BlockMeshMergePatchPairs trouble 2
Can anyone tell me why the following blockMeshDict of a simple four blocks gives trouble when trying to merge the last pair of patches ( topMerge bottomMerge) . blockMeshDict reads: /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.0 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; root ""; case ""; instance ""; local ""; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1.0; vertices ( // z = 0 (back plane) (0 0 0) //0 (1 0 0) //1 (1 0 0) //2 (2 0 0) //3 (2 0 0) //4 (3 0 0) //5 (0 1 0) //6 (1 1 0) //7 (1 1 0) //8 (2 1 0) //9 (2 1 0) //10 (3 1 0) //11 (0 1 0) //12 (3 1 0) //13 (0 2 0) //14 (3 2 0) //15 // z = 0.1 (front plane) = +16 (0 0 0.1) //16 (1 0 0.1) //17 (1 0 0.1) //18 (2 0 0.1) //19 (2 0 0.1) //20 (3 0 0.1) //21 (0 1 0.1) //22 (1 1 0.1) //23 (1 1 0.1) //24 (2 1 0.1) //25 (2 1 0.1) //26 (3 1 0.1) //27 (0 1 0.1) //28 (3 1 0.1) //29 (0 2 0.1) //30 (3 2 0.1) //31 ); blocks ( hex (0 1 7 6 16 17 23 22) (2 2 1) simpleGrading (1 1 1) hex (2 3 9 8 18 19 25 24) set1 (2 2 1) simpleGrading (1 1 1) hex (4 5 11 10 20 21 27 26) (2 2 1) simpleGrading (1 1 1) hex (12 13 15 14 28 29 31 30) (8 2 1) simpleGrading (1 1 1) ); edges ( ); patches ( wall bottom ( (0 1 17 16) (2 3 19 18) (4 5 21 20) ) wall top ( (14 30 31 15) ) patch inflow ( (0 16 22 6) (12 28 30 14) ) patch outflow ( (5 11 27 21) (13 15 31 29) ) empty frontAndBack ( (0 6 7 1) (16 17 23 22) (2 8 9 3) (18 19 25 24) (4 10 11 5) (20 21 27 26) (12 14 15 13) (28 29 31 30) ) patch leftMerge1 ( (1 7 23 17) ) patch rightMerge1 ( (2 18 24 8) ) patch leftMerge2 ( (3 9 25 19) ) patch rightMerge2 ( (4 20 26 10) ) patch bottomMerge ( (6 22 23 7) (8 24 25 9) (10 26 27 11) ) patch topMerge ( (12 13 29 28) ) ); mergePatchPairs ( (leftMerge1 rightMerge1) (leftMerge2 rightMerge2) (topMerge bottomMerge) ); // ************************************************** *********************** // and the output of blockMesh gives the error: Enriched patch support OK. Slave faces: 6 Master faces: 8 local: 4(18 27 28 19) one side: 0 other side: 0 local: 4(28 38 36 19) one side: 0 other side: 1 Finished face 0 local: 4(36 38 29 20) one side: 1 other side: 1 --> FOAM FATAL ERROR : Zero length edge detected. Probable projection error: slave patch probably does not project onto master. Please switch on enriched patch debug for more info From function void enrichedPatch::calcCutFaces() const in file slidingInterface/enrichedPatch/enrichedPatchCutFaces.C at line 237. FOAM aborting Foam::error::printStack(Foam:http://www.cfd-online.com/OpenFOAM_D...part/proud.gifstream&) Foam::error::abort() Foam::enrichedPatch::calcCutFaces() const Foam::enrichedPatch::cutFaces() const Foam::slidingInterface::coupleInterface(Foam::poly TopoChange&) const Foam::slidingInterface::setRefinement(Foam::polyTo poChange&) const Foam::polyTopoChanger::topoChangeRequest() const Foam::polyTopoChanger::changeMesh() Foam::attachPolyTopoChanger::attach(bool) blockMesh [0x80718c2] __libc_start_main __gxx_personality_v0 ..and that is with "enriched patch debug" switched on in controlDict. What am I missing? Many thanx in advance, Radu |
I bet you 10 to 1 you messed u
I bet you 10 to 1 you messed up a choice of master and slave patch pair: the two patches must face each other. Otherwise, the slave projects into a line on a master and you get this error.
Hrv |
Oh how much I would like to lo
Oh how much I would like to loose this bet... The two patches do face each other and do have the same area and so on.
I did an even simpler test, with only three blocks, something like (in xy plane): bl3 ___________ bl1 | bl2 and defined just two merge pairs 1: between bl1 and bl2 2: between bl3 and bl1+bl2 ...and saw that it failed only when BOTH the merge pairs were specified. Any one by itself was fine.(of course the mesh had multiple regions not connected by any face) Just in case anyone is interested I post theblockMeshDict file. /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.0 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; root ""; case ""; instance ""; local ""; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1.0; vertices ( // z = 0 (back plane) (0 0 0) //0 (1 0 0) //1 (1 0 0) //2 (2 0 0) //3 (0 1 0) //4 (1 1 0) //5 (1 1 0) //6 (2 1 0) //7 (0 1 0) //8 (2 1 0) //9 (0 2 0) //10 (2 2 0) //11 // z = 0.1 (front plane) = indx+12 (0 0 0.1) //12 (1 0 0.1) //13 (1 0 0.1) //14 (2 0 0.1) //15 (0 1 0.1) //16 (1 1 0.1) //17 (1 1 0.1) //18 (2 1 0.1) //19 (0 1 0.1) //20 (2 1 0.1) //21 (0 2 0.1) //22 (2 2 0.1) //23 ); blocks ( hex (0 1 5 4 12 13 17 16) (2 4 1) simpleGrading (1 1 1) hex (2 3 7 6 14 15 19 18) set1 (2 8 1) simpleGrading (1 1 1) hex (8 9 11 10 20 21 23 22) (8 4 1) simpleGrading (1 1 1) ); edges ( ); patches ( wall bottom ( (0 1 13 12) (2 3 15 14) ) wall top ( (10 22 23 11) ) patch inflow ( (0 12 16 4) (8 20 22 10) ) patch outflow ( (3 7 19 15) (9 11 23 21) ) empty frontAndBack ( (0 4 5 1) (12 13 17 16) (2 6 7 3) (14 15 19 18) (8 10 11 9) (20 21 23 22) ) patch leftMerge ( (1 5 17 13) ) patch rightMerge ( (2 14 18 6) ) patch bottomMerge ( (4 16 17 5) (6 18 19 7) ) patch topMerge ( (8 9 21 20) ) ); mergePatchPairs ( (leftMerge rightMerge) (topMerge bottomMerge) ); // ************************************************** *********************** // Cheers, Radu |
You have two intersecting mesh
You have two intersecting mesh modifiers operating at the same time, which is not allowed - please read the documentation. If you connect them one at a time, everything works.
Hrv |
Sorry about that, but I tried
Sorry about that, but I tried to run blockMesh with either one of them switched on and then use stitchMesh for the other pair and I get the following error, e.g.:
Adding point and face zones --> FOAM FATAL ERROR : point, face or cell zone already exists From function void addZones ( const List<pointzone*>& pz, const List<facezone*>& fz, const List<cellzone*>& cz ) in file meshes/polyMesh/polyMesh.C at line 590. FOAM aborting Foam::error::printStack(Foam:http://www.cfd-online.com/OpenFOAM_D...part/proud.gifstream&) Foam::error::abort() Foam::polyMesh::addZones(Foam::List<foam::pointzon e*> const&, Foam::List<foam::facezone*> const&, Foam::List<foam::cellzone*> const&) stitchMesh [0x80564c8] __libc_start_main __gxx_personality_v0 Aborted I remember seeing this problem reported before...a long time ago...but donīt seem to be able to find that thread. Can anyone help. Thanx again, Radu |
