Home > Forums > OpenFOAM Native Meshers: blockMesh
Internal walls of zero thickness
Like Tree5Likes
Old   April 6, 2009, 01:50
lakeat's Avatar
Daniel WEI (老魏)
lakeat is on a distinguished road
Send a message via Skype™ to lakeat
Hi again, I found the solution, use the normalToFace option in faceSetDic
    // Faces with normal to within certain angle aligned with vector.
    normalToFace
        normal (0.309016994 0.951056516 0);     // Vector
        cos     0.000000001;       // Tolerance (max cos of angle)
Note: as for zero thickness plate, set cos option a small one, (use foamToVTK -faceSet plateTmp to Check it).
What a nice day!
Daniel
Daniel WEI
Boeing Research & Technology - China
Beijing, China
Email
lakeat is offline   Reply With Quote
Old   March 19, 2015, 10:21
sati is on a distinguished road
It may seem weird to answer to a post so long after it was written, but as i fell on it today, i'm thinking that maybe i could help other people having this problem.
A very simple trick to create a thin wall in an internal face is to create a point with the same coordinates than on of those which are on the internal face. Then, define the faces and the blocks as if one of the points was on one side of the face, and the other point was on the other face. This way, the mesh is identical to the one created before, exept that there is no more an intern face, and defining a wall patch there becomes trivial.
mizzou likes this.
sati is offline   Reply With Quote
Old   December 15, 2015, 03:06
Mojtaba.a's Avatar
Mojtaba Amiraslanpour
Mojtaba.a is on a distinguished road
Send a message via Skype™ to Mojtaba.a
Wouldn't this lead into a new block, which has absolute poor cells within it?
mizzou likes this.
Learn OpenFOAM in Persian for free, And ask your questions here.
Complex Heat & Flow Simulation Research Group
If you can't explain it simply, you don't understand it well enough. "Richard Feynman"
Mojtaba.a is offline   Reply With Quote
Thread Tools
Trackbacks are On
SnappyHexMesh internal walls podallaire OpenFOAM Mesh Utilities 2 July 24, 2008 09:12
Fluent3dMeshToFoam error with Fluent mesh with internal walls jdk OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 3 February 19, 2008 10:01
starccm+2 handling of internal walls/faces nico CD-adapco 2 June 8, 2007 05:58
Internal Walls in Hex hagupta CFX 4 June 7, 2006 09:09
Internal/Interior walls in Gambit/Tgrid Riaan FLUENT 0 March 31, 2006 22:16
