Home > Forums > OpenFOAM Native Meshers: blockMesh
Axisymmetrical mesh
Old   January 28, 2005, 04:21
Default Hi, I want to make a axi-s
Rasmus Gjesing (Gjesing)
I want to make a axi-symmetrical mesh for a cylinder. So I have constructed a 5 degree wedge as explained in the user guide, and defined the front and back as wedge-patches.
Q1.
However, I have a question regarding the points on the radius of the cylinder. Should there coordinates just be calculated as implied by fig. 6.3 in the userguide. So, if the x-axis goes in the radius-direction, the x-coordinate will be lower than the radius.
Q2.
Also, should the wedge be exactly 5 degrees or is this just a recommandation?
Q3.
And what about the curvature of the surface of the cylinder?
Q4.
I have made the outer edge of the cylinder a circle-arc, but it appears as a straight line in paraFoam. Is paraFoam just drawing straight lines between every points? And will openFOAM use/discover the bigger area due to the curvature?
This is perhaps peanuts, but I like to be 100% certain. This is also why I use openFOAM! ;-)
Kind regards,
Rasmus
Old   January 28, 2005, 04:25
Default Q1: Yes Q2: Just a recommend
Hrvoje Jasak (Hjasak)
Q1: Yes
Q2: Just a recommendation. Should be small enough that the difference between the arc and a straight line at the outer diameter does not matter, but large enough to avoid round-off problems with decimal precision.
Q3: Neglected
Q4: There are no arcs - it is a straight line. Remember, you are really using a 3-D solver to do axi-symmetric.
Enjoy,
Hrv
Old   October 10, 2005, 11:06
Default Hi, I want to test my new sol
olivier Petit
olivier is on a distinguished road
I want to test my new solver, In first time I tested my case with icoFoam in ordre to be sure that there is no probleme with my mesh created with blockMesh.
when I run my case with icoFoam I had "Nan" in the 1st time step!!
I think that I have no devision per zero!
I will be happy If some one tel me what is the probleme with my goemetry or my mesh.
how can I make my case in the forum?
thanks a lot
olivier is offline   Reply With Quote
Old   October 10, 2005, 11:21
Default You've messed something up - t
Hrvoje Jasak
hjasak is on a distinguished road
You've messed something up - try running checkMesh to see if the mesh is correct, check the wedge boundary conditions on the front and back, check the viscosity you've set (non-zero, but not really crucial), check that the differencing schemes are set up correctly and the boundary conditions are not stupid. Check the time step.
In short, check everything :-)
Enjoy,
Hrv
Hrvoje Jasak
Old   October 10, 2005, 12:15
Default Yup, the mesh is totally wrong
Hrvoje Jasak
Yup, the mesh is totally wrong:
- it's in 2 pieces
- it is a 90 deg segment and not a wedge
- it's got blocks that are inside out
You will need to sort this out before moving on further. Try putting
setenv FOAM_SIGFPE 1
into your dot-files and you'll get more messages, e.g.:
coyote*138-> blockMesh . wedgeOliverBaily
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.2 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
Exec : blockMesh . wedgeOliverBaily
Date : Oct 10 2005
Time : 17:15:39
Host : coyote
PID : 6696
Root : /home/coyote/hjasak/OpenFOAM/hjasak-1.2/run/support
Case : wedgeOliverBaily
Nprocs : 1
Create time
Reading block mesh description dictionary
Creating block mesh
Creating blockCorners
Creating curved edges
Creating blocks
Creating patches
Creating block mesh topology
--> FOAM Warning :
From function cellModel::mag(const labelList&, const pointField&)
in file meshes/meshShapes/cellModel/cellModel.C at line 136
zero or negative pyramid volume: -1.35e-07 for face 0
--> FOAM Warning :
zero or negative pyramid volume: -1.35e-07 for face 1
--> FOAM Warning :
zero or negative pyramid volume: -8.5e-08 for face 2
--> FOAM Warning :
zero or negative pyramid volume: -1.85e-07 for face 3
--> FOAM Warning :
zero or negative pyramid volume: -1.35e-07 for face 4
--> FOAM Warning :
zero or negative pyramid volume: -1.35e-07 for face 5
--> FOAM Warning :
From function blockMesh::createTopology(IOdictionary& meshDescription)
in file createTopology.C at line 372
negative volume block : 0, probably defined inside-out
--> FOAM Warning :
zero or negative pyramid volume: -9.03125e-09 for face 0
--> FOAM Warning :
zero or negative pyramid volume: -9.03125e-09 for face 1
--> FOAM Warning :
zero or negative pyramid volume: -6.02083e-09 for face 2
--> FOAM Warning :
zero or negative pyramid volume: -1.20417e-08 for face 3
--> FOAM Warning :
zero or negative pyramid volume: -9.03125e-09 for face 4
--> FOAM Warning :
zero or negative pyramid volume: -9.03125e-09 for face 5
--> FOAM Warning :
negative volume block : 1, probably defined inside-out
--> FOAM Warning :
zero or negative pyramid volume: -2.70937e-08 for face 0
--> FOAM Warning :
zero or negative pyramid volume: -2.70938e-08 for face 1
--> FOAM Warning :
zero or negative pyramid volume: -1.80625e-08 for face 2
--> FOAM Warning :
zero or negative pyramid volume: -3.6125e-08 for face 3
--> FOAM Warning :
zero or negative pyramid volume: -2.70937e-08 for face 4
--> FOAM Warning :
zero or negative pyramid volume: -2.70937e-08 for face 5
--> FOAM Warning :
negative volume block : 2, probably defined inside-out
--> FOAM Warning :
zero or negative pyramid volume: -1.41563e-06 for face 0
--> FOAM Warning :
zero or negative pyramid volume: -1.41563e-06 for face 1
--> FOAM Warning :
zero or negative pyramid volume: -4.65583e-07 for face 2
--> FOAM Warning :
zero or negative pyramid volume: -2.36567e-06 for face 3
--> FOAM Warning :
zero or negative pyramid volume: -1.41562e-06 for face 4
--> FOAM Warning :
zero or negative pyramid volume: -1.41562e-06 for face 5
--> FOAM Warning :
negative volume block : 3, probably defined inside-out
--> FOAM Warning :
zero or negative pyramid volume: -4.24687e-06 for face 0
--> FOAM Warning :
zero or negative pyramid volume: -4.24688e-06 for face 1
--> FOAM Warning :
zero or negative pyramid volume: -1.39675e-06 for face 2
--> FOAM Warning :
zero or negative pyramid volume: -7.097e-06 for face 3
--> FOAM Warning :
zero or negative pyramid volume: -4.24688e-06 for face 4
--> FOAM Warning :
zero or negative pyramid volume: -4.24688e-06 for face 5
--> FOAM Warning :
negative volume block : 4, probably defined inside-out
--> FOAM Warning :
zero or negative pyramid volume: -7.66667e-07 for face 0
--> FOAM Warning :
zero or negative pyramid volume: -7.66667e-07 for face 1
--> FOAM Warning :
zero or negative pyramid volume: -7e-07 for face 2
--> FOAM Warning :
zero or negative pyramid volume: -8.33333e-07 for face 3
--> FOAM Warning :
zero or negative pyramid volume: -7.66667e-07 for face 4
--> FOAM Warning :
zero or negative pyramid volume: -7.66667e-07 for face 5
--> FOAM Warning :
negative volume block : 5, probably defined inside-out
--> FOAM Warning :
zero or negative pyramid volume: -2.3e-06 for face 0
--> FOAM Warning :
zero or negative pyramid volume: -2.3e-06 for face 1
--> FOAM Warning :
zero or negative pyramid volume: -2.1e-06 for face 2
--> FOAM Warning :
zero or negative pyramid volume: -2.5e-06 for face 3
--> FOAM Warning :
zero or negative pyramid volume: -2.3e-06 for face 4
--> FOAM Warning :
zero or negative pyramid volume: -2.3e-06 for face 5
--> FOAM Warning :
negative volume block : 6, probably defined inside-out
--> FOAM Warning :
zero or negative pyramid volume: -1.0945e-06 for face 0
--> FOAM Warning :
zero or negative pyramid volume: -1.0945e-06 for face 1
--> FOAM Warning :
zero or negative pyramid volume: -1.034e-06 for face 2
--> FOAM Warning :
zero or negative pyramid volume: -1.155e-06 for face 3
--> FOAM Warning :
zero or negative pyramid volume: -1.0945e-06 for face 4
--> FOAM Warning :
zero or negative pyramid volume: -1.0945e-06 for face 5
--> FOAM Warning :
negative volume block : 7, probably defined inside-out
--> FOAM Warning :
zero or negative pyramid volume: -0.000246879 for face 0
--> FOAM Warning :
zero or negative pyramid volume: -0.000246879 for face 1
--> FOAM Warning :
zero or negative pyramid volume: -9.1675e-05 for face 2
--> FOAM Warning :
zero or negative pyramid volume: -0.000402083 for face 3
--> FOAM Warning :
zero or negative pyramid volume: -0.000246879 for face 4
--> FOAM Warning :
zero or negative pyramid volume: -0.000246879 for face 5
--> FOAM Warning :
negative volume block : 8, probably defined inside-out
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
zero or negative pyramid volume: -1.80625e-08 for face 3
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
negative volume block : 9, probably defined inside-out
--> FOAM Warning :
zero or negative pyramid volume: -3.01042e-09 for face 0
--> FOAM Warning :
zero or negative pyramid volume: -3.01042e-09 for face 1
--> FOAM Warning :
zero or negative pyramid volume: -6.02083e-09 for face 3
--> FOAM Warning :
zero or negative pyramid volume: -3.01042e-09 for face 4
--> FOAM Warning :
zero or negative pyramid volume: -3.01042e-09 for face 5
--> FOAM Warning :
negative volume block : 10, probably defined inside-out
Default patch type set to empty
Caught arithmetic exception
Abort
Hrv
Hrvoje Jasak
Old   October 10, 2005, 12:36
Default 1.what is wrong with two pices
olivier Petit
1.what is wrong with two pices?
2.when I use 5deg in a wedge I have a problem with bad elements near to axis.
3. I dont understand what do you mean by:
"it's got blocks that are inside out "
best ragards
Old   October 10, 2005, 12:43
Default 1. Formally nothing, depending
Hrvoje Jasak
1. Formally nothing, depending on exactly what you're trying to do
2. Probably the same reason as here: your block definition is wrong
3. Read the manual (RTFM):
http://www.opencfd.co.uk/openfoam/do...tml#x5-40002.1
Figure 2.3 specifies how a hex block needs to be defined in terms of vertices. If vertices 4, 5, 6, 7 are behind the vertices 0, 1, 2, 3, the block volume according the the figure will be negative. This is what you have done.
Hrvoje Jasak
Old   October 10, 2005, 13:03
Default thanks for your time and your
olivier Petit
thanks for your time and your help
Old   December 23, 2005, 11:16
Default Could anybody let me know wher
ali
Ali Heidari
ali is on a distinguished road
Could anybody let me know where (in which dot file) to put 'setenv FOAM_SIGFPE 1'? Is this syntax correct or I have to add something to it.
ali is offline   Reply With Quote
Old   December 23, 2005, 12:03
Default Into your ~/.cshrc put sete
Hrvoje Jasak
setenv FOAM_SIGFPE true
Enjoy,
Hrv
Hrvoje Jasak
Old   April 2, 2007, 14:00
Default round-off errors: January 2
  #11
Maka Mohu
maka is on a distinguished road
round-off errors:
January 28, 2005:
How can we check for the later effect? This may come to be critical at high Re turbulent flows. I thought that one way, may be to do the a test computation on the same mesh with single and double precision (new option in V1.3) to check the sensitivity to round-off errors but it seems to be expensive option. Any body knows a better way or recommendation? Thanks.
Best regards,
Maka
Thanks.
maka is offline   Reply With Quote
Thread Tools
Trackbacks are On
Create fine mesh that grows to coarse mesh (Urgent CZ FLUENT 1 January 3, 2009 10:36
axisymmetrical flow sara Main CFD Forum 6 September 6, 2008 08:11
Oscillatory mesh motion setup mesh flux ERROR jaswi OpenFOAM Running, Solving & CFD 5 August 23, 2007 04:41
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
Stream function in axisymmetrical problem Daniel CD-adapco 0 September 8, 2003 11:20
