-   OpenFOAM Native Meshers: blockMesh (http://www.cfd-online.com/Forums/openfoam-meshing-blockmesh/)
-   -   Problems of mutiple regions (http://www.cfd-online.com/Forums/openfoam-meshing-blockmesh/61809-problems-mutiple-regions.html)
fw407 February 7, 2008 15:23
Hi, guys I want to create a
Hi, guys
I want to create a third region in a Fluid-Structure case, but came into problems.
When I try to make a symbolic link for the regions, the first two regions is going well, but when I try to make a symbolic link for the third region(which I want to add), the symbolic link is not working well.and when I try:
blockMesh . icoStructFoamTest_multipe_region
I end up with errors:
fw407@fw407-laptop:~$ ln -s /home/fw407/OpenFOAM/fw407-1.3/run/tutorials/icoStructFoam/icoStructFoamTest_mul tipe_region/constant/region3/polyMesh/ /home/fw407/OpenFOAM/fw407-1.3/run/tutorials/icoStructFoam/icoStructFoamTest_mul tipe_region/constant/polyMesh
fw407@fw407-laptop:~$ cd /home/fw407/OpenFOAM/fw407-1.3/run/tutorials/icoStructFoam
fw407@fw407-laptop:~/OpenFOAM/fw407-1.3/run/tutorials/icoStructFoam$ blockMesh . icoStructFoamTest_multipe_region
Reading block mesh description dictionary
--> FOAM FATAL ERROR : Cannot find mesh description file
"constant/polyMesh/blockMeshDict" or
"constant/polyMesh/meshDescription" or
"constant/mesh/meshDescription"
From function blockMesh
in file genBlockMesh.C at line 102.
FOAM exiting
Could anyone tell me how to solve it?
All the best
Feng
gschaider February 7, 2008 15:56
Is there a file icoStructFoam
Is there a file icoStructFoamTest_multipe_region/constant/region3/polyMesh/blockMeshDict ?
Did you remove the symbolic link from the previous regions?
fw407 February 8, 2008 08:54
Hi, Bernhard There is a fil
Hi, Bernhard
There is a file icoStructFoamTest_multipe_region/constant/region3/polyMesh/blockMeshDict
and I have removed the symbolic link before I make a new one
However, the property dialogue of the symbolic link I create for region 3 tells me it is a broken one.
By the way, do you think it has a connection with a file called tetFemSolution? because in this file, it only define something like:
object tetFemSolution; ln -s (symbolic link for region 2)
All the best
Feng
