Home > Forums > OpenFOAM Native Meshers: blockMesh
Question about icoFoam boundary file
Old   February 3, 2007, 23:59
Default Dear all, I am a brand new Op
JZ
jack2000 is on a distinguished road
Dear all,
I am a brand new OpenFoam user. I have some difficulties to understand how fill the boundary information. For example, in the case of icoFoam of tutorials, what is real meaning of nFaces and startFace? How can get information from a mesh? I would very appreciate if somebody can give me an answer.
Regards!
Jack
PS: part of boundary information from the icoFoam tutorials.
movingWall
type wall;
physicalType wall;
nFaces 20;
startFace 760;
fixedWalls
type wall;
physicalType wall;
nFaces 60;
startFace 780;
frontAndBack
type empty;
physicalType empty;
nFaces 800;
startFace 840;
jack2000 is offline   Reply With Quote
Old   February 5, 2007, 08:51
Default That information is found in t
Assistant Moderator
Bernhard Gschaider
That information is found in the Userguide Section 6.1.2
But don't bother about these numbers. Nobody (I guess not even Henry, Hrv or Mattijs) edits them by hand. You let utilities do that for you.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   February 6, 2007, 17:50
Default Hi, Bernhard, Thank you very
JZ
Hi, Bernhard,
Thank you very much for giving me some suggestion. Could you tell me what untilies I can use for finding nFaces and startFace if I have already generated a mesh? Could you use icoFoam as the example to show me how to use it? I will very appricate for that.
Best Reagrds!
Jack
Old   February 7, 2007, 16:01
Default Jack. The utilities I was r
Assistant Moderator
Bernhard Gschaider
Jack.
The utilities I was refering to are mesh generators like blockMesh and manipulators like splitMesh. They write these values and there is no need to touch them in a solver like icoFoam.
If you are a brand new user there are two things you have to know about them:
- Their meaning is explained in section 6.1.2
- Don't touch them (you'll propably break the mesh)
Old   February 7, 2007, 23:40
Default Hi, Bernhard, I am very appre
JZ
Hi, Bernhard,
I am very appreciated for your help.
Based on your answer and the testing, I am now clear that the boundary file is generated by blockMesh.
Because my FoamX doesn't work, I try to prepare the mesh and other input data manually without using FoamX. Do you think this idea works? Thank you very much again!
Best Regards!
Jack
Old   April 26, 2007, 12:19
Default Hi Jack, I had the same pr
Giovanni Boldrini
giovanni is on a distinguished road
Hi Jack,
I had the same problem, but i discovered that the boundary file is generated automatically by the command blockMesh. So you haven't to define nFaces and startFaces.
If you want to understand better what they mean, try to generate one simple block: hex (0 1 2 3 4 5 6 7) (1 1 1) simpleGrading (1 1 1), then divide it in two parts (1 2 1), finally in 8 parts (2 2 1).
It will be easier to understand face's numbers and their location.
Good Luck
Giovanni
giovanni is offline   Reply With Quote
Thread Tools
Trackbacks are On
Density in icoFoam Densidad en icoFoam manuel OpenFOAM Running, Solving & CFD 8 September 22, 2010 04:10
Question: FFT file to plow ice FLUENT 0 September 11, 2006 10:25
initial value file question Ulf Senechal CFX 3 October 7, 2004 09:26
Question about libudf file zhou1 FLUENT 1 January 29, 2004 09:22
[Question] in reading mesh file Levanto FLUENT 3 February 19, 2002 09:42
