Home > Forums > OpenFOAM Native Meshers: blockMesh
Generating nonuniform meshes with sizefunction
Old   July 16, 2009, 04:21
John Deas
johndeas is on a distinguished road
I modified the end of my code this way:
mesh.movePoints(points);
runTime.functionObjects().off();
runTime++;
mesh.write();
And I don't have errors related to fieldAverage anymore. A new time directory is created, but, only points are exported, not the full mesh with boundaries, owners, neighbours, etc... which doesn't make all this very useful.
johndeas is offline   Reply With Quote
Old   July 16, 2009, 05:49
John Deas
I tried to understand a little how all this work.
In an fvMesh, the write() method is a reimplementation of the virtual write() inherited from polyMesh, itself inherited from objectRegistry (and itself from regIOobject).
But, when fvMesh::write() is called, the following code is executed
bool fvMesh::write() const
    return polyMesh::write();
and thus the regIOobject::write() is called, in the end.
The problem in my case is that the only written file is points.
When the fvMesh mesh is created, with
Foam::fvMesh mesh
    Foam::IOobject
     Foam::fvMesh::defaultRegion,
     runTime.timeName(),
     runTime,
     Foam::IOobject::MUST_READ
the IOobject provided is used by the inherited constructor of polyMesh, which creates the faces_, owner_, etc... each with their own IOobject, and registering all them on the fvMesh object. I don't see where is the difference of treatment, and why only the "points" file is exported.
Plus, if I try a
mesh.names()
I get:
11
cellZones
fvSolution
meshPhi
points
neighbour
faces
faceZones
fvSchemes
pointZones
boundary
owner
Which made me expect to find those files in the time directory.
Old   July 19, 2009, 13:10
Henrik Rusche
henrik is on a distinguished road
John,
it's all about saving disk space.
When OF write a mesh, it only saves data that has changed after the last dump. On read OF goes backwards through the time dumps and collects the necessary data.
All what you have to do in order to obtain a "normal" mesh is to copy 1/polyMesh/points into constant/polyMesh and delete the "1" time directory.
Henrik
henrik is offline   Reply With Quote
Old   July 19, 2009, 13:52
John Deas
Thank you for the information !
Well rewriting the whole polyMesh forced me to dive a little into OF structure which wasn't a bad thing, after all
Old   July 20, 2009, 04:36
John Deas
Something that might be attractive (my 2 cents...) would be to have the same kind of rule for field reading. If I apply a preprocess on the mesh, which outputs to other time directories, the process of field reading would detect and use the latest version so I don't have to manually copy everything on the last time directory.
Old   March 26, 2010, 04:58
Default hyperbolic mesh
  #26
guillaume maurice
guillaumem is on a distinguished road
Hi
I am also performing LES on channel flow and i would like to use ane hyperbolic mesh does someone has some know how to do that how to implement the routine in the code
guillaumem is offline   Reply With Quote
Old   April 11, 2010, 05:01
Bertrand Delvaux
Bertrand is on a distinguished road
Hello Alberto,
I am very new to OF and would like to know if it is possible for you to send me your code about "hyperbolic" (or any other analytical function" meshing? Because I would like to implement it on a variable cross-sectional cylinder, with the number of cells depending on the radius, for instance...
Thank you very much!
Best,
Bertrand
Bertrand is offline   Reply With Quote
Old   April 18, 2012, 03:53
Default final code
  #28
Lev
levka is on a distinguished road
Hello guys,
could you please upload final working code...
levka is offline   Reply With Quote
Thread Tools
Trackbacks are On
Specifying nonuniform initial condition msyaml OpenFOAM Running, Solving & CFD 65 April 25, 2016 04:23
Specifying nonuniform boundary condition maka OpenFOAM Running, Solving & CFD 59 October 22, 2014 14:52
Import or generating Meshes from Koordinates Gau%c3%9fKr%c3%bcger toby OpenFOAM Mesh Utilities 7 February 27, 2009 16:25
FixedValue nonuniform BC dmoroian OpenFOAM Running, Solving & CFD 1 November 3, 2006 05:26
Generating big meshes with GAMBIT on NT Andrew Ooi FLUENT 12 February 2, 2000 23:26
