[blockMesh] BlockMesh error with growing mesh size
Old   September 21, 2007, 00:08
Default BlockMesh error with growing mesh size
Kian Mehravaran
kian is on a distinguished road
I just upgraded to 1.4.1 by compiling the source.
I have noticed that blockMesh does not like more than 962 cells in the x-direction in the sonicFoam/shockTube example (1 block), and it gives this error if you specify more than 962 cells:
--> FOAM FATAL ERROR : face 0 in patch 0 does not have neighbour cell face: 4(0 2 3 1)#0
I don't know if this is related to the problem or not, since I had not started to really use version 1.4.1, but I had made changes to the source of sonicFoam and executed Allwmake in the applications directory. I saw some errors in vtkFoam application (different gcc versions), but the modified sonicFoam application works fine.
Thank you for your help.
Kian Mehravaran
kian is offline   Reply With Quote
Old   September 21, 2007, 00:11
Default The error message seems to sug
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
The error message seems to suggest that there is a problem in your blockMeshDict. Paste it here. Someone might be able to identify the source of the problem.
msrinath80 is offline   Reply With Quote
Old   September 21, 2007, 10:01
Default Dear Srinath, Thank you for y
Kian Mehravaran
Dear Srinath,
Thank you for your reply.
It is the one in sonicFoam/shockTube. I haven't changed the blockMeshDict. As I said, the error goes away if the mesh size is 962, instead of the original 1000! I feel that something is wrong with my blockMesh. The full error is below the letter.
Thanks, Kian Mehravaran
--> FOAM FATAL ERROR : face 0 in patch 0 does not have neighbour cell face: 4(0 1 3 2)#0 Foam::error::printStack (Foam:stream&) in "/home/kian/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccSPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/kian/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccSPOpt/libOpenFOAM.so"
#2 Foam::polyMesh::facePatchFaceCells(Foam::List<foam ::face> const&, Foam::List<foam::list<int> > const&, Foam:: List<foam::list<foam::face> > const&, int) const in "/home/kian/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccSPOpt/libOpen FOAM.so"
#3 Foam::polyMesh::polyMesh(Foam::IOobject const&, Foam::Field<foam::vector<float> > const&, Foam::List<foam::ce> const&, Foam::List<foam::list<foam::face> > const&, Foam::List<foam::word> const&, Foam::List<foam::word> const&, Foam::word const&, Foam::List<foam::word> const&, bool) in "/home/kian/OpenFOAM/OpenFOAM-1.4.1/lib/linu xGccSPOpt/libOpenFOAM.so"
#4 main in "/home/kian/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccSPOpt/blockMesh"
#5 __libc_start_main in "/lib/tls/libc.so.6"
#6 __gxx_personality_v0 at ../sysdeps/i386/elf/start.S:122
Old   September 21, 2007, 12:09
Default Wierd. It works perfectly fine
Wierd. It works perfectly fine for me here. Compare your blockMeshDict with this one:
blockMeshDict
Old   September 24, 2007, 16:00
Default Thank you for posting your blo
Kian Mehravaran
Thank you for posting your blockMeshDict, mine is exactly the same. Weird indeed.
Another weird problem that I had, reminded me of the difference our systems might have:
I compiled mine with single precision.
I noticed that when I use a deltaT lower than 1.0E-05, it is basically regarded as zero. In other words, time is always zero!
I checked the deltaT.value() in the code (sonicFoam), and it contains the correct value.
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[blockMesh] blockMesh to generate the mesh of a deep cavity eddykendo OpenFOAM Meshing & Mesh Conversion 4 July 5, 2015 16:54
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 14:37
