October 11, 2006, 03:52 |
Ccm24ToFoam problem
Hi! All
I have some difficulty with mesh converting from .ccm to OpenFOAM. I used ccm24ToFoam of OpenFOAM ver1.3, but it doesn't work fine. Please refer the log attached below. On the other hand, ccm24ToFoam of OpenFOAM ver1.2 could work fine. Does somebody help me? [tadashi@panoutsosvisitor simpleFoam_rot]$ ccm24ToFoam . dummy blade.ccm /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.3 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : ccm24ToFoam . dummy blade.ccm Date : Oct 11 2006 Time : 09:57:59 Host : panoutsosvisitor PID : 20683 Root : /home/tadashi/OpenFOAM/tadashi-1.3/run/tutorials/simpleFoam_rot Case : dummy Nprocs : 1 Create time Vertices: number: 202064 max: 202064 Cells: number: 190450 max: 190450 Faces: internal: 561490 boundary: 21340 boundary:0 ProstarRegionNumber:-1 Foam::error::printStack Foam::sigSegv::sigSegvHandler /lib64/libc.so.6 [0x33c5c2f550] ccm24ToFoam [0x411e46] ccm24ToFoam [0x412b5d] ccm24ToFoam [0x418280] __libc_start_main __gxx_personality_v0 Segmentation fault |
October 11, 2006, 05:54 |
One problem could be with non-
Mark Olesen
Rep Power: 40 |
One problem could be with non-word characters in the boundary region definitions.
October 11, 2006, 06:43 |
Thanks Mark for your reply.
I
If I use the default boundary definition at pro-star and export this boundary condition to .ngeom file, does this cause the problem when I convert .ccm to OpenFOAM? |
June 6, 2007, 11:50 |
I have also got a problem rela
Markus Graf
Rep Power: 17 |
I have also got a problem related to the ccm24ToFoam function.
I have built a mesh in a proStar and did run all the proStar commands which are described in the users manual to standardize ccm file layout. Whenever I run the ccm24ToFoam function I always receive the following error message for all my boundary faces: Vertices: number: 122105 max: 125430 Cells: number: 115585 max: 115585 Faces: internal: 340051 boundary: 13145 boundary:1 ProstarRegionNumber:1 boundary:2 ProstarRegionNumber:2 boundary:3 ProstarRegionNumber:3 boundary:4 ProstarRegionNumber:4 boundary:5 ProstarRegionNumber:5 boundary:6 ProstarRegionNumber:6 boundary:7 ProstarRegionNumber:7 boundary:8 ProstarRegionNumber:8 Error reading opt string 'BoundaryType' Number of (uncompacted) points:125431 Number of internal faces:340051 Number of boundary faces:13145 Number of (uncompacted) cells:115586 *** InternalFaces:340051 *** Number of patches:1 Patch:0 ccm boundary id:0 name:wall0 type:wall Boundary face has invalid region. Face:340051 verts:4(100218 100366 100368 100220) owner:974 neighbour:-9999 has ccm.boundary:1 which has no Foam patch equivalence. Assigning it to patch 0. To prevent this compact your boundary regions! Boundary face has invalid region. Face:340052 verts:4(104088 104248 104250 104090) owner:4984 neighbour:-9999 has ccm.boundary:1 which has no Foam patch equivalence. Assigning it to patch 0. ... The problem is that my eight different boundary faces are assigned to one single patch. Does anybody know what additional proStar command or setting I need to generate a valid ccm file so that the different boundaries are assigned to different patches after executing ccm24ToFoam? |
June 7, 2007, 15:12 |
Try ccm26ToFoam from 1.4. Has
Mattijs Janssens
Rep Power: 26 |
Try ccm26ToFoam from 1.4. Has a few bugs fixed.
June 11, 2007, 02:03 |
Thanks for your advice Mattijs
Markus Graf
Rep Power: 17 |
Thanks for your advice Mattijs. The problem doesn't occur with ccm26ToFoam.
June 12, 2007, 11:21 |
Hi Mattijs
I am new to ope
abhishek k n
Rep Power: 17 |
Hi Mattijs
I am new to open foam.....the error message when i imported ccm file using ccm26ToFoam -> FOAM FATAL ERROR : Cannot read file "bus" From function ccm26ToFoam in file ccm26ToFoam.C at line 618. What kind of format should be used binary/ascii or something different |
June 12, 2007, 13:35 |
Have a look at the source ($FO
Mattijs Janssens
Rep Power: 26 |
Have a look at the source ($FOAM_UTILITIES/mesh/conversion/ccm26ToFoam/ccm26ToFoam/ccm26ToFoam.C)
It needs as argument a file that ends in .ccm. |
June 13, 2007, 08:07 |
Hi Mattijs
It was my stup
#9 |
abhishek k n
Rep Power: 17 |
Hi Mattijs
It was my stupid mistake of typing the command. Thank you for the help. I will be contacting you in future too :-) |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
