[blockMesh] Inconsistent number of faces
Like Tree8Likes
  • 3 Post By hjasak
  • 1 Post By Turbulence
  • 2 Post By Rider
  • 1 Post By Rider
  • 1 Post By AtoHM
Old   June 5, 2006, 13:27
Default Inconsistent number of faces
Giuseppe Noviello
derath is on a distinguished road
Hi to all
Which means this error of blockMesh?
> FOAM FATAL ERROR : Inconsistent number of faces between block pair 2 and 4
From function blockMesh::blockMesh(IOdictionary& meshDescription)
in file createMergeList.C at line 202.
FOAM exiting
Someone can help me?
Thanks in advantage
Giuseppe
derath is offline   Reply With Quote
Old   June 5, 2006, 13:29
Default It means you've got 2 blocks y
Hrvoje Jasak
It means you've got 2 blocks you are trying to connect to each other in blockMesh but they haven't got the matching number of cells in this direction or that the scaling is different.
Hrv
aow, mgnisia and MTomić like this.
Hrvoje Jasak
Old   July 17, 2012, 09:10
Default Trouble with blockMesh: inconsistent number of faces between block pairs 0 and 1
Deepak Cheekati
Turbulence is on a distinguished road
Hi all,
I tried to manipulate the blockMeshDict, but I am not able to get rid of this problem.
"inconsistent number of faces between block pairs 0 and 1"
Can anyone help?
blockMeshDict:
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 1;
vertices
(-1 39.8 -0.5)
(81 39.8 -0.5)
(-1 40.2 -0.5)
(81 40.2 -0.5)
(-1 39.8 1)
(-1 39.8 52)
(81 39.8 52)
(81 39.8 1)
(-1 40.2 1)
(-1 40.2 52)
(81 40.2 52)
(81 40.2 1)
(-1 81.2 1)
(-1 81.2 52)
(81 81.2 52)
(81 81.2 1)
(-1 -1.2 1)
(-1 -1.2 52)
(81 -1.2 52)
(81 -1.2 1)
blocks
hex (0 4 7 1 2 8 11 3) (410 2 5) simpleGrading (1 1 1)
hex (4 5 6 7 8 9 10 11) (410 2 170) simpleGrading (1 1 1)
hex (8 9 10 11 12 13 14 15) (410 205 170) simpleGrading (1 1 1)
hex (16 17 18 19 4 5 6 7) (410 205 170) simpleGrading (1 1 1)
boundary
bPlane
type patch;
faces
(0 4 7 1)
tPlane
type patch;
faces
(2 3 11 8)
fPlane
type patch;
faces
(0 2 8 4)
backPlane
type patch;
faces
(1 7 11 3)
lPlane
type patch;
faces
(0 1 3 2)
FPlane
type patch;
faces
(4 8 9 5)
(8 12 13 9)
(16 4 5 17)
BackPlane
type patch;
faces
(7 6 10 11)
(10 14 15 11)
(19 18 6 7)
LuPlane
type patch;
faces
(8 11 15 12)
LbPlane
type patch;
faces
(16 19 7 4)
RPlane
type patch;
faces
(5 6 10 9)
(9 10 14 13)
(17 18 6 5)
TuPlane
type patch;
faces
(12 15 14 13)
blPlane
type patch;
faces
(16 17 18 19)
Thank You
Shri Hari likes this.
Turbulence is offline   Reply With Quote
Old   July 17, 2012, 10:07
Rider is on a distinguished road
Could you post a drawing ? (about the geometry that you want to create with blockMesh)
Rider is offline   Reply With Quote
Old   July 17, 2012, 10:31
Deepak Cheekati
PFA the image.Will this do?
Old   July 17, 2012, 10:54
Ok, this is the geometry that I had deduced with the points
The problem is in the syntax of blocks. The correct syntax is :
hex (0 1 3 2 4 7 11 8)
hex (4 7 11 8 5 6 10 9)
hex (16 19 7 4 17 18 6 5)
hex (8 11 15 12 9 10 14 13)
arsenis and Shri Hari like this.
Old   July 17, 2012, 13:39
Deepak Cheekati
Hi Rider,
Thank you very much
Could you explain me how to number,so that I wont make this mistake again..
Thank You
Turbulence.
Old   July 18, 2012, 02:35
Hi Turbulence,
You will find the explanation of the rule to use (with illustration) on the following link:
http://www.openfoam.org/docs/user/blockMesh.php
Rider.
Old   July 18, 2012, 04:46
Deepak Cheekati
Thank you very much Rider
Old   July 18, 2012, 05:01
Your welcome
Old   November 26, 2019, 09:17
Default Inconsistent number of faces between block pair 0 and 1
  #11
Sama
Samsam2 is on a distinguished road
I have same problem and dont know what is wrong with my mesh. I get error of "Inconsistent number of faces between block pair 0 and 1". Here is copy of my blockmesh dict:
FoamFile
version 2.0;
format ascii;
class dictionary;
scale 1;
vertices
(-296 -296.6 -5000)
(-296 -296.6 2192)
(-296 -296.6 2792)
(-296 -296.6 2992)
(-296 296.6 2992)
(-296 296.6 2792)
(-296 396.6 2792)
(-296 396.6 2192)
(-296 296.6 2192)
(-296 296.6 -5000)
(296 -296.6 -5000)
(296 -296.6 2192)
(296 -296.6 2792)
(296 -296.6 2992)
(296 296.6 2992)
(296 296.6 2792)
(296 396.6 2792)
(296 396.6 2192)
(296 296.6 2192)
(296 296.6 -5000)
blocks
hex (0 9 8 1 10 19 18 11) (16 16 194) simpleGrading (1 1 1)
hex (1 8 5 2 11 18 15 12) (16 16 22) simpleGrading (1 1 1)
hex (2 5 4 3 12 15 14 13) (16 16 5) simpleGrading (1 1 1)
hex (8 7 6 5 18 17 16 15) (16 2 22) simpleGrading (1 1 1)
edges
boundary
frontAndBack
type wall;
faces
(10 11 18 19)
(11 12 15 18)
(12 13 14 15)
(18 15 16 17)
(9 8 1 0)
(8 5 2 1)
(5 4 3 2)
(7 6 5 8)
walls
type wall;
faces
(0 1 11 10)
(1 2 12 11)
(2 3 13 12)
(15 14 4 5)
(16 15 5 6)
(18 17 7 8)
(19 18 8 9)
outlet
type patch;
faces
(0 10 19 9)
inletone
type patch;
faces
(3 13 14 4)
inlettwo
type patch;
faces
(17 16 6 7)
Could you please help me how to solve this problem?
Thanks alot!
Samsam2 is offline   Reply With Quote
Old   July 9, 2020, 10:52
Default Inconsistent number of specified cell
  #12
George
gpouliasis is on a distinguished road
I am reviving this thread, since i found a problem that is not listed here. It could help somebody.
This errror can appear also if the number of specified cell in the same direction is different. In example:
(50 10 1)
(50 20 1)
It is logical, but still i made it wrong the first time
gpouliasis is offline   Reply With Quote
Old   September 11, 2021, 10:33
Unhappy same problem
  #13
Pradeep Mamillapalli
pradeep_m is on a distinguished road
Creating block offsets
Creating merge list
--> FOAM FATAL ERROR:
From function void Foam::blockMesh::calcMergeInfo()
in file blockMesh/blockMeshMerge.C at line 222.
FOAM exiting
blockMesh file
convertToMeters 1;
vertices
(0 0 -0.01) //0
(0.1 0 -0.01) //1
(0.234 0.02127 -0.01) //2
(0.279 0.308 -0.01) //3
(0.659 0.308 -0.01) //4
(0.8545 0 -0.01) //5
(0 0.321 -0.01) //6
(0.1 0.321 -0.01) //7
(0.234 0.321 -0.01) //8
(0.279 0.321 -0.01) //9
(0.659 0.321 -0.01) //10
(0.8545 0.321 -0.01) //11
(0 0 0.01) //12
(0.1 0 0.01) //13
(0.234 0.02127 0.01) //14
(0.279 0.308 0.01) //15
(0.659 0.308 0.01) //16
(0.8545 0 0.01) //17
(0 0.321 0.01) //18
(0.1 0.321 0.01) //19
(0.234 0.321 0.01) //20
(0.279 0.321 0.01) //21
(0.659 0.321 0.01) //22
(0.8545 0.321 0.01) //23
blocks
hex (0 1 7 6 12 13 19 18) (110 110 1) simpleGrading (1 1 1)
hex (1 2 8 7 13 14 20 19) (110 456 1) simpleGrading (1 1 1)
hex (2 3 9 8 14 15 21 20) (110 300 1) simpleGrading (1 1 1)
hex (3 4 10 9 15 16 22 21) (110 1454 1) simpleGrading (1 1 1)
hex (4 5 11 10 16 17 23 22) (110 718 1) simpleGrading (1 1 1)
edges
boundary
inlet
type patch;
faces
(0 12 18 6)
outlet
type patch;
faces
(5 11 23 17)
bottom
type symmetryPlane;
faces
(0 1 13 12)
top
type patch;
faces
(6 18 19 7)
(7 19 20 8)
(8 20 21 9)
(9 21 22 10)
(10 22 23 11)
obstacle
type wall;
faces
(1 2 14 13)
(2 3 15 14)
(3 4 16 15)
(4 5 17 16)
mergePatchPairs
can anyone please address my problem?
pradeep_m is offline   Reply With Quote
Old   September 11, 2021, 10:42
geometry attached here
File Type: jpg WhatsApp Image 2021-09-11 at 20.10.33.jpg (89.0 KB, 58 views)
Old   January 31, 2023, 16:07
Andrew Mills
Drew.M is on a distinguished road
I know this is old but, the link is no longer working. Is there an updated link @rider???
Thanks!
Drew.M is offline   Reply With Quote
Old   February 1, 2023, 02:51
M
AtoHM is on a distinguished road
https://www.openfoam.com/documentati...ckmesh-utility
Drew.M likes this.
AtoHM is offline   Reply With Quote
Decomposing meshes Tobi OpenFOAM Pre-Processing 22 February 24, 2023 09:23
parallel run OpenFoam Srinath Reddy OpenFOAM Running, Solving & CFD 13 February 27, 2019 09:15
foam-extend_3.1 decompose and pyfoam warning shipman OpenFOAM 3 July 24, 2014 08:14
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 10:37
