-   OpenFOAM Native Meshers: blockMesh (http://www.cfd-online.com/Forums/openfoam-meshing-blockmesh/)
-   -   BlockMesh error in channel flow (http://www.cfd-online.com/Forums/openfoam-meshing-blockmesh/61808-blockmesh-error-channel-flow.html)
lofty March 3, 2008 16:03
Hi I am simulating a flow i
Hi
I am simulating a flow in a channel with cyclic BC and four ribs inside which i have specified as walls. I am getting the following error when i execute the blockMesh.
Reading block mesh description dictionary
Creating block mesh
Creating blockCorners
Creating curved edges
Creating blocks
Creating patches
Creating block mesh topology
--> FOAM Warning :
From function cellModel::mag(const labelList&, const pointField&)
in file meshes/meshShapes/cellModel/cellModel.C at line 134
zero or negative pyramid volume: -1.33333 for face 4
Default patch type set to empty
--> FOAM FATAL ERROR : face 1 in patch 0 does not have neighbour cell face: 4(0 18 20 43)#0 Foam::error::printStack(Foam:http://www.cfd-online.com/OpenFOAM_D...part/proud.gifstream&) in "/home/caelinux/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/caelinux/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Foam::polyMesh::facePatchFaceCells(Foam::List<foam ::face> const&, Foam::List<foam::list<int> > const&, Foam::List<foam::list<foam::face> > const&, int) const in "/home/caelinux/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#3 Foam::polyMesh::polyMesh(Foam::IOobject const&, Foam::Field<foam::vector<double> > const&, Foam::List<foam::cellshape> const&, Foam::List<foam::list<foam::face> > const&, Foam::List<foam::word> const&, Foam::List<foam::word> const&, Foam::word const&, Foam::List<foam::word> const&, bool) in "/home/caelinux/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#4 Foam::blockMesh::createTopology(Foam::IOdictionary &) in "/home/caelinux/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/blockMesh "
#5 Foam::blockMesh::blockMesh(Foam::IOdictionary&) in "/home/caelinux/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/blockMesh "
#6 main in "/home/caelinux/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/blockMesh "
#7 __libc_start_main in "/lib/i686/libc.so.6"
#8 Foam::regIOobject::readIfModified() in "/home/caelinux/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/blockMesh "
From function polyMesh::facePatchFaceCells(const faceList& patchFaces,const labelListList& pointCells,const faceListList& cellsFaceShapes,const label patchID)
in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 127.
FOAM aborting
Any idea how to resolve the problem! Thanks in advance
hjasak March 3, 2008 17:00
Check your lock definition - o
Check your lock definition - one block is inside-out.
Hrv
lofty March 3, 2008 18:26
Sorry what is lock definition
Sorry what is lock definition Jasak. What do you mean by "one block is inside out". All the blocks are inside the channel. Here is my block dic file.
FoamFile
version 2.0;
format ascii;
root "/opt/OpenFOAM/caelinux-1.4.1/run";
case "cubes";
instance "constant/polyMesh";
local "";
class dictionary;
object blockMeshDict;
arguments "/opt/OpenFOAM/caelinux-1.4.1/run/cubes" off;
convertToMeters 0.01;
vertices
(0 0 0)
(8 0 0)
(0 2 0)
(8 2 0)
(0 8 0)
(8 8 0)
(0 0 8)
(8 0 8)
(0 2 8)
(8 2 8)
(0 8 8)
(8 8 8)
(0 0 6)
(2 0 8)
(2 0 6)
(0 2 6)
(2 2 8)
(2 2 6)
(0 0 2)
(0 0 4)
(2 0 2)
(2 0 4)
(0 2 2)
(0 2 4)
(2 2 2)
(2 2 4)
(4 0 4)
(4 0 6)
(6 0 4)
(6 0 6)
(4 2 4)
(4 2 6)
(6 2 4)
(6 2 6)
(4 0 0)
(4 0 2)
(6 0 0)
(6 0 2)
(4 2 0)
(4 2 2)
(6 2 0)
(6 2 2)
(2 2 0)
(2 0 0)
(4 0 8)
(4 2 8)
(6 0 8)
(6 2 8)
blocks
hex (0 2 42 43 18 20 24 22) (16 16 16) simpleGrading (1 1 1)
hex (19 21 25 23 12 14 17 15) (16 16 16) simpleGrading (1 1 1)
hex (43 34 38 42 13 44 45 16) (16 16 64) simpleGrading (1 1 1)
hex (35 37 41 39 26 28 32 30) (16 16 16) simpleGrading (1 1 1)
hex (27 29 33 31 44 46 47 45) (16 16 16) simpleGrading (1 1 1)
hex (36 1 3 40 46 7 9 47) (16 16 64) simpleGrading (1 1 1)
hex (2 3 5 4 8 9 11 10) (64 48 64) simpleGrading (1 1 1)
edges
patches
wall bottomWall
(19 12 14 21)
(0 18 20 43)
(43 13 44 34)
(27 44 46 29)
(35 26 28 37)
(36 46 7 1)
wall cube1
(12 6 13 14)
(15 3 16 17)
(12 14 17 15)
(6 13 16 3)
(12 6 3 15)
(14 13 16 17)
wall cube2
(18 19 21 20)
(22 23 25 24)
(18 20 24 22)
(19 21 25 23)
(18 19 23 22)
(20 21 25 24)
wall cube3
(26 27 29 28)
(30 31 33 32)
(26 27 32 30)
(27 29 33 31)
(26 27 31 30)
(28 29 33 32)
wall cube4
(34 35 37 36)
(38 39 41 40)
(34 36 40 38)
(35 37 41 39)
(34 35 39 38)
(36 37 41 40)
wall topWall
(4 10 11 5)
symmetryPlane sides1
(0 2 3 1)
(6 7 9 8)
symmetryPlane sides2
(2 4 5 3)
(8 9 11 10)
cyclic inout1
(1 3 9 7)
(0 6 8 2)
cyclic inout2
(3 5 11 9)
(2 8 10 4)
mergePatchPairs
mike_jaworski March 3, 2008 18:37
Dear OF Newbie, The order
Dear OF Newbie,
The order in which you specify the vertices of a block matter. If you look at the user-guide section on using blockMesh, it will show you the order you should specify the vertices in and how that order defines local coordinates, etc.
The relevant section of the user guide is here:
http://www.opencfd.co.uk/openfoam/do...#x31-1640006.3
You'll have to examine your block definitions for which specific block is incorrect.
Good Luck,
Mike J.
lofty March 5, 2008 09:13
Hi Can anyone explain what
Hi
Can anyone explain what the following error imply:
FOAM FATAL ERROR : face 0 in patch 11 does not have neighbour cell face: 4(12 14 13 6)#0
I do have a face opposite to face mentioned in error. Why is blockMesh not recognising it? Thank You
