $mid_c1 $Outlet_z ) arc 17 16($mid_c1 0.0 $Outlet_z ) arc 16 19(0.0 #calc"-1*$mid_c1" $Outlet_z ) arc 19 18(#calc"-1*$mid_c1" 0.0 $Outlet_z ) arc 22 21(0.0 $mid_c2 $Outlet_z ) arc 21 20($mid_c2 0.0 $Outlet_z ) arc 20 23 (0.0 #calc"-1*$mid_c2" $Outlet_z ) arc 23 22 (#calc"-1*$mid_c2" 0.0 $Outlet_z ) ); boundary ( Inlet { type patch; faces ( (0 3 2 1) ); } Outlet { type patch; faces ( (16 17 18 19) (17 21 22 18) (18 22 23 19) (20 16 19 23) (20 21 17 16) ); } Walls { type wall; faces ( (0 1 5 4) (1 2 6 5) (2 3 7 6) (3 0 4 7) (4 5 9 8) (5 6 10 9) (6 7 11 10) (7 4 8 11) (8 12 15 11) (11 15 14 10) (10 14 13 9) (9 13 12 8) (12 13 21 20) (15 12 20 23) (14 15 23 22) (13 14 22 21) ); } ); mergePatchPairs ( ); /* patches ( patch inlet ( (0 3 2 1) ) patch outlet ( (16 17 18 19) (17 21 22 18) (18 22 23 19) (20 16 19 23) (20 21 17 16) ) ); mergePatchPairs ( ); |
September 29, 2017, 16:51 |
Update for OpenFOAM V5
#37 |
Simpson
He everyone there have been some updates to OpenFOAM since this was last posted I updated the .m4 file for the the version 5.
Paste in a text file and see under extension .m4: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant/polyMesh"; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // changecom(//)changequote([,]) define(calc, [esyscmd(perl -e 'printf ($1)')]) define(VCOUNT, 0) define(vlabel, [[// ]Vertex $1 = VCOUNT define($1, VCOUNT)define([VCOUNT], incr(VCOUNT))]) meshGenApp blockMesh; convertToMeters 0.001; define(D, 10) //10 mm column diameter define(L, 500) //50 cm length define(PI, 3.14159265) define(R, calc(D/2)) define(CW, calc(D/4)) //Width of middle square section define(CX, calc(R*cos((PI/180)*45))) define(CZ, calc(R*sin((PI/180)*45))) define(NPS, 50) // how many cells in width of square section define(NPD, 50) // how many cells from square section edge to perimeter of cylinder define(NPY, 50) // how many cells from top to bottom vertices ( ( CW 0.0 CW) vlabel(fiveoclocksqb) (-CW 0.0 CW) vlabel(sevenoclocksqb) (-CW 0.0 -CW) vlabel(elevenoclocksqb) ( CW 0.0 -CW) vlabel(oneoclocksqb) ( CX 0.0 CZ) vlabel(fiveoclockcb) (-CX 0.0 CZ) vlabel(sevenoclockcb) (-CX 0.0 -CZ) vlabel(elevenoclockcb) ( CX 0.0 -CZ) vlabel(oneoclockcb) ( CW L CW) vlabel(fiveoclocksqt) (-CW L CW) vlabel(sevenoclocksqt) (-CW L -CW) vlabel(elevenoclocksqt) ( CW L -CW) vlabel(oneoclocksqt) ( CX L CZ) vlabel(fiveoclockct) (-CX L CZ) vlabel(sevenoclockct) (-CX L -CZ) vlabel(elevenoclockct) ( CX L -CZ) vlabel(oneoclockct) ); blocks ( //square block hex ( sevenoclocksqb fiveoclocksqb oneoclocksqb elevenoclocksqb sevenoclocksqt fiveoclocksqt oneoclocksqt elevenoclocksqt ) (NPS NPS NPY) simpleGrading (1 1 1) //slice1 hex ( sevenoclockcb fiveoclockcb fiveoclocksqb sevenoclocksqb sevenoclockct fiveoclockct fiveoclocksqt sevenoclocksqt ) (NPS NPD NPY) simpleGrading (1 1 1) //slice2 hex ( sevenoclocksqb elevenoclocksqb elevenoclockcb sevenoclockcb sevenoclocksqt elevenoclocksqt elevenoclockct sevenoclockct ) (NPS NPD NPY) simpleGrading (1 1 1) //slice3 hex ( elevenoclocksqb oneoclocksqb oneoclockcb elevenoclockcb elevenoclocksqt oneoclocksqt oneoclockct elevenoclockct ) (NPS NPD NPY) simpleGrading (1 1 1) //slice4 hex ( oneoclocksqb fiveoclocksqb fiveoclockcb oneoclockcb oneoclocksqt fiveoclocksqt fiveoclockct oneoclockct ) (NPS NPD NPY) simpleGrading (1 1 1) ); //create the quarter circles edges ( arc fiveoclockcb sevenoclockcb (0.0 0.0 R) arc sevenoclockcb elevenoclockcb (-R 0.0 0.0) arc elevenoclockcb oneoclockcb (0.0 0.0 -R) arc oneoclockcb fiveoclockcb (R 0.0 0.0) arc fiveoclockct sevenoclockct (0.0 L R) arc sevenoclockct elevenoclockct (-R L 0.0) arc elevenoclockct oneoclockct (0.0 L -R) arc oneoclockct fiveoclockct (R L 0.0) ); boundary ( outlet { type patch; faces ( (fiveoclocksqb oneoclocksqb elevenoclocksqb sevenoclocksqb) (fiveoclocksqb fiveoclockcb oneoclockcb oneoclocksqb) (fiveoclockcb fiveoclocksqb sevenoclocksqb sevenoclockcb) (sevenoclocksqb elevenoclocksqb elevenoclockcb sevenoclockcb) (oneoclocksqb oneoclockcb elevenoclockcb elevenoclocksqb) ); } inlet { type patch; faces ( (fiveoclocksqt oneoclocksqt elevenoclocksqt sevenoclocksqt) (fiveoclocksqt fiveoclockct oneoclockct oneoclocksqt) (fiveoclockct fiveoclocksqt sevenoclocksqt sevenoclockct) (sevenoclocksqt elevenoclocksqt elevenoclockct sevenoclockct) (oneoclocksqt oneoclockct elevenoclockct elevenoclocksqt) ); } walls { type wall; faces ( (sevenoclockcb fiveoclockcb fiveoclockct sevenoclockct) (sevenoclockcb sevenoclockct elevenoclockct elevenoclockcb) (elevenoclockcb elevenoclockct oneoclockct oneoclockcb) (oneoclockcb oneoclockct fiveoclockct fiveoclockcb) ); } ); // ************************************************** *********************** // |
November 11, 2017, 16:02 |
#38 |
Rep Power: 20 |
Here is a pipe mesh done with OpenFOAM-dev and the #calc function. As well as the new methods to adress patches via their block and face number. Also naming the points etc is used. The values 0.278 and 0.35 are chosen in such a way, that the non orthogonality and skewness of the resulting mesh is optimal for the current mesh size. It also features an additional outer region for increased resolution of the boundary layer.
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: dev | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.001; ra1 10; // radius in mm le1 0; // start le2 100; // end a1p #calc "0.35*$ra1*sin(degToRad(45.0))"; a2p #calc "0.900*$ra1*sin(degToRad(45.0))"; a3p #calc "1.000*$ra1*sin(degToRad(45.0))"; a1n #calc "-$a1p"; a2n #calc "-$a2p"; a3n #calc "-$a3p"; ap1 #calc " 0.278*$ra1"; an1 #calc "-0.278*$ra1"; ap2 #calc " 0.900*$ra1"; an2 #calc "-0.900*$ra1"; ap3 #calc " 1.000*$ra1"; an3 #calc "-1.000*$ra1"; xa 10; // mesh resolution ya 10; // mesh resolution za 100; // mesh resolution vertices ( name a00 ($a1n $a1n $le1) name a01 ($a1p $a1n $le1) name a02 ($a1p $a1p $le1) name a03 ($a1n $a1p $le1) name a04 ($a2n $a2n $le1) name a05 ($a2p $a2n $le1) name a06 ($a2p $a2p $le1) name a07 ($a2n $a2p $le1) name a08 ($a3n $a3n $le1) name a09 ($a3p $a3n $le1) name a10 ($a3p $a3p $le1) name a11 ($a3n $a3p $le1) name b00 ($a1n $a1n $le2) name b01 ($a1p $a1n $le2) name b02 ($a1p $a1p $le2) name b03 ($a1n $a1p $le2) name b04 ($a2n $a2n $le2) name b05 ($a2p $a2n $le2) name b06 ($a2p $a2p $le2) name b07 ($a2n $a2p $le2) name b08 ($a3n $a3n $le2) name b09 ($a3p $a3n $le2) name b10 ($a3p $a3p $le2) name b11 ($a3n $a3p $le2) ); blocks ( hex (a00 a01 a02 a03 b00 b01 b02 b03) fluid ($ya $ya $za) simpleGrading (1 1 1) hex (a06 a02 a01 a05 b06 b02 b01 b05) fluid ($xa $ya $za) simpleGrading (1 1 1) hex (a07 a03 a02 a06 b07 b03 b02 b06) fluid ($xa $ya $za) simpleGrading (1 1 1) hex (a04 a00 a03 a07 b04 b00 b03 b07) fluid ($xa $ya $za) simpleGrading (1 1 1) hex (a05 a01 a00 a04 b05 b01 b00 b04) fluid ($xa $ya $za) simpleGrading (1 1 1) hex (a10 a06 a05 a09 b10 b06 b05 b09) fluid (3 $ya $za) simpleGrading (5 1 1) hex (a11 a07 a06 a10 b11 b07 b06 b10) fluid (3 $ya $za) simpleGrading (5 1 1) hex (a08 a04 a07 a11 b08 b04 b07 b11) fluid (3 $ya $za) simpleGrading (5 1 1) hex (a09 a05 a04 a08 b09 b05 b04 b08) fluid (3 $ya $za) simpleGrading (5 1 1) ); edges ( arc a00 a01 (0 $an1 $le1) arc a01 a02 ($ap1 0 $le1) arc a02 a03 (0 $ap1 $le1) arc a03 a00 ($an1 0 $le1) arc a04 a05 (0 $an2 $le1) arc a05 a06 ($ap2 0 $le1) arc a06 a07 (0 $ap2 $le1) arc a07 a04 ($an2 0 $le1) arc a08 a09 (0 $an3 $le1) arc a09 a10 ($ap3 0 $le1) arc a10 a11 (0 $ap3 $le1) arc a11 a08 ($an3 0 $le1) arc b00 b01 (0 $an1 $le2) arc b01 b02 ($ap1 0 $le2) arc b02 b03 (0 $ap1 $le2) arc b03 b00 ($an1 0 $le2) arc b04 b05 (0 $an2 $le2) arc b05 b06 ($ap2 0 $le2) arc b06 b07 (0 $ap2 $le2) arc b07 b04 ($an2 0 $le2) arc b08 b09 (0 $an3 $le2) arc b09 b10 ($ap3 0 $le2) arc b10 b11 (0 $ap3 $le2) arc b11 b08 ($an3 0 $le2) ); defaultPatch { name walls; type wall; } boundary ( inlet { type patch; faces ( (0 4) (1 4) (2 4) (3 4) (4 4) (5 4) (6 4) (7 4) (8 4) ); } outlet { type patch; faces ( (0 5) (1 5) (2 5) (3 5) (4 5) (5 5) (6 5) (7 5) (8 5) ); } ); |
December 6, 2019, 03:06 |
1/4 of pipe with blockmesh
#39 |
Franco
Rep Power: 6 |
hello,
i am fairly new with OpenFOAM and well, the preprocessing is a little bit complicated, OF it is super powerfull as software but a little bit complicated to get the hand on it.... i wanted to do a 1/4 of a cylinder with blockmesh, is it possible to do the blockmesh with polyhedral cells for the mesh? also how can i define a simple quarter of cylinder, i found some examples in the comments of a cylinder but it was difficult to follow them.... i wanted to finish with something where i can define the R and the lenght of the hight in Z with the 5 different patches defined... |
May 8, 2020, 11:08 |
#40 |
Rep Power: 5 |
Hello everyone!
I am currently working with OpenFoam to create a cylinder. The cylinder I need should only be discretized in the h direction (Photo). Does anyone know how I can avoid the round basement being divided into so many small cells? (I have attached a photo). I´m quite new to OpenFoam and would be very happy if someone could help me! Regards! |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
Prescribed Translating Cylinder Mesh for Added Mass Problem (Transient FSI) | Lloyd Sullivan | CFX | 5 | August 7, 2018 08:11 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[ICEM] How to mesh for regular pentagonal cylinder using ICEM in 2D? | ranjanrk | ANSYS Meshing & Geometry | 0 | June 18, 2016 02:10 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
